Old May 18, 2001, 11:37 PM
kit basher is offline
Find More Posts by kit basher
Mike Swan
Oroville, California, United States
Joined Oct 2000
Any thoughts on airfoil for 400/480 stuka with scale wing
Hi, Am working off of a reduced scale plan, wingspan around 30-35.Plane will be in pink foam,alot of stuff still in planning stage,was wondering about airfoils for scale wing?Thanks Mike
kit basher is offline Find More Posts by kit basher
Old May 19, 2001, 07:58 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
RG15 modified 8% root/10%tip cord and 2deg washout.
Haldor is offline Find More Posts by Haldor
Old May 19, 2001, 09:07 AM
PeterH is offline
Find More Posts by PeterH
Granby, CT, USA
Joined Jan 2001
I suggest just using what is on the original plan. I also suggest cheating a bit and going for a bit more span with a bit more tip chord. The original wing is so severely tapered that I think it is a stall/snaproll waiting to happen at any moment when built as small as you are considering. At the Reynolds numbers your wing will have, I think you won't gain any practical benefit from trying to optimize the airfoil. Good luck.
PeterH is offline Find More Posts by PeterH
Old May 19, 2001, 12:21 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
At least make the tip chord larger. As PeterH says, the Rn is so small the airfoil won't be a factor, but it will be a tip-staller.
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Discussion Any thoughts on a spad for a magnum .52? webdragon SPAD - Simple Plastic Airplane Designs 1 Oct 20, 2007 11:08 PM
Discussion Prices on used Zagi 400, 400x.. any thoughts on what is a decent price to sell at? markm75 Trader Talk 12 Apr 28, 2007 10:47 PM
Any advice on components for small scale project? Patrick_sween Scratchbuilt Indoor and Micro Models 13 May 13, 2002 08:03 PM
Any thoughts on NSP Filip E and Krontronik 200 DannyGayhart Electric Sailplanes 6 Nov 23, 2001 10:42 AM
Any thoughts on hitec flight packs? f2racer Electric Plane Talk 5 Sep 29, 2001 09:22 AM
