Old Jul 07, 2006, 06:51 AM
Tom Korn is offline
Find More Posts by Tom Korn
30 seconds until re-kit
Casselberry, Florida
Joined Dec 2002
Absolutely gorgeous, Mitja! You are a very good craftsman. Thanks for sharing with us!
Tom Korn is offline Find More Posts by Tom Korn
Old Jul 07, 2006, 10:47 AM
Redbaron25 is offline
Find More Posts by Redbaron25
North East England
Joined Feb 2004
I agree, a beautifully designed and built model. Have you designed other models too, Mitja? You seem like an experienced builder/designer.
Steve
Redbaron25 is offline Find More Posts by Redbaron25
Old Jul 07, 2006, 11:15 AM
Erk is offline
Erk
Find More Posts by Erk
Erk
All thumbs, no scents
Erk's Avatar
Vallejo CA
Joined Nov 2005
Wow! What a pretty fishy!
The rubber band gluing fixture is ingenious! I've only seen that used for guitar repairs; never thought it would work for models!
Are kits available?
Erik
Erk is offline Find More Posts by Erk
Old Jul 07, 2006, 12:49 PM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Steve
I enjoy designing, building and flying my ow models. Well, I must admit, that somethimes I get inspiration for my designs on the other models, but I never make copies.
Some of my designs:
F5J-400 sailplane with 118" wingspan (3m) season 2004
F5J sailplane for season 2005
video of climbing with Mega ACn16/15/3: http://www.rcpics.net/view_single.php?medid=62988
My little green beast, sport model:
And many more.... will show them by time...
Maybe you should visit my homepage: MS-UL Design to see more about me and my designs.
ultralajt is offline Find More Posts by ultralajt
Old Jul 07, 2006, 12:55 PM
ultralajt's Avatar
Joined Sep 2004
Are kits available?
Erik
Yes, the kits are available. The production of the KITs take over one of my friends who also own a hobby shop.
But I dont know if he will be willing to send the kits by post abroad, and how will this affect on the end price for the customer.
Prototype KIT.
Well who knows, if will be the interes for this sailplane, maybe we will send it around the globe. Everything is possible!
Regards!
Mitja
Old Jul 09, 2006, 03:42 PM
ultralajt's Avatar
Joined Sep 2004
Today was a great day for flying!
Old Jul 10, 2006, 01:11 AM
orck is offline
Find More Posts by orck
Joined Aug 2004
congratulations, you have done a great work here
i cannot find the blueprints for the normal edition of guppy
orck is offline Find More Posts by orck
Old Jul 10, 2006, 03:16 AM
ultralajt's Avatar
Joined Sep 2004
I will put the link to the GUPPY plans soon here!
Mitja
Old Jul 12, 2006, 09:53 AM
ADSO is offline
Find More Posts by ADSO
Bologna - Italy
Joined Aug 2005
Great Job
I like the way you make the balsa pod, can you please post some more photos of construction?
Ciao
Maurizio
ADSO is offline Find More Posts by ADSO
Old Jul 13, 2006, 02:02 AM
ultralajt's Avatar
Joined Sep 2004
Originally Posted by ADSO
Great Job
Ciao
Maurizio
If you look at the page 1, you can find some pictures of the fuselage.
Fuselage is build in two separated parts (pod and boom) and they are joined together somwhere in the middle of the manufacturing process.
The rear part (boom) is build around a carbon tube. The balsa strips are glued on top, bottom and sides of the tube. Latter, this boom is sanded to elliptical cross section.
The front part is builded like a box with triangle balsa on the inside corners. This triangular balsa allow that outside shape can be "shaved" down to elliptic cross section.
But before one start to shape outside surfaces, the boom and pod are glued together. I use kind of expandable polyurethane glue to make this joint. It fills up all gaps, and sands well.
The bottom side of the fuselage is laminated from 4 layers of 2mm balsa, with help of "mold" made from styrofoam.
Main components for the forward part of the fuselage are bottom and two sidewalls.
Detail of the cockpit. Triangular balsa is visible here. Note the grain direction!
(this photo is courtesy of Rupert, one of the builders of Guppy)
Joining the both fuselage parts. It is a good idea here to use fuselage drawing as a guide, to poroperly adjust both parts, coz if not, the angle of attack of wing and tail can go wrong! Note the rear one wing mounting plywood, with thread reinforced with CA glue!
Old Jul 13, 2006, 02:10 AM
ultralajt's Avatar
Joined Sep 2004
The KIT made on CNC Laser cutting machine is already in production!
I also made some additional drawings for the building of the Guppy from the KIT, because some parts are slightly different than if one build it from scratch.
In KIT version, some tail members are designed to lock between each other, so the building process is fast and accurate without necessary measurements and adjusting the parts.
Old Jul 13, 2006, 02:51 AM
ultralajt's Avatar
Joined Sep 2004
More pictures of KIT:
Old Jul 13, 2006, 04:20 AM
ADSO is offline
Bologna - Italy
Joined Aug 2005
So you don't use any kind of jig to assembled the pod? only the drawing as a reference? triangle stock are glued to the sides and then the sides to the bottom?
Excuse my silly questions but i'm a newby.
Ciao
Maurizio
Old Jul 13, 2006, 06:24 AM
ultralajt's Avatar
Joined Sep 2004
No, you dont need any special jigs. You need a straight working surface only. It could bee a workbencha or a woden board.
The rear part of fuselage is assembled laying on its side on the bench or board, so it is straight, when finished.
The front part is glued in two phases. First we glue the sidewalls and bottom (laminated bottom) at their straight forvard section. We also glue the front plywood rib in between fuselage sides and all balsa nose sections.
When glue is dry, we glue rear tapered part of fuselage and also glue in the rear plywood rib. I clamp this rear part while gluing, with many rubber bands and some self adhesive tape.
When glue is dry, we insert and glue all triangular balsa in the corners.
Now we join pod and boom parts of fuselage together, but now we must assure, that they are glued straight...we dont want a curved centerline of the fuselage. It should be straight.
We can fix our fuselage on the board by rubber bands or adhesive tape, and put some audio casettes to support a boom and assure the straightness of complete fuselage.
If we fail just a bit, we can still save our work, by sanding the fin upper part where horizontal tail will be mounted, to achieve proper difference between tail and winga AOA. We can use plans for evaluating the AOA, just by putting the fuselage to lay sideward on the plans, with wing saddle laying excatly over the plans. And observing the direction of horizontal tail saddle line...and correcting it if needed.
Regards!
Mitja
Old Jul 14, 2006, 02:42 AM
ultralajt's Avatar
Joined Sep 2004
GUPPY PLANS FREE TO DOWNLOAD:
PLANS:
http://p-chan.prkoritu.net/rc/src/11...15.pdf.unknown
INSTRUCTIONS:
Instructions not yet in English, but many pictures tell also about assembly
I suggest to use one of Tiled print free software for printing this large plan (scale 1:1) to separate papers and glued them together.
Discussion Queen Bee (flying wing) as an electric sailplane? Daneel Flying Wings 4 Jul 22, 2006 12:21 PM
Electric Sailplane flying in MO rchawks Electric Sailplanes 3 Jul 25, 2005 09:21 AM
Nothing like electric sailplane flying... soholingo Electric Sailplanes 31 Dec 05, 2004 07:03 PM
Building and flying a Guppy.... Arbo Parkflyers 147 Nov 21, 2004 06:46 PM
