Old Jul 09, 2006, 11:51 AM
Doc Holliday is offline
Find More Posts by Doc Holliday
Raleigh NC
Joined Feb 2006
Which would give me more thrust in an EDF50
Feigao 5300kv with a 3 blade rotor and 3s
Medusa 4000kv with a 3 blade rotor and 4s
Medusa 4000kv with a 5 blade rotor and 3s
Doc Holliday is offline Find More Posts by Doc Holliday
Old Jul 09, 2006, 12:24 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
it is not that simple
how is the ducting... what are the rotors ... and how many amps are running through..?
all do have a footprint on the result..
Claus
clausxpf is offline Find More Posts by clausxpf
Old Jul 09, 2006, 04:13 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
The Medusa 4000Kv is too mild for most fan use...takes too many cells for really high RPM.
The Medusa 5300Kv is the real fan motor...does well on 3 cells. It gives a little more power than the Feigao 5300 at about the same amp draw...it is a little more efficent. It costs more...the eternal tradeoff.
Also, do you mean the 3 blade 2" pitch impeller, or the 3 blade 3" pitch impeller.
The 5 bladed rotor makes the most thrust, but is also a very large amp load for the 12mm brushless motors
I sense you are rather new at EDFs, based on your questions.....If I were you, I would start out with the Feigao 5300 or the Medusa 5300 and 3S packs and get your feet wet. Start out with the stock 3 bladed 2" pitch unit and then experiemnt from there. New rotors to test later are cheap. Do consider making the bolt on fan mod to prevent loosing the fan in flight.
Do some searches on the EDF50 and motors for it...tons of info has been posted over the last couple of years.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Which would you put the good stuff in? Jason Paul Parkflyers 26 May 05, 2005 04:38 PM
How go i get more thrust in my Cd-rom motor!! Opie818 Power Systems 4 Oct 11, 2004 04:29 PM
Will a 6.0 Volt motor give me more rpm than a 7.2 volt? randall1959 Power Systems 3 Feb 08, 2004 09:50 PM
Right now, I wish my fms would give me a break. Big problems with inter cord. HELP!! adam_jorgensen Power Systems 21 Mar 24, 2002 08:24 PM
How would you install CF spars in an EPP wing? GregG Foamies (Kits) 6 Mar 07, 2002 02:42 PM
