Old May 13, 2001, 01:51 PM
tony houk is offline
Find More Posts by tony houk
north charleston,s.c., usa
Joined Apr 2001
f-14 center of gravity verus center of lift
i read something a while back that if a plane had variable swept wings that to make it aerodynamically stable in flight the center of gravity would have to move with the wing sweep. in my thinking i thought that having the center of gravity stay forward of the center of lift would cause it to be more stable in the sweept back wing position. any help would be appreciated. thanks. tony
tony houk is offline Find More Posts by tony houk
Old May 13, 2001, 04:25 PM
cwatters is offline
Find More Posts by cwatters
Somewhere in England
Joined Apr 2001
>.. in my thinking i thought that having the
Yes but it's possible to have too much of a good thing. "Most" planes fly best with the COG as far back as stability will allow. The further forward the COG the more downforce the tail has to generate (=more drag)... and the wing has to compensate by producing more lift (=more drag again). A rearward COG also helps with manoeuvreability.
cwatters is offline Find More Posts by cwatters
Old May 13, 2001, 06:53 PM
Doc Watson is offline
Find More Posts by Doc Watson
Doc Watson's Avatar
UK
Joined Mar 2000
Tony,
The 'real' F14 compensates for wing movement by pumping fuel into forward and aft fuel tanks. Models can be designed to fly with a 'fixed' CG position, goto www.wemotec.com and check out the Chris Golds Tornado which is an electric EDF swing wing model. I think the plans are avalible through Traplet publications.
Doc
Doc Watson is offline Find More Posts by Doc Watson
Old May 14, 2001, 01:46 AM
Troy is offline
Find More Posts by Troy
Caution:Makes sharp left turns
Troy's Avatar
United States, CA, Lake Forest
Joined Feb 1999
I couldn't find Chris Gold's Tornado on the Wemotec site??
Troy is offline Find More Posts by Troy
Old May 14, 2001, 06:05 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
That's too bad, it used to be there. I also have dreamed about making a swing wing F-14. It seems to me that the CG should move with the wings to get everything in balance. Cwatters explained it the way I think it should be. I also think that if you're up to making a model with such advanced features as Swing Wings, the CG movement to coincide with wing sweep should be now big deal. I'd do a cheap, lookalike styro glider at first to get things worked out. Take it up to a slope and try it with the wings in both configurations. Once you get that to fly reliably and get the CG figured out , then move on to your scale project. Just my opinions on the way I'd try it. Be sure to let us all know how yours works out.
GregG is offline Find More Posts by GregG
Old May 14, 2001, 01:48 PM
francois is offline
Find More Posts by francois
francois's Avatar
Irvine, CA USA
Joined Dec 2000
Doc is absolutely correct, the F-14 pumps fuel aft to deal with the aft CP shift. Also if you ever look at pictures of the F14 in a fully swept configuration at supersonic speeds these little canards pop out of the wing glove box just ahead of the wing pivot. These little areas help move the Cp foward as at transonic and supersonic speeds the Cp moves aft.
Hmnn a swing wing ducted fan....too many projects already :P
-Bernard
francois is offline Find More Posts by francois
Center of gravity byebyeplane Beginner Training Area (Aircraft-Electric) 20 Jun 03, 2008 03:13 PM
KC/EJF F-18 ARF Center of Gravity location Ed Waldrep Electric Ducted Fan Jet Talk 2 Oct 07, 2002 10:50 PM
Center of Gravity cenman Electric Plane Talk 4 Jul 17, 2001 08:35 AM
What is the center of gravity for the IFO? spy0o7 Electric Plane Talk 3 Jun 20, 2001 10:02 AM
How do you determine the Center of Gravity?? Dandi6065 Parkflyers 8 May 07, 2001 04:44 PM
