Old Jul 07, 2006, 07:43 AM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Can a brushless motor run in reverse?
I've got a Tower Pro motor, and would like to use it on a flying wing, but am unsure if I can wire the three leads in reverse to make it work. Thanks in advance.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Jul 07, 2006, 07:45 AM
darkfly is offline
Find More Posts by darkfly
sandy, ut
Joined Jan 2005
yes. just change the wires around untill it runs in reverse.
darkfly is offline Find More Posts by darkfly
Old Jul 07, 2006, 07:52 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
By "change the wires around", he means swap any two wires to reverse the motor.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Jul 07, 2006, 08:02 AM
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Thank you both very much.
Old Jul 07, 2006, 08:12 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Yes but I usually don't notice it until after I've made it a nightmare to get to the motor wires.
bildo baggins is offline Find More Posts by bildo baggins
Old Jul 07, 2006, 09:37 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Or use a CC ESC (and maybe others?) that can reverse the motor direction from the ESC programming mode.
hoppy is offline Find More Posts by hoppy
Old Jul 07, 2006, 03:15 PM
ken_keeler is offline
Find More Posts by ken_keeler
AMA 148796
Where it Rains
Joined Jul 2002
Me too - I seem to always forget to run the motor until the cowl is on with all those itty bitty screws, or I've glued it on such as on one of the foamys.
Which is one of the things I love about the Castle ESCs - just hook up the handy dandy CastleLink and tell it to reverse the motor.
Ken
ken_keeler is offline Find More Posts by ken_keeler
Old May 06, 2009, 02:39 AM
courage@gp is offline
Find More Posts by courage@gp
courage@gp's Avatar
Johannesburg
Joined Jun 2008
I would like to add to the question. Is it possible to make a dualsky brushless motor run on channel 4 in both directions on the fly. ie: can a robbe ESC instruct the motor to rotate left on left stick and right on right stick? Local shops here say it cant be done. Our application is a thrust motor on a large airship.
courage@gp is offline Find More Posts by courage@gp
Old May 06, 2009, 09:57 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Plane controllers don't have the reverse you're looking for, boat controllers (all?) have one.
Meet the natives?
www.yhahoogroups.com/group/sarfly
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old May 06, 2009, 02:24 PM
courage@gp's Avatar
Johannesburg
Joined Jun 2008
THANK YOU so much! You have resolved a Austrian riddle that we have received here in SA that has driven me mad! BOAT ESC!! Brilliant.
Old Jul 06, 2009, 11:27 PM
hwat rc is offline
Find More Posts by hwat rc
Australia, QLD, Maleny
Joined Jul 2009
if you reverse the wires between the battery and esc what does it do?
hwat rc is offline Find More Posts by hwat rc
Old Jul 06, 2009, 11:31 PM
Joined Feb 2001
ESC whether brushed or brushless, will go up in smoke.
This goes for all electronics in general, servo, RC, tv, appliances, car etc.
You will be your LHS will be and your wife will be
Finally, my devious mind has figured out why some ESC manufacters don't tell how to reverse rotation
Or am I just being paranoid?
Old Jul 07, 2009, 10:59 PM
hwat rc is offline
Joined Jul 2009
thanks ron,
but could it be possible that you blow up the battery instead because i accidently did swap the wires and the battery blew up? i tested the esc and motor and they seem fine.
Old Feb 11, 2011, 01:52 PM
Ready to Fly 1 is offline
Find More Posts by Ready to Fly 1
Joined Dec 2010
I'm trying to make a twin engine plane (Like a Bomber) all I know is if you change two wires from the esc to the motor it will spin the other direction. But where do I get a proppeller for the motor spinning backwards?
Ready to Fly 1 is offline Find More Posts by Ready to Fly 1
Old Feb 11, 2011, 03:08 PM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Same place you get all your propellers...just ask for a pusher prop. THey are available but there's not the same range made as standard props.
Steve
slipstick is online now Find More Posts by slipstick
Any Ideas for which Brushless motor to run in my Vasa 65 and K&A F86?? Joe Elston Electric Ducted Fan Jet Talk 52 Oct 05, 2006 05:07 PM
Question can we change the run of in-runnter brushless motor? forestsinger Power Systems 2 Jan 18, 2006 12:16 PM
Motor run-in? Alembic Parkflyers 1 Sep 26, 2002 05:55 PM
Brushless Motor Break-In Period? green66 Electric Plane Talk 13 Jul 15, 2002 04:43 PM
Motor run-in... Wet or dry? paulaac Power Systems 5 Feb 15, 2002 03:13 PM
