Old Jul 11, 2006, 03:50 PM
Flint is offline
Find More Posts by Flint
Flint's Avatar
Australia, ACT, Canberra
Joined May 2001
Originally Posted by BulletMaster
I had a control rod that was only threaded one end. Also the same problem as Ozace with the ball links cracking (after trying to take off for adjustment).
Ditto, on the ball links, I have broken 4 now, 2 during the build and 2 during adjustments. No spares available yet. I hope Wattsuprc get a lot in!
Flint is offline Find More Posts by Flint
Old Jul 11, 2006, 11:02 PM
AeroSports is offline
Find More Posts by AeroSports
sky is the limit
AeroSports's Avatar
NJ, US
Joined May 2002
I built and flown mine without any problem. it flies smooth and powerful.
AeroSports is offline Find More Posts by AeroSports
Old Jul 12, 2006, 10:16 AM
helicrazi is offline
Find More Posts by helicrazi
United States, TX, Crosby
Joined Dec 2005
One wrong main shaft brg. three # 6800ZZ, in the kit, need #689ZZ, lower brg.
helicrazi is offline Find More Posts by helicrazi
Old Jul 14, 2006, 02:19 AM
geneween is offline
Find More Posts by geneween
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
more broken links
I had one link break on me, and I was missing one washer for the mixing arm. other than that smooth sailing. much better build than the 450XL IMO.
GW
geneween is offline Find More Posts by geneween
Old Jul 14, 2006, 04:21 AM
northwood is offline
Find More Posts by northwood
northwood's Avatar
Joined Aug 2005
I had no problems what so ever with my kit. No missing parts, brittle links and so on... I'm happy!
northwood is offline Find More Posts by northwood
Old Jul 14, 2006, 05:07 AM
zx12rRed is offline
Find More Posts by zx12rRed
Joined Jun 2006
- Control Shaft H60023 also has the thinned part of it to fit the grub screw for the Elevator lever in the wrong spot (therefore elevator lever hits the main shaft).
The shaft needs to be flipped around!!!!!
im having the same problem Nick and i installed the shaft precisely as the instructions and Bob White demonstrates in his TREX 600 Build video
mine doesnt hit the main shaft but there is very little movement up and down before it does, once the linkages are on there will be even less, i guess i will have to dremmel a flat spot in a more appropriate spot
i will try spinning it the other way just to see if u are right and apologise accordingly if you are
nice heli dont get me wrong well done, now i just need to find someone that knows how to set up a gy611 as i sure dont
zx12rRed is offline Find More Posts by zx12rRed
Old Jul 14, 2006, 10:30 PM
zx12rRed is offline
Joined Jun 2006
yep sorry nick i just pulled it all apart and tried it in both directions
and neither way clears the main shaft
the little indented bit on the shaft is in the wrong spot on my kit
so i just didnt use the little indented bit and moved it so the ball was vertical with the ball on the anti rotation device
definately something wrong
Old Jul 15, 2006, 12:24 AM
GoBucks is offline
Find More Posts by GoBucks
United States, OH, Westerville
Joined Oct 2005
Any one else's control shaft have alot of side to side play? Mine has what seems to be a good 1-2mm of play if I move it side to side.
GoBucks is offline Find More Posts by GoBucks
Old Jul 15, 2006, 12:35 AM
ozace is offline
Find More Posts by ozace
Renewed interest
ozace's Avatar
Melbourne , Australia
Joined Jun 2002
Not here, mine all fitted really well, only ball link issues
ozace is offline Find More Posts by ozace
Old Jul 15, 2006, 02:22 AM
geneween is offline
Conformity Kill's
Mission Viejo, CA
Joined Nov 2005
yup my control shaft moves side to side. I'm going to try to put some washers where the bearing hit to see f it helps.
geneween
Old Jul 15, 2006, 03:29 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
my control shaft is ok too.
BulletMaster is offline Find More Posts by BulletMaster
Old Jul 15, 2006, 04:50 AM
zx12rRed is offline
Joined Jun 2006
2 batch's of control shafts, 1 good and 1 bad
my shaft has about 1 to 2mm of play as well, i assumed this was ok, now i assume its not, so im gonna have to fix it.
whats the best way ?
dremmel a few mm off one end ?
or look for some little washers ?
or demand a new shaft off align ?
Old Jul 15, 2006, 04:43 PM
ozace is offline
Renewed interest
ozace's Avatar
Joined Jun 2002
There seem to be more and more ball link issues popping up. It seems to be the most common problem reported so far.
Old Jul 15, 2006, 09:44 PM
zx12rRed is offline
Joined Jun 2006
for those of you haveing issues with the small amount of play on the shaft that holds the linkages to the swash, in my spares bag that came with the heli there was one washer that was the same as the ones that go on there
i used it and no more end play
have a look and see if you have any in your spares bag
Old Jul 16, 2006, 08:25 AM
sky is the limit
AeroSports's Avatar
NJ, US
Joined May 2002
can someone show a picture of problem ball links?
Sold Almost New Align Trex 600 XL motor--65$ shipped Jag72 Aircraft - Electric - Power Systems (FS/W) 0 Jun 15, 2007 09:10 AM
Discussion Align Trex 600 metal head parts driving me crazy! kenmalecki Electric Heli Talk 12 Jun 05, 2007 12:09 AM
Discussion Align Trex 600 power options RC Man Electric Heli Talk 44 Aug 12, 2006 06:50 AM
Yippee! Align Trex 600 at modefo's heli!!!!!! prodigy Mini Helis 19 Jul 13, 2006 12:55 AM
Discussion Align TREX 600 mysn95 Electric Heli Talk 7 Mar 10, 2006 12:29 PM
