Old Jun 28, 2006, 06:20 PM
rob10000 is offline
Find More Posts by rob10000
rob10000's Avatar
ARF OV-10 for AP/UAV work
I just stumbled upon this nice design. It's very visable, and seems like it would make a great candidate for AP or an UAV. Twin engine, and plenty of room for the gear in the center fuselage, with a nice, unobstructed view forward.
Here's the specs.
Wing span: 48 in / 1220mm
Wing area: 434 sq in / 28 sq dm
Flying weight: 4.4 lb / 2000g
Fuselage length: 50 in / 1270 mm
Engine Required: 2c 0.15 cu in X2 pcs
Radio Required: 4-5channels,7-9 mini servos
Li-Poly : 11.1V 1300-1600mAh x2 pcs
Propeller:8x6 x2pcs
Out runner Brushless Motor : 400T x2 pcs
Speed Control :15 - 20 Amp x2 pcs
More pictures and specs at
http://www.nitroplanes.com/elbrgasovbrt.html
rob10000 is offline Find More Posts by rob10000
Old Jun 28, 2006, 09:02 PM
Jim Holloman is offline
Find More Posts by Jim Holloman
Joined Aug 2005
In my opinion, it would be too fast and without enough inherent stability. An autopilot could help with the stability problem, but the speed would still be a concern in regard to safety, takeoffs, and landings. Also, a twin motor aircraft is usually more difficult to control than a single motor aircraft. Now, that claim is forever debated by pilots of full size aircraft, but the stats. are revealing. Given the same amount of flight time, you are more likely to die in a light twin than in a single.
Jim Holloman is offline Find More Posts by Jim Holloman
Old Jun 28, 2006, 10:10 PM
Photoship One is offline
Find More Posts by Photoship One
by Alary Design
Photoship One's Avatar
United States, AZ, Mesa
Joined May 2002
a couple things come to mind
1. scale aircraft do NOT make good AP/AV platforms.
2. twin power systems means more vibes to contend with
but it does look like a fun plane and at $129 how can you go wrong!! nice find
Photoship One is offline Find More Posts by Photoship One
Old Jun 28, 2006, 10:17 PM
Real Ira is offline
Find More Posts by Real Ira
Not THAT Ira
Real Ira's Avatar
Coupeville, Wa
Joined Jan 2006
Looks like fun but by the time it is loaded with the nessary gear the wing loading would most likley be quite high and this means speed. For AP sloooow is good,(usualy).
Real Ira is offline Find More Posts by Real Ira
Old Jun 29, 2006, 10:36 AM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
convert it to a single pusher
patrickegan is offline Find More Posts by patrickegan
Old Jun 29, 2006, 10:39 AM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Add some length to each wing and make it dihedral and make it a pusher single and walah!
quailbird is offline Find More Posts by quailbird
Old Jun 29, 2006, 10:42 AM
qualcity is offline
Find More Posts by qualcity
WHOHH..You See That??
qualcity's Avatar
Aurora, Colorado
Joined Jan 2005
Nice idea!
qualcity is offline Find More Posts by qualcity
Old Jun 29, 2006, 11:31 AM
rob10000 is offline
rob10000's Avatar
I found a nice, 12 page thread about this plane, complete with build pictures and flight videos. These guys were building them scale, with pneumatic retracts, and judging by the videos, it performs well.
http://www.rcgroups.com/forums/showthread.php?t=475564
I think this could work!
Discussion Electric OV-10 for FPV scrtsqrl Electric Plane Talk 2 Dec 12, 2006 05:19 AM
Discussion ARF OV-10 for AP/UAV work rob10000 UAV - Unmanned Aerial Vehicles 0 Jun 28, 2006 06:19 PM
Zagi Airframe for AP and UAV keeprighton Aerial Photography 10 Dec 06, 2005 05:43 PM
OV-10 for GWS EPS Drives ben1272 Foamies (Kits) 11 Jan 10, 2004 05:41 PM
OV-10 - Looking for kit or plans. VfrOnly Parkflyers 2 Mar 09, 2003 07:15 PM
