Old Jul 05, 2006, 09:44 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
Help me design a small fast wing
I've got a few design questions I hope you can help me with. Please bear with me if I ask a stupid question... I'm still learning . I would like to build a very fast and small low drag e-powered flying wing (i.e. break 100 mph under 20 amps ). I plan to power it with a Razor 400 or custom wound high Kv outrunner with TP1320 batteries. I have a hot wire cutter and have cut a few wings so cutting cores should not be too difficult. Oh, and the wing will be made from epp or eps, covered with henry tape and ultracoat.
First question. What airfoil would you suggest? My fastest wing right now (96 mph @ 23 amps) is a 30" wing with a hybrid airfoil of an SD-7032 top and SD-6060 bottom. I think it might be too draggy for really high speed. Searching around I've found that the MH-43 is a pretty popular foil for F5D wings. Would it be suitable to a tailess design? The Rafi #30 foil has been suggested but my google ended empty handed. Does anyone know where I can find this foil?
2nd q. How much sweep should I design into the wing? I'm not completely sure what effects sweep has? I think in increases drag during turns (bad) but also increases stability (good). Is a plank wing going to be the fastest? I'm not sure I'm comfortable with a plank (I have zero experience in that arena). What are the effects to flight when comparing sweep at the LE to sweep at the TE (deep V vs. delta wing)?
Also, what wingspan should I shoot for? I'm thinking 24". Anyone flying a wing smaller then that at over 100 mph?
What else should I be thinking about?
jfinch is offline Find More Posts by jfinch
Old Jul 05, 2006, 11:10 PM
I'm Rick James is offline
Find More Posts by I'm Rick James
Nucking Futs
I'm Rick James's Avatar
Southern Killafornia
Joined Jan 2005
I'm guessing the electric forum or the flying wing forum would be a good spot for this thread.
Sorry I can't help you more.
RJ
I'm Rick James is offline Find More Posts by I'm Rick James
Old Jul 05, 2006, 11:49 PM
jfinch is offline
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
If anyone knows airfoils and wing design I'd think it would be you guys. I'm asking in the flying wing forum too though .
Old Jul 06, 2006, 12:05 AM
THUREN is offline
Find More Posts by THUREN
blah...
THUREN's Avatar
United States, OR, Bend
Joined Jun 2005
Get THIS , chop the center out making the span you want, slap a motor on an pin it...
I bet it would haul!
THUREN is offline Find More Posts by THUREN
Old Jul 06, 2006, 12:34 AM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
If you can find a "Wedgie" they haul with a lipoly and an outrunner. A friend of mine carbon bagged one and it screams.
slopemeno is offline Find More Posts by slopemeno
Old Jul 06, 2006, 01:12 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
The PW51 foil, is a good fast foil for a plank. We have had our Drongo up to 132mph using the PW51.
Glenn
ZIPPER is offline Find More Posts by ZIPPER
Old Mar 11, 2007, 01:02 PM
Jeffrito is offline
Find More Posts by Jeffrito
sloper dude
Jeffrito's Avatar
L'Étoile du Nord
Joined Jan 2005
Here's what you want to start with; an Aeromod Passaj.
The Passaj, like all Aeromod designs, is molded (in this case fiberglass) in a female mold over high-density foam. Not only is this the fastest wing around, but it's as tough as a bagged wing. Electrifying it shouldn't be very hard, but it would do 100 mph on the slope, without motor power. The wing separates for access to the electronics. Price is about $150 + shipping, and it's far less work to put together than a foamie.
Jeff
Jeffrito is offline Find More Posts by Jeffrito
Old Mar 11, 2007, 01:43 PM
flyboyjimi is offline
Find More Posts by flyboyjimi
The sky is my playground
flyboyjimi's Avatar
Near the Ocean in Hunt. Beach Calif.
Joined Apr 2006
I took a scrappy from WW and put a hacker B20 brushless motor with a ten amp speed controller on it and Mr Chang up on Fairview hill in Costa Mesa used to clock me regurlarly at 95 mph this was very shallow dive but the thing was just about maxed out I tried 4 by 3 prop and that seemed to do the best overall changing the pitch and length either made it faster or more power I used a 3 cell 1500 battery and the most amps I could get before it heating up was around eight good luck from a HACKY flyer in H.B. Jim
flyboyjimi is offline Find More Posts by flyboyjimi
Old Mar 11, 2007, 01:46 PM
flyboyjimi's Avatar
Joined Apr 2006
And by the way the scrappy is a foam wing with little carbon flat strips located throughtout the wing and the length is 25 inches hope this helps Jimmy in H.B.
Help! Help me design a cheap and simple wing for a club gliding competition RobinBennett Flying Wings 27 Jun 12, 2006 07:25 PM
Help me design a fast Li-Po Projeti zorro Foamies (Kits) 43 Feb 19, 2004 04:52 PM
Help me choose a DLG flying wing? Aten W Arthog Hand Launch 7 Jul 28, 2003 01:07 PM
Help me design my new workshop.... Steve McBride The Builders Workshop 0 Oct 03, 2002 10:22 AM
Help me design an aerial photography foamie cincyfler Foamies (Kits) 3 Aug 09, 2002 08:58 AM
