Old May 12, 2001, 07:46 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
how much current while charging Transmitter
I saw a nifty plug for charging the transmitter from my flight pack charger. This would save time over the trickle charger or taking the pack out to charge.
How much current is safe while charging the transmitter pack inside the transmitter ?
Al
Al P is offline Find More Posts by Al P
Old May 12, 2001, 08:21 AM
Ron Cichowski is offline
Find More Posts by Ron Cichowski
Old Guy
Ron Cichowski's Avatar
Carver, MA USA
Joined Jun 2000
C/1 is safe as long as you have some sort of peak detection shutdown. (e.g. 600mah pack at .6 amp) A number of commercial units will boost TX pack at 1.0A with peak shut down.
Ron
Ron Cichowski is offline Find More Posts by Ron Cichowski
Old May 13, 2001, 02:18 AM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
It's all depends on which kind of battery and wires in the tranny. Also, some tranny has a diode in series with the battery to prevent reverse charge apply to the cells.For most peak detection chargers, they need to "see" the real voltage of the battery. You will need to bypass(shorted) the diode for the charger to see the voltage. If you have good cells in the tranny, 2-3C rate should be ok. Most of the tranny battery is going through the switch., You don't want to pass too much current through the switch and damage the contacts.
Brian
bhchan is offline Find More Posts by bhchan
Old May 13, 2001, 11:57 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
1A is usually the maximum current to charge a transmitter battery. Jurgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
How much current can I get from Radio shack 8 cell 1600 mah Nimh The Other Dave Power Systems 4 May 02, 2008 03:25 PM
Panasonic Li ion how much current? Neil McGrath Power Systems 0 May 14, 2002 09:39 AM
How much current do you get from your Li-Ions? ETKing Parkflyers 16 Jan 31, 2002 08:35 PM
How much current fron AA NiMH ? Orion1 Beginner Training Area (Aircraft-Electric) 15 Jan 12, 2002 09:55 AM
How much current does your elmn draw yjin Electric Heli Talk 3 May 08, 2001 11:35 PM
