Old Jul 03, 2006, 10:28 PM
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
Thomas W. Massey (Zwarte Zee)
Hey guys here is the build up of my Zwarte Zee. I could still use some help here and there as I posted in my other thread, please take a look, as I am new to this type of boat model.
Here is my "Drydock" it also doubles as a kitchen table every now and then.
Prop and rudder assembly as per the kit instructions. This area I am going to mod so I can remove the rudder for maintanence, but for now it is kit stock.
Test fitting the decks.
Close up of the motor installed.
Any comments or suggestions please feel free to ask. If you see in these pics something I can do better or and idea you may have please tell me.
Massey is offline Find More Posts by Massey
Old Jul 04, 2006, 09:09 AM
wingnut163's Avatar
Newburgh New York
Joined May 2005
nice work. looks like you have things under control.
wingnut163 is offline Find More Posts by wingnut163
Old Jul 04, 2006, 09:50 AM
Swieqi Malta
Joined Nov 2005
Hello Massey
I believe the motor I see in the picture is not suitable for this model of a sea going vessel. It revs too much.
You need a low RPM motor with high torque. You need a 7 or more pole motor. The motor you have will draw a lot of current, in conjunction with the propeller I seen in the picture.
This means. It will get very hot and you ESC might also suffer from this consequence.
Just for the record high RPM motors work well on 2 bladed propellers. 3 or more bladed propellers need torque motors not high revs.
Hope this info helps
PS: very nice work keep it up.
Stephen
shipcollector5 is offline Find More Posts by shipcollector5
Old Jul 04, 2006, 11:10 AM
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
If you gear down the motor to 2 or 3/1 motor to propeller the the motor you are using might be ok.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jul 04, 2006, 01:34 PM
McAlester
Joined Nov 2004
Massey,
I'm afraid I have to agree about the motor. I haven't built the 'Zee', but did one close to it. Used an old drill motor I happened to have. With the stock prop it would almost plane, sort of. Makes for one @#$$ of a wake though! Also used a 6 volt gellcell about center of the hull. Not exactly the 'best' choice, but another of "what I had" things. Install before the deck! (The only way to ever get it out is by sending the boat to the scrapyard, sigh.) Your idea about the rudder keel is a good one. Beats breaking the keel loose and then regluing it. A hatch above the rudder is also very handy!
Wish my first one looked as good, keep it up.
- 'Doc
LtDoc is offline Find More Posts by LtDoc
Old Jul 04, 2006, 01:40 PM
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
Thanks for the advise guys. I know alot about this type of motor I use them to race my R/C cars. THe LHSs in my area say this will be fine ungeared but I have my reservations about it. Are there 7 pole motors out there that will fit a 540/550 motor mount?
On a side note I have decided to totaly redesign the rudder linkages. In the pics you can see what Billings uses for a rudder control arm. I didnt like this setup cause it was comming lose alot while I was messing around with the boat. I would not want that to come loose as the bow is facing away from me on a large lake. I will post pics of my progress as I make it.
Thanks again
Old Jul 04, 2006, 02:15 PM
Swieqi Malta
Joined Nov 2005
Thanks again
Hi Massey
I purchase my 7 pole motors from MODEL MOTORS DIRECT UK (Mr. A.J.Graham Keepers Cottage, Home Farm Iwerne Minster, Dorset DT11 8LB Tel 01747812440 (between 9-10am English time) Twin pack cost 24.00 sterling this includes postage to Europe. (He is only a mail order person , no email no web site)
They are excellent quality 6-12v 5000rpm max twin roller bearings skewed wound. See them in the picture. Last but not least that will fit perfectly in a 540 motor mount.
Stephen
Old Jul 04, 2006, 08:52 PM
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
UPDATE: (pics tomorrow tho)
I have just built and installed the radio box and also built a battery box. The rudder servo is mounted and so far every thing looks good. I suspended the servo and the radio box from the 2 braces that run from bow to stern so that if the ship does take in any water it will not sit inside the radio box. Also this allows me to place ballast low in the hull when it comes time to ballast for an accurate water line. (it feels like it is going to need at least a pound of lead or some other heavy stuff)
As for the motor does any one reading this know where i can aquire a 7 pole motor here in the US or from a place that has a website? Calling out of country is not that great of an idea on a cell (the only type of phone I have). I dont mind purchasing from overseas I just need some way other than by phone. Hopefuly if all goes well with the rudder I will be gluing the decks in place tomorrow. (yes I will put pics up). Thanks again for the inputs and I look forward to more. I will also soon post pics of my 2 Victoria sailboats.
