Old Apr 23, 2010, 12:35 PM
b94cast is online now
Find More Posts by b94cast
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
A few props I have played with:
The 8040 works great - flight times for me were around 7-8 minutes on a 500mah battery.
For longer flight times and still good performance, I like the 7035 prop - about 10 minutes or so.
For even longer flight times yet, but slower - I like using a 5043 prop. I can easily git 13-14 minute flights with that and a 500mah battery, without being conservative on the throttle.
b94cast is online now Find More Posts by b94cast
Old Apr 23, 2010, 12:42 PM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
Hey Fer.. I totally agree with the other guys. I have a 2826 equivalent that I am putting on a Clancy Big Bee (60" span). I hope you just typed in the motor number when you posted. I will tell you that my current beater Swift has a 3s 1100 battery and an Emax 2812.. kinda big stuff for this wing but I also put 5 feet or so of LEDs (which pull from the main battery)..
Keep us updated...
Mark
mthomas is offline Find More Posts by mthomas
Old Apr 23, 2010, 01:57 PM
teslahed is offline
Find More Posts by teslahed
Joined Jul 2008
Originally Posted by Fer View Post
wicked vid teslahed!!! i just got myself one as well and when i saw your vid i thout i wanna do this as wel... only thing is i've never done leds before. could you maybe make a quike scetch on how you did it? i'd be very greatfull.... thnx in advance!
On the swift in that video i took the 12v input direct from the Lipo battery before it got to the speed controller and stuck that across all the LEDs in parallel. In order for them not to burn out you need to stick a resister in series with each LED so it draws less current and has less voltage dropped across it. I couldn't work out the maths for that easily but the internet helped;
LED resistor value calculator
You stick in the voltage and the specification of the LED in question (given wherever you buy it from) and it gives you the ohms you need.
I've found a new method that might work better for some situations though. The biggest problem doing it previously was having to run 2 wires up each wing with all the LEDs in parallel on them. It means cutting and messing about with the wing a bit, although i'm sure if i did it again i'd get it neater.
If you just want a few LEDs and want them less permanently attached you can run an LED directly off a 3 volt watch battery (or two 1.5 volts in series). Unless you want loads of them in different spots, in which case the weight of the batteries may add up, this might even be lighter as you dont need wire.
It's also much simpler, the only thing you can get wrong is putting the LED in the wrong way round (assuming it's a 3volt LED) and then you just reverse it for correct polarity. I need to find a way to make a tiny case so i don't need to tape and untape it to turn it on and off and change the batteries but other than that it works great.
teslahed is offline Find More Posts by teslahed
Old Apr 24, 2010, 04:28 PM
Fer is offline
Fer
Find More Posts by Fer
Fer
Travelling far and wide
Fer's Avatar
Nederland
Joined Jul 2009
Thank's For all the coment's!
Hi everyone,
Thank you all, i can realy work with the info you all gave me.
Telsahed thank you to, for your explention about the led's.
The thing is, i would like to build a flying wing (swift) with a couple of led strips for night flying and eventually be abel to carry fpv equipment (Maybe FCO3 + vid glasses) (or if anyone has a cheaper segetion for good FPV equipment????)
I'm wondering at the moment if it would be a better plan to get a swift maxy and use the hardware for that one?
would that be better for all the wait?
I'll keep you all updated...
Thanx again!
Fer
Fer is offline Find More Posts by Fer
Old Apr 24, 2010, 04:43 PM
Fer is offline
Fer
Fer
Fer's Avatar
Nederland
Joined Jul 2009
I found this vid on youtube:
Swift II "Night flyer" build (9 min 58 sec)
this is wat i want to do....
I love the way the leds light up the wing!
Old Apr 24, 2010, 04:45 PM
Fer is offline
Fer
Fer
Fer's Avatar
Nederland
Joined Jul 2009
and this one for the FPV:
Presenting my new FPV Swift II (3 min 23 sec)
Old Apr 24, 2010, 05:03 PM
twister782 is offline
Find More Posts by twister782
twister782's Avatar
Akron, Ohio
Joined May 2008
Originally Posted by teslahed View Post
You'll need to lighten up the back end somehow in order to get a lighter battery balanced at the front. A smaller lighter motor is the easiest option if you can get something suitable.
Here is a short video of my swift flying wing at night with LEDs;
http://www.youtube.com/watch?v=_0eR-sujYzg
For the record this one is massively overweight on a 1000mah 3 cell battery after being crashed repaired and glued for more than a year, and that was before i put the lights in it. It's not a slow flier anymore :-( Still looks pretty though.
Did you catch it at the end? I can't catch mine in the daylight. Nice vid
twister782 is offline Find More Posts by twister782
Old Apr 24, 2010, 05:27 PM
teslahed is offline
Joined Jul 2008
I did, and thanks.
If you watch the previous video closely you can see me go round again after my first attempt was too fast at the 1:50 mark.
Launching and catching my flying wing (0 min 51 sec)
Old Apr 24, 2010, 05:38 PM
twister782's Avatar
Akron, Ohio
Joined May 2008
I can't do that launch either!! I need my fingers for work. So I can pay for this hobby
Old Apr 29, 2010, 05:05 AM
teslahed is offline
Joined Jul 2008
I will admit it involved added risk but i am flying with a 6 inch prop - as long as i whip my hand away quickly enough i dont run into problems.
Having said that it only worked at the time. I've since added more lights and glue and now the plane doesn't have enough power to punch itself upwards and instead wobbles about dangerously at waist height for a second or so before hitting the ground.
