Old May 18, 2001, 11:35 AM
cruzomatic is offline
Find More Posts by cruzomatic
San Antonio, Texas USA
Joined Feb 2001
broken wing dowel, any suggestions
In moving from Dallas to San Antonio, one of my rear-wing rubberband dowels mysteriously broke on my miss2. Any suggestions on a repair? Would epoxy stand up to the strain the rubberbands put on it? Can I fly it with only the criss-cross rubberbands? Thanks, Cruzomatic
cruzomatic is offline Find More Posts by cruzomatic
Old May 18, 2001, 01:15 PM
dommi is offline
Find More Posts by dommi
Oxfordshire, UK.
Joined Nov 1999
Dont repair it, remove what is left of the whole dowel, you can try flushing off what is left of the dowel either side of the fuz and carefully drilling a slightly smaller size than the dowel dia. into centre of the dowel just thro the fuz, then break out what is left in the fuz sides, this way you may retain same size dowel, then fix it with your
favourite glue, some people dont glue them in
just a tight fit, that would have saved you a lot of trouble replacing your broken one.
all the best. Mike.
dommi is offline Find More Posts by dommi
Old May 18, 2001, 01:23 PM
BillH is offline
Find More Posts by BillH
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
replace the dowel
BillH is offline Find More Posts by BillH
Old May 18, 2001, 03:06 PM
Dick Huang is offline
Find More Posts by Dick Huang
Dick Huang's Avatar
Dallas,TX, USA
Joined Mar 1999
Twist the dowl and break the glue joint then remove the broken dowl and install a new one.Lightly glue in a new one such that it can be removed quickly. The strength is not in the glue joint but the dowl; use glue to keep it from sliding out.
Yours,
Dick Huang
Dick Huang is offline Find More Posts by Dick Huang
Old May 19, 2001, 12:31 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Cut off old dowel flush with fuselage, drill new hole next to old dowel, insert new dowel and glue to old dowel and fuselage sides.
E-Challenged is online now Find More Posts by E-Challenged
Old May 19, 2001, 12:42 AM
Sluf7 is offline
Find More Posts by Sluf7
Sluf7's Avatar
New Zealand, Taranaki, Midhirst
Joined Feb 1999
Nah re drill it and put in larger dowel with epoxy or pva.
Sluf7
Sluf7 is offline Find More Posts by Sluf7
Old May 19, 2001, 05:29 PM
Jim Ryan is offline
Find More Posts by Jim Ryan
Jim Ryan's Avatar
Cincinnati, OH USA
Joined Oct 2000
IMO, the best way to remove broken wing dowels is to bore the broken dowel out with a piece of sharpened brass tubing the same diameter as the dowel. This way you don't have problems with a normal twist drill trying to "walk" off-center, and you get a nice smooth hole that's ready for the replacement dowel.
Jim
Jim Ryan is offline Find More Posts by Jim Ryan
Old May 20, 2001, 12:53 AM
Joined Feb 2001
Fixed thanks, Cruz
Discussion Getting ready to make a wing, any suggestions? Bohh33 Hand Launch 4 Jan 31, 2007 10:17 AM
Discussion ~80mph wing + motor combos - Any Suggestions? freedomflyer Flying Wings 58 Oct 19, 2006 08:02 PM
Discussion twitchy wing.......any suggestions? randall1959 Flying Wings 31 May 01, 2006 11:53 AM
Cutting Wing Ribs - Any Suggestions? fliir Parkflyers 8 Feb 24, 2002 07:36 PM