Massey
Old Jul 04, 2006, 10:42 PM
Boats on the brain!!
green-boat's Avatar
Arnold, Mo.
Joined Jul 2005
Here is one place for motors http://www.harbormodels.com/Harborma...m18-motors.htm
and another http://www.loyalhannadockyard.com/ look under motors.
green-boat is offline Find More Posts by green-boat
Old Jul 04, 2006, 11:27 PM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Besides what green-boat posted there is also:
http://www.mackproductsrc.com/index.htm
http://www.shipsnthings.com/indexNS.htm
Look at this site for Hughey geardrives:
http://www.drcwebservices.com/ffe/hardware.htm
Kmot is offline Find More Posts by Kmot
Old Jul 05, 2006, 01:47 PM
r/c ships and workboats
bellingham, wa
Joined May 2006
Looking good so far. Looks like the hull is of styrene plastic. I would recomend that you rough up the plastic a bit before you glue anything to it. Would also recomend sealing the beams and underside of the deck and any other structures that comein contact with the styrene with epoxy to help with adheasion proctection in the long run from moisture. I prefer to build up a "dam" behind the shaft tubes and fill the area in with epoxy/filler mix to help reduce shaft vibration and firm up the keel/ hull in that area (seals the the shaft/hull opening as well).
I agree with the others on choice of motor-- not the best for this application. LHS have good references for going fast but rarely for scale boats ( not as big of market). They will sell what they "think" will work. Not really their fault as they do not know there IS a difference.
Keep up the good work as we are all watching to see how this turns out.
keith S is offline Find More Posts by keith S
Old Jul 05, 2006, 03:26 PM
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
Thanks again for the inputs on my boat. I bought a mabuchi(sp sry) 540 fan cooled motor today to give the boat its sea trials in. I am talking sea trials and I have not even put the decks on yet sheesh I need not get ahead of myself here. What I can give you guys is the pics I promised last night so here they are.
Radio box looking forward into the battery tray.
View from Aft looking forward. You can see the servo mounted in this pic. I will put a better shot up once I get the rudder done.
Another angle of the battery and radio box.
Here is a close up of the radio box and you can also see my electronics in this pic.
I am planning on putting a few lights in the cabbins and running lights too. I cant remember what side the red and green go on but I am sure I can find out. I am a long ways off from that step but I will need to make a little tray for that battery pack as well. As always comments are appreciated and you guys are really helping me out on this project. Thank you
Massey
Old Jul 05, 2006, 04:02 PM
Sweden, Gothenburg
Joined Aug 2005
Green on right side and red on left, nice work with that Dutch tug!
Cheers Jack
viggen65 is offline Find More Posts by viggen65
Old Jul 05, 2006, 04:23 PM
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
You are on the way!
One thing you may want to do before going to far is to seal the internal wood parts before sealing her up. This will keep moisture out of the frames and the underside of the deck and house.
Another thing you may want to do is to remove some of the material in front of the prop so that the prop may get more water to it. You don't have to remove a lot, maybe just 3mm from each side.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Jul 05, 2006, 08:31 PM
Drydock Captian
Massey's Avatar
Spanaway, WA
Joined Jul 2006
Sealing the wood
I was planning on sealing the wood with a sanding sealer that I used to use on my model rockets. Will this be good for the inside of the hull's wood too or should I use like a deck sealer or resin? I live in an apartment and dont have access to a shop so fumes are a big deal here. Also what do you guys that have built a few of these use to keep your deck marks for stancions and what not visable when you paint the model? I am planning on making my decks have Nonskid like look to them and not the wood paneling that the original had. Also is a rattle can type paint going to be good enough for the red and black on the hull? I have an airbrush and compressor but that will take me forever to paint the hull with and make it look good. Again alot of this stuff I am new to still and not sure what the norm is. Thanks in advance
Massey
Nemesis 3D Build up! Martin Hunter Parkflyers 524 Jul 15, 2003 11:27 PM
What matrial should I use to build up a fuse??? basicman Scale Electric Planes 0 Apr 25, 2003 02:20 PM
Questions regarding Todds Tiny build-up compuatic Parkflyers 1 Jul 03, 2002 09:14 AM
symmetrical wing build- up VNe Power Systems 14 Sep 09, 2001 02:08 PM