Old May 03, 2010, 03:32 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
teslahead, I saw that spinning trick in a video a couple weeks ago. Been meaning to try it but haven't thought of it while I've been out flying. Looks like you've got that down pat.
It's been going over a year, but I haven't showed off my Microdan/Swift, so here's a few videos of my swift from today's flying session:
http://www.youtube.com/watch?v=NYDOJpiPiVw
Swift's make awesome video platforms. The extreme wind made it hard to get other angles, but there's some good shots of the Antioch bridge, the Sacramento delta, PG&E power plant, "beer building"... also got a few good lock's on my buddies aggressor swift.
http://www.youtube.com/watch?v=AGmMGux5Xhk
Our 13oz AUW Microdan setups are fun on windy days like today. I've got handcatches down pretty good, but on a gusty 15+MPH day like today it wasn't happening. At the end of the onboard video you can see me lining up for a handcatch, a strong gust grabbed it, I miss by 3feet, and it ran straight in to that lightpole.
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old May 03, 2010, 08:58 AM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by b94cast View Post
Here is a post from Diggs - great info on this. I used this setup (except battery, went with a 500mah because rhino's were out of stock) and thoroughly enjoy it.
Odd, the links didn't work when you quoted my post. Let me try and post this again and I hope they will work now.
Diggs.
Setup for a Swift II
There are two motors that are basically identical. I donít have a preference and have used both on several different planes and it works great.
http://hobbycity.com/hobbycity/store...idProduct=8618
http://hobbycity.com/hobbycity/store...idProduct=4859
As for the ESC, this is my current favorite due to the larger BEC
http://hobbycity.com/hobbycity/store...2A_BEC)___BESC
But if you want to go even lighter, this will work well also.
http://www.hobbycity.com/hobbycity/s...eed_Controller
I go with the larger 9 gram servos just for the extra torque and a bit better throw. I need it when going slow. If your swift is built for speed, then you donít need as much throw really. But when going slow, less air over the control surfaces, the longer throws will help.
http://hobbycity.com/hobbycity/store...ec_Micro_Servo
Lipo
http://hobbycity.com/hobbycity/store...idProduct=7308
Or any 3S pack similar in weight. This will get the CG pretty much spot on with the other gear listed above. The 3S 750mah pack works also, but makes it a touch nose heavy, but is good in the wind.
Prop
GWS EP8040
http://gwsprops.com/direct_drive.htm
A few other things I do differently.
1. Cut the servos holes out from the bottom and have the arms sticking through the top of the wing. I donít use the stock pushrods or control horns. I double z-bend heavy music wire like used on a slow stick for the push rods, or make carbon fiber push rods, and I use larger/taller control horns on the control surfaces. This makes it easier on the servo to push the surfaces and give me more throw.
2. Use Dubro Servo arm extensions to get more throw and I can burry the servo a bit deeper this way too. http://www.allerc.com/product_info.php?products_id=2087
That pretty much sums up my Swift II build. I use an AR6100 RX for my DX7 TX. I prefer the 6100E so I can burry the wires easier.
Diggs is offline Find More Posts by Diggs
Old May 03, 2010, 01:32 PM
Jbray is offline
Find More Posts by Jbray
United States, NC, Southport
Joined Mar 2010
Swift II
I just ordered one of these up and went with the setup Diggs posted here. I flew Digg's Swift II with this set up and it flew like a dream!
I am not a very experienced RC pilot and we had at least 8-10 mph winds during some of our flights last weekend and this setup was solid.
Thanks again Diggs!
Jbray is offline Find More Posts by Jbray
Old May 04, 2010, 03:26 PM
teslahed is offline
Joined Jul 2008
Nice videos, looked like you were flying well despite the wind.
There isn't all that much to the spinning trick. All you have to have is a plane with a sufficiently good power to weight ratio that it will punch itself upwards from stationary and build up speed for the control surfaces to work before it hits the ground.
Other than that make sure you let go as the thing is leaning just slightly away from you and level in that direction just off the vertical. Whip your hand away pretty quickly so you don't get caught up in the prop (i never have done doing this but i don't do it carelessly). It should fly upwards and away from you slowly leveling out until you have enough speed and height for normal flight.
I've just started building a new swift style flying wing. I bought it from www.flyingwings.co.uk which sells a swift clone called the Raven which seems identical except that the cut outs for the electronics are on the top and it comes with a carbon fibre wing spar. I'll be writting a review so here are a few pictures of progress so far if anyone is interested;
I'm very interested to see what weight i can get it down to. I intend to stick this stuff in it;
http://www.giantcod.co.uk/a220812-18...-p-402625.html
http://www.giantcod.co.uk/hobbywing-...-p-402475.html
http://www.giantcod.co.uk/loong-tipp...-p-404434.html
http://www.giantcod.co.uk/6x4e-sport...-p-403325.html
http://www.giantcod.co.uk/towerpro-s...rvo-p-268.html
I'm not going for the lightest build ever but it can get windy in Edinburgh.
Old May 04, 2010, 08:35 PM
Benign Forecast
b94cast's Avatar
Colorado
Joined Dec 2009
I will be looking forward to that review teslahed - This (Swift) aircraft is the favorite that I have (least favorite being the Skyartec Cessna) - so anything that is close to this with possible improvements definitely interests me!
I didn't create an account on the site linked - but since I am on the other side of the pond, I am not sure if it would be cost prohibitive with shipping (hope not depending on what you find!)
thanks!
... is that review done yet?
-Shaun
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
