http://hobbycity.com/hobbycity/store...idProduct=6311 Use this on my ultra lite Yak 55 and it is pretty good with 2S and an 8040 prop, but I think the higher KV will be better. I am still looking around. I don't even know which size prop will fit on it. that would be a good starting point I know the 8040 won't fit, so I am guessing 3000kv is going to be about right. Would be cool to do a tiny inrunner, but I don't think it will mount up.Let us know what you use and how it turns out. I am interested! Diggs |
Hiya's I used this on my mini. with 6030 prop. http://www.2dogrc.com/ecommerce/os/c...oducts_id=2405
seems to balance well with this batt all the way up front.http://www.headsuprc.com/servlet/the...-500mah/Detail If you use a prop saver use a tight rubber on it or you will eat into your wing with a 6inch prop. There was a mini thread here maybe we should pull it out of the deep. |
is this the thread mini swift
carl |
TC, Michigan
Joined Jan 2009
Just picked up the new Rhino 40c 1050mah 3s batt's today. 5c Charge rate and 40c discharge cont.
Should be a Stellar performer. My Swift is getting heavy with the newest addition of the TowerPro 2408-21 as well Link: http://www.hobbycity.com/hobbycity/s...idProduct=4321 Both will add about an ounce each and i have just added several CF Spars and i have Glassed the bottom of the wing. I am building this as i am my Ritewing TL50. It'll be heavy but have insane power and strength (no flex or twist) so this swift can finally overcome its fear of speed ;-) -Justin |
Diggs |
| Thread Tools | |
| Discussion Good setup for a MSComposit Swift II ? | myrslakt | Foamies (Kits) | 4 | Oct 10, 2009 02:30 PM |
| Video Swift II Maiden | Sim69 | Electric Plane Talk | 3 | Jan 27, 2007 11:32 PM |
| Sold Swift II Airbrush line British Scheme | TreeFlyer | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 05, 2007 10:58 PM |
| Discussion Swift II from MS Composit? | db1 | Flying Wings | 14 | Dec 11, 2006 07:13 PM |
| Discussion My Swift II + Question | highboy | Flying Wings | 2 | Nov 29, 2006 11:05 AM |
