Old Jul 11, 2009, 09:25 PM
Diane@lazertoyz is offline
Find More Posts by Diane@lazertoyz
Diane@lazertoyz's Avatar
United States, OH, Eastlake
Joined Jan 2007
We just located 3 mini swifts- 2 blue & 1 green , if any one is interested let us know.
Standard price $35.00 each.
Regards,
Diane
Lazertoyz.com
Diane@lazertoyz is offline Find More Posts by Diane@lazertoyz
Old Jul 11, 2009, 11:10 PM
annihil8ted is offline
Find More Posts by annihil8ted
San Diego
Joined May 2008
Originally Posted by Champaignmike
Put 1071 Mah back in the 1000 Mah pack........
Ouch, isn't that really bad for the battery?
annihil8ted is offline Find More Posts by annihil8ted
Old Jul 12, 2009, 12:16 PM
Phoenix426 is offline
Find More Posts by Phoenix426
Phoenix426's Avatar
Joined Mar 2009
actually, it's not. I've found that every lipo battery is a little different.
Almost all of my batteries take a little more or a little less that the advertised MAH. Most of them take a little more.
I have a couple 1300's that take almost 1500.
I've heard about some battery makers using larger cells and advertising them as smaller so they can give them a higher amp rating.
My 1300 batteries may be like that.
Phoenix426 is offline Find More Posts by Phoenix426
Old Jul 12, 2009, 12:39 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
Wow normally works the other way for me, what brand are your more than advertised batteries???
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jul 12, 2009, 12:58 PM
Wobby is offline
Find More Posts by Wobby
Closed Account
Joined May 2007
Yeah, thats Hobby Ciy's famous trick on the higher C rated Zippy H's, and some others they carry.
Their 5000Mah 20c lipo's, stickered and sold as 4000Mah 25c (for example)
Another example is the 2500Mah 25c~35c, they are the identical to my 3700Mah 20c
The list goes on, lol
Normally, you really dont want to take out more than 80% of a lipo's capacity if you can avoid it, they really dont like it in the long run.
Wobby is offline Find More Posts by Wobby
Old Jul 12, 2009, 02:34 PM
San Diego
Joined May 2008
Hmmm, time to get some Zippy batteries.
That's is some valuble info.
Old Jul 13, 2009, 02:33 PM
doggit is offline
Find More Posts by doggit
doggit's Avatar
northenden, manchester, england
Joined May 2009
i have just ordered the hextronik 1700kv and was wondering if a 3 cell 540 mah lipo will give me enough ooomph for the occasional vertical and some slower flying too, i have a couple of 8x4 and 8x6, also 6x6.5 upto 7x6, props, which of these will work best, i plan to put this combo into my new swift, but today i flew my old beat up swift, and was using a 49g 1400kv BL with a 8x6 prop and as i had a couple of 3 cell 1500 mah i threw one in and boy did it fly i threw it into the air and got level then full throttle, it was like the star trek enterprise going to warp well i suppose for all you experienced pilots it probably wasnt but it is the fastest i have flown, and i loved every second, and it has now given me the need for speed as much as the slow pace i normaly fly
but for now i want to get as much stick time to be able to fly at warp
carl
doggit is offline Find More Posts by doggit
Old Jul 13, 2009, 04:46 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
1700kv motor and the 8x4 will work, but you might shorten its life a bit. I am flying that setup on a superfly and on one of my swift IIs and it works, but the 1500kv is a better choice IMO. The 8x6 will hurt it for sure, you will notice it will come down very hot. I have also flown the 8x4.3 gws slowfly prop on there and that did ok, but I prefer the 8x4. It would be nice is GWS made a 7x4.
Diggs
Diggs is offline Find More Posts by Diggs
Old Jul 13, 2009, 04:59 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
I'm running the 1700kV BW swinging an APC 6x4E on my Swift II. It doesn't have unlimited vertical but it's still capable of decent vertical lines. You could try your 6x6.5 and see how it does.
They make a 7x3.5.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Jul 13, 2009, 05:28 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
They make a 7x3.5.
kendall
Yeah, but the 7x3.5 is just wimpy in everything I have installed it in. Odd, just curious if the same design of the 8x4 on a 7x4 would improve the umph for the 7 incher.
Diggs
Old Jul 13, 2009, 06:11 PM
LostPlanetAirman is offline
Find More Posts by LostPlanetAirman
Don't fly over your head!!!
LostPlanetAirman's Avatar
United States, AZ, Fountain Hills
Joined Apr 2005
I've got the GWS 7x3.5 on my Swift II attached to a CustomCDR Hot Wind Single . I'm running it on 3s and, while it doesn't have blazing speed, I get true, unlimited vertical.
Speedwise the 7x3.5 may be a bit wimpy, but unlimited vertical more than makes up for it.
LPA
LostPlanetAirman is offline Find More Posts by LostPlanetAirman
Old Jul 13, 2009, 06:22 PM
rdjay is offline
Find More Posts by rdjay
Blind Hawk
rdjay's Avatar
Seattle, WA USA
Joined Dec 2006
Diggs
Trim 1/2" off each end of the 8x4, I've done it on lots of different props and it works well.
RdJay
rdjay is offline Find More Posts by rdjay
Old Jul 13, 2009, 07:14 PM
unlvace is offline
Find More Posts by unlvace
Las Vegas
Joined May 2008
What about the 7x5 apc prop on the 1700kv.
unlvace is offline Find More Posts by unlvace
Old Jul 13, 2009, 07:42 PM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Regardless what prop you use, you're not going to get much static thrust off 3cells without overheating that motor and killing it fast (I'd estimate under 9oz continuous). If I was forced to use a stock 1700kV on my swift I'd probably use 2cell and an 8040hd. That should draw about 10A and give about 12oz thrust or so. It'll fly fine like that with a 2s900 or larger.
FWIW, the 1700kV has the lowest copper content out of all the bluewonder series motors, and thus it has the lowest efficiency. It has 10 turns of 25awg wire terminated Y, but even 11turns of 24awg newbie wire will fit in the stator with ease. This is why the 1700kV "runs hot". Note that of the bluewonder series, only the 1300kV and 1500kV are the only ones that are even close to reaching the full potential of the blue wonder mechanics (they average 70% efficiency, which is very good).
Cheers,
Kev
Truglodite is offline Find More Posts by Truglodite
Old Jul 13, 2009, 08:04 PM
yood is offline
Find More Posts by yood
Joined Jul 2007
ms composit swift 2
I ordered a swift 2 last week on the 6th of july after reading the great things about the swift 2 on this thread. Also ordered all the components. Unfortunately i was very stupid an ordered directly from ms composit usa because they were the only ones who had the paint scheme I wanted. I ordered it 2nd day air and paid the extra shipping costs. I got the confirmation email but never a tracking number. I have sent several emails to them with no response. I guess I want to know if anyone had ordered from them and how long it took to get their package. Anyone with info pls help. They will not respond to my emails requesting a tracking number and I cannot seem to cancel the order
yood is offline Find More Posts by yood
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 02:30 PM
Video Swift II Maiden Sim69 Electric Plane Talk 3 Jan 27, 2007 11:32 PM
Sold Swift II Airbrush line British Scheme Twinkletoze Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 10:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 07:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 11:05 AM
