Go Back   RC Groups > Aircraft - Electric - Airplanes > Flying Wings
Old Jul 10, 2006, 07:14 AM   #1
IceTea was already taken.
IceWind's Avatar
MSComposite Swift II
Hi to all Swift II owners.
I got one of these wings and i'm building it.
I gathered some friends ideas and started.
I'll be using a brushed 400 motor it's not the best but i'm trying to give some use to old stuff i got at home.
But for that i needed to make some changes.
Here some photos:
  • Name: normal_IMG_0131.jpg
Description: The motor mount i've made in 2mm ply using the original one has template. The motor mount i've made in 2mm ply using the original one has template. 38.5 KB · Views: 1457
  • Name: normal_IMG_0115b.jpg
Description: The motor assembly, i've used some parts of the original mount for outrunners. The motor assembly, i've used some parts of the original mount for outrunners. 43.2 KB · Views: 1510
  • Name: normal_IMG_0114b.jpg
Description: It's going to stay like this on the wing. It's going to stay like this on the wing. 34.2 KB · Views: 1508
  • Name: normal_IMG_0111c.jpg
Description: I had to cut a piece on the wing, so the motor be inserted in it, and won't stay much out, creating problems to balance it on the specified COG. I had to cut a piece on the wing, so the motor be inserted in it, and won't stay much out, creating problems to balance it on the specified COG. 35.5 KB · Views: 1043
  • Name: normal_IMG_0112c.jpg
Description: The motor and mount in place. The motor and mount in place. 36.7 KB · Views: 1623
  • Name: normal_IMG_0113c.jpg
Description: The motor fit's almost in the midle of the wing. I hope this makes it do some perfect rolls! :) The motor fit's almost in the midle of the wing. I hope this makes it do some perfect rolls! :) 22.8 KB · Views: 1304
IceWind is offline Find More Posts by IceWind   Reply With Quote
Old Jul 10, 2006, 07:40 AM   #2
Real models, not toys.
Hi Ice Wind, I had one with a small MPJet outrunner. An AXI 2208/26 is a better option, but it flyes great even with my setup.
Good luck with it.
Zdenek
  • Name: SWIFTII-001.jpg
  • Name: SWIFTII-002.jpg
  • Name: SWIFTII-003.jpg
euromodels is online now Find More Posts by euromodels   Reply With Quote
Old Jul 10, 2006, 08:05 AM   #3
IceWind's Avatar
It looks great! I bet that outrunner makes the wing really fly!!!
What battery are you using?
The only Axi i have avaiable is a 2208/34 i think, i'm no sure. But i guess i'll upgrade it from the speed 400 to an outrunner too.
It was with that in mind that i made that motor mount. (3x that in a sentence, doesn't rcgroups have a spellchecker? ...it should )
Old Jul 10, 2006, 08:26 AM   #4
You need something about 1400KV. I think an AXI2208/34 is too slow (1100KV). The MPJet I am using has 1400KV, AXI 2208/26 - 1420KV.
I used APC 8x3.8 and GWS 8x6 props. GWS is a better option, it is very flexible and doesn't break when you land. Battery: 7.2V/1500-2000mAh Lipo.
I got about 40 minuts from the bigger battery, 1500mAh is about what you need.
Old Jul 10, 2006, 04:26 PM   #5
IceWind's Avatar
I got some etec 7,4V - 1700mah and gws 11,1v - 1300mah .
But has i'm using the speed 400 i need something to make this motor alive so i'll try the 11,1v.
The prop will be a 5043 fro gws.
I hope i can make it fly, i'm being helped by a great friend if not i would have messed this all up!
Old Jul 10, 2006, 08:15 PM   #6
It is easy to fly and can survive a few crashes.
Old Jul 13, 2006, 07:56 AM   #7
IceWind's Avatar
An here it is, ready to fly.
I had to change the motor, the 400 i had was a litle stuck and i had another brand new.
I've tested it to see if it has enough trust and it seems so, holding it prop facing down about a bit more than half it starts to want go up.
  • Name: normal_IMG_0007.jpg
Old Jul 17, 2006, 09:51 PM   #8
IceWind's Avatar
Finally the maiden.
It flys perfectly it's awesome!!!
It really can glides at low speed, and if i push the throtle forward it gains speed very quickly and even going vert. Despite the motor be a 400 brushed the performance is great.
Have a look at the maiden flight.
Click here to watch Swift2-maiden
Old Aug 16, 2006, 11:49 AM   #9
ciberjohn's Avatar
LOL..olha o Nando!
Well. I have one to, with a thundertiger 2928/09 and a 8X6 prop. It flys grate, only my 4 gws 3s 1300mah packs only have 6c....will try to upgrade pack to my wing.
ciberjohn is offline Find More Posts by ciberjohn   Reply With Quote
Old Aug 19, 2006, 07:51 PM   #10
ciberjohn's Avatar
Because of IceWind I bought one, as you already know, and I ealready have it on tape ( thanks to IceWind ): http://www.ciberjohn.com/gal/display...?album=4&pos=1
Old Aug 25, 2006, 12:16 PM   #11
IceWind's Avatar
We are starting a Swift club over here!
The number of owners of them is increasing.
Old Aug 28, 2006, 08:09 AM   #12
ViruTs
I have thye swift powered by a df300 and 3s 860 lipo That's defenetivelñy my favorite wing.
With a gunther prop goes vertical unlimited, not extremely fast,defenetively not speed rocket but it flies failry rapid and above all slows down more than my IFO.
Plus thermals better than my easyglider.
submarco is offline Find More Posts by submarco   Reply With Quote
Old Oct 11, 2006, 07:06 PM   #13
ImNotAPilotIJustPlay1onTV
What are the specs on the swift?
AUW in ounces?
Wing span?
wing area in Sq In. ?
Wing loading?
Thanks!
karakoram is offline Find More Posts by karakoram   Reply With Quote
Old Dec 06, 2006, 08:14 PM   #14
Womb Drifter
Phiber Optik's Avatar
I just ran across these wings today....awesome selection of graphics, and for $35 I can't believe that people aren't all over these things.
Phiber Optik is offline Find More Posts by Phiber Optik   Reply With Quote
Old Dec 07, 2006, 01:11 AM   #15
db1
don betz
db1's Avatar
I was thinking the same thing when I saw them for sale at the JR Indoor Festival. I bought one but I'm not sure when I'll get around to installing the electronics. A quick test fit finds that the servo bays are cut just a little farther away than the servo wires are long. Oh well, I'll have to break out the iron I guess.
I was thinking of using a light slow setup. I have a power system left over from an old Slofly Micro 22. Slow with good acceleration. Might not work but I'm going to try it anyway.
db
db1 is offline Find More Posts by db1   Reply With Quote
Discussion Good setup for a MSComposit Swift II ? myrslakt Foamies (Kits) 4 Oct 10, 2009 03:30 PM
Video Swift II Maiden Sim69 Airplanes - Electric Videos 3 Jan 28, 2007 12:32 AM
Sold Swift II Airbrush line British Scheme CharM Aircraft - Electric - Airplanes (FS/W) 0 Jan 05, 2007 11:58 PM
Discussion Swift II from MS Composit? db1 Flying Wings 14 Dec 11, 2006 08:13 PM
Discussion My Swift II + Question highboy Flying Wings 2 Nov 29, 2006 12:05 PM
Congratulations SimpleM!
