Old Jun 29, 2006, 05:32 PM
funkenstein is offline
Find More Posts by funkenstein
Joined Jun 2006
best choice of Lipo Battery -help please
could i please have some recommendations of the best Lipo battery to buy with the following setup:
model: 40inch WS wattage stuka
Brushless Motor:
Operating Voltage 11.1V, 8-22A
KV 920
weight 82g
size L40.5xW(motor diam)29.2mm
Shaft 3mm (DIA)X11.00mm (L)
Li-po 3 lipo
propellor 11x5.5, 10x5
Speed controller:
Continuous current limit 30A
Maximum current limit 40A (within 5 second)
Input voltage from 7.2V to 12V
Suitable for Nicd, NiMH and Lipo batteries
Can be programmed to switch the brake ON / OFF
Number of FET = 15 pieces
High rate PWM 8K
Auto Timing
High Current BEC
Self-adjusting throttle range
also what sort of flight times could i expect from the best choice of Lipo?
any advice gratefully recieved.
funkenstein is offline Find More Posts by funkenstein
Old Jun 30, 2006, 04:25 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
You probably need a 2000-2200 pack. That wil be a good balance beween duration and weight, and won't be overstressed if you keep currents below 20A.
This is a very popular size, and there are some remarkably good packs at this capacity going for very keen prices if you avoid the major brands (too expensive) or the real junk (buy from smaller vendors who have a reputation to lose) Also by keeping current down to less than 10C most packs will perform adequately.
Althought at full throttle on the griund the pack will run out in about 6 minutes, in the air at reduced throttle settings, you are likely to get around 20 minutes unless you induklge in full power dive bombing runs all the tme.
Old Jun 30, 2006, 06:35 AM
Joined Jun 2006
thanks vintage1 that's really helpful.
20mins in the air will be awesome! i'll start looking at 2200 packs, as you say there are some pretty competitive deals out there at the moment, shouldn't stress the bank balance too badly...
Old Jun 30, 2006, 07:09 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
FWIW, I think 12-14 min of normal flying would be closer to what you might expect.
hoppy is offline Find More Posts by hoppy
Old Jun 30, 2006, 08:01 AM
Joined Jun 2006
12-14 mins is still a pretty good time in the air. should do me fine
Old Jul 01, 2006, 02:18 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
ALOT dpends on the type of plane. On my light scale/vinatge type stuff there is no way I CAN run at full throttle or the model is a speck! The warbird types eat up more because they are good for blistering low speed passes and great screaming climbs ..and large loops..
So if its aerobatics, yes, flight time comes down. If its a trainer, its liklely you will get what I said.
Best brand of Lipo battery? flierbk Batteries and Chargers 31 Nov 16, 2007 02:11 PM
Lipo Battery Help please falcon65 Beginner Training Area (Aircraft-Electric) 6 Sep 09, 2005 08:08 AM
Help! battery help please! NoamN Electric Plane Talk 20 Feb 18, 2004 12:53 PM
Battery help please Funflier1 Batteries and Chargers 5 Nov 22, 2003 10:01 AM
Zagi Battery Help Please ETKing Foamies (Kits) 2 Dec 21, 2001 03:47 AM
