Old Mar 05, 2007, 01:55 PM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
The only, and by my opinion the best solution is using one of 400 size brushless outruner as Welgard A22/12/15 (as I mentioned before), or similar one (these days the brusheles are similar as egg to an egg) so it will fit inside Guppy nose on the exsisting original firewal. Look at the drawing on my previous post. I believe it is easy and efficient conversion to brushless power.
Mitja
ultralajt is offline Find More Posts by ultralajt
Old Mar 05, 2007, 02:01 PM
rud-elev is offline
Find More Posts by rud-elev
Joined Apr 2006
Originally Posted by Iso Octane
Just entertaining the idea of fitting in a GWS style gearbox with a 20mm brushless. Geared up for a 9" prop.
Firstly, it absolutely doesn't fit in the nose. Could place it further back and run a shaft, but that might throw off the CG. Then where am I going to find a 9" folding prop for a 2mm shaft?
Depending on which GWS GB (300 or 400) you would need either a 3mm or 4mm spinner set... both of which are available.
I have been recently thinking of that combo (Himax 2025-4200 and EPS 400 GB) as it is about half the price of a Hacker B20 and provides steeper gearing choices than the Hacker/Maxon 4:1.
Some of my 2M gliders are wooden fused and coverted to EP via the razor-saw, so they are not as pretty or as sleek as FG fuses. My plan was to build a nose cold air vent that would provide the needed clearance for the GB top.
Maybe one of these days.
R/E
rud-elev is offline Find More Posts by rud-elev
Old Mar 05, 2007, 02:27 PM
Iso Octane is offline
Find More Posts by Iso Octane
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
Thanks for the feedback guys.
I have the gearbox-motor combo laying around, which is why I want to go that route. I also like the idea of spinning a bigger prop, and the flexibility a gearbox provides.
The outrunner solution seems to be the easiest way (besides having to buy one) to swing a bigger prop, so it's likely I'll be doing that.
Iso Octane is offline Find More Posts by Iso Octane
Old Mar 05, 2007, 03:57 PM
oracle_9 is offline
Find More Posts by oracle_9
No drugs to fly high
oracle_9's Avatar
Toronto, Canada
Joined Jan 2004
My guppy uses a welgard 22/12/10. Still havent test flown it, maybe this weekend.
I did a static test on it a few weeks ago, here is what I got:
My setup:
8x CBP750 nihms from cheapbatterypacks $10
Corona 620 dual conv receiver $18
WA22/12/10 from Grayshobbies $21
Graupner 7x4.5 folder CAM prop with spinner $20
Bidproducts 20A BEC controller $15
This produces about at full throttle 385g (13.8oz)
With 8x4.5 graupner Schmit folder prop, its 450g (15.9oz)
I didn't have 9" props, but they definitely produce even more thrust.
I didn't have the firewall at the nose as in your diagram, rather, the firewall is on the rear of the motor. Otherwise you would have the wires in the way or hanging outside the fuse.
oracle_9 is offline Find More Posts by oracle_9
Old Mar 05, 2007, 08:53 PM
dennymaize is offline
Find More Posts by dennymaize
PA
Joined Dec 2003
Yee Haa, dang you guys are getting set to have some high climbing Guppies! Hacker A20-20L's and B20's! That should do it for sure:-) I have a B20 18L on 3 cells on my 2 meter WindDancer and I can hold it vertical by the boom, turn on the motor and launch vertical! Not sure this isn't a little over kill for the Guppy:-))
On my Guppy I have a little home made CD rom motor, weighs 28 grams and a 6/3 folder on 3 lipo cells. I havn't tried it yet but I'm pretty sure it will be plenty. I just carved the fuse round to the diameter I wanted in the front and then hollowed out the nose inside from the front with a dremel tool with a drum sander on it to the correct depth for the fire wall. Wires inside. I'll let you know how it works.
One thing I'm sure of is that there have to be plenty of small, inexpensive brushless motors that will work great and be a whole lot more effecient than the old S-400.
Keep reporting on motors and combinations guys, this is one area where i don't have a lot of time to experiment and I would like to be able to offer a power system as well.
dennymaize is offline Find More Posts by dennymaize
Old Mar 05, 2007, 09:22 PM
rdwoebke is online now
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Hey Denny,
I have a very similar motor in that little 40 inch span converted Ionosphere hand launch. I run a 6x3 folder and 3S lipo. 20 turns of 26 guage terminated in Y. Seems similar to the speed 400 DD output at about half the weight.
Ryan
rdwoebke is online now Find More Posts by rdwoebke
Old Mar 06, 2007, 12:07 AM
ultralajt's Avatar
Joined Sep 2004
Here is also one of effective power combination for the Guppy, that is already proven. Motor is mounted as I show earlier on this drawing: http://www.rcgroups.com/forums/attac...mentid=1207533
motor: ROXXY BL-outrunner 2824-34
speed controller: ROXXY BL-control 818 (6-10 NiXX or 2-3 LiXX)
accu: INTELLECT 2/3 A 1200 mAh 8 cells
prop: aeronaut 9x7 folder
Old Mar 06, 2007, 06:46 AM
ultralajt's Avatar
Joined Sep 2004
I think it is time to again gather all crucial info at one place….
…so, what we have here till now?
Plans:
http://p-chan.prkoritu.net/rc/src/11...61.pdf.unknown
http://p-chan.prkoritu.net/rc/src/11...15.pdf.unknown
http://p-chan.prkoritu.net/rc/src/11...79.pdf.unknown
http://www.profili2.com/eng/download_plan.asp?Id=861
http://www.rcgroups.com/forums/showa...hmentid=978149
http://putstuff.putfile.com/37704/4323191
Manuals:
http://www.polecataero.com/uploads/G...mblymanual.pdf
http://p-chan.prkoritu.net/rc/src/11...53.pdf.unknown
http://p-chan.prkoritu.net/rc/src/Or...20covering.wmv
Videos:
http://www.rcpics.net/img/71042
http://www.rcpics.net/img/74642
http://www.megaupload.com/?d=ARKUGEPA
http://www.megaupload.com/?d=2P8OFJON
http://freeweb.siol.net/bgrabner/guppy.avi
http://p-chan.prkoritu.net/rc/src/GUPI-HOT.avi
guppy ilk duzgun ucus (1 min 21 sec)
Guppy HOT (4 min 14 sec)
Guppy sailplane (2 min 15 sec)
Guppy electric sailplane (2 min 16 sec)
Guppy RC Plane (3 min 6 sec)
Photos:
http://www.email.si/apps/es_gallery/a.php?id=12233
http://www.email.si/apps/es_gallery/a.php?id=29876
KIT producers:
Varies internet adresses, where additional information about building the Guppy is available:
http://forum.modelarji.com/viewtopic.php?t=11069
http://forum.modelarji.com/viewtopic.php?t=8401
http://www.flyfreak-hr.org/phpBB2/vi...7b7ef0f15787ed
http://www.forum.rcmodell.hu/viewtop...r=asc&start=15
So much for now!
Mitja
Old Mar 06, 2007, 07:26 AM
Carl Petersen is offline
Find More Posts by Carl Petersen
Carl Petersen's Avatar
United States, AZ, Maricopa
Joined Mar 2002
A few bad links but very useful. Great idea.
(Actual links can't have "..." in them)
Carl Petersen is offline Find More Posts by Carl Petersen
Old Mar 06, 2007, 07:58 AM
ultralajt's Avatar
Joined Sep 2004
You are right!
I must check all that links and erase those that seems to be "dead".
It will be quite time consuming to check them all, but I think I will manage till weekend
Any hint about apropriate server where I could upload important files, will be accepted with joy!
Some servers simply delete files if users dont download them often.
But of course if someone is interested about some plans, I can send them by E-mail. Just tell me what you want and give me your email address.
But please, dont ask from me vectorised files for the CNC cutting. Those files are reserved only for the polecataero.com and future KIT producer in Europe.
Mitja
Old Mar 06, 2007, 08:16 AM
Joined Mar 2002
Old Mar 06, 2007, 06:56 PM
KevinSharbonda is offline
Find More Posts by KevinSharbonda
Make Flying Fun
United States, CO, Grand Junction
Joined May 2003
Hotliner Wing Plans...Untiled ?
Originally Posted by ultralajt
Of course, the completed manual for the Hotliner wings will be soon available!
Regards!
Mitja
Can print my wings full sized...any untiled pdfs' ?
sharbonda@comcast.net
KevinSharbonda is offline Find More Posts by KevinSharbonda
Old Mar 07, 2007, 02:31 AM
ultralajt's Avatar
Joined Sep 2004
Done!
Old Mar 07, 2007, 06:56 AM
Make Flying Fun
Joined May 2003
Sorry, I guess the email server has limit smaller than the file? didn't receive it!
Old Mar 07, 2007, 07:27 AM
ultralajt's Avatar
Joined Sep 2004
Yes, I tried already twice and got the message:
This Message was undeliverable due to the following reason:
Your message was not delivered because the return address was refused.
The return address was "<mitja.sersen.erman@siol.net>"
Please reply to <Postmaster@siol.net>
if you feel this message to be in error. The following attachments have been removed from the bounce message: GUPPY-HOTLINER wing plans-A1.pdf
Dont know what to do next....
The attached file was 545KB of size.
Mitja
Discussion Queen Bee (flying wing) as an electric sailplane? Daneel Flying Wings 4 Jul 22, 2006 12:21 PM
Electric Sailplane flying in MO rchawks Electric Sailplanes 3 Jul 25, 2005 09:21 AM
Nothing like electric sailplane flying... soholingo Electric Sailplanes 31 Dec 05, 2004 07:03 PM
Building and flying a Guppy.... Arbo Parkflyers 147 Nov 21, 2004 06:46 PM
