Old Jun 27, 2006, 07:07 PM
Pshaw is offline
Find More Posts by Pshaw
Joined Aug 2005
Is it possible to get over 100mph level speed on this????
I just got a MicroJet and I'm looking for a ballistic speed setup. I realize hand lauching on these things is difficult. But what is the best "semi-realistic" setup for top speed? I was thinking about a mega 3turn.... has anyone tried this setup? Any suggestions? Is 100+ mph possible?
Pshaw is offline Find More Posts by Pshaw
Old Jun 27, 2006, 08:15 PM
rycomm is offline
Find More Posts by rycomm
Flyin' Ryan
USA, MO, Lee's Summit
Joined Sep 2001
I am not an expert, but I don't think it is likely to get a microjet to 100mph, without some mods. A mega 3t or simalr 3000ish kv motor is a good start. I think 4S lipos would be needed to get near 100mph. I think some drag reducing mods would also be needed. Supposedly the Funjet is a cleaner airframe, and I am putting a 3t Mega in it, but only expect 70ish on 3S, maybe less. These are small airframes to get moving that fast, and will be hard to see quickly, they cover a lot of airspace at 100mph.
If you really want 100+, a sokol or other sp400 pylon racer would do it with the mega 3t. These are very well designed airframes built for these kind of speeds. I have never seen one in person, but they look fast in the pictures and videos. I'm sure someone who has done the mods will post, and maybe have had a radar pass.
Ryan
rycomm is offline Find More Posts by rycomm
Old Jun 27, 2006, 08:41 PM
Pshaw is offline
Joined Aug 2005
Hmmm... pylon racers seem cool but I'm on a tight budget. Crap I was hoping I could hit 100mph on a 3 cell! Thanks for the info tho.
Old Jun 27, 2006, 08:51 PM
MustangAce17 is offline
Find More Posts by MustangAce17
EDF Addicted
MustangAce17's Avatar
United States, FL, High Springs
Joined Sep 2005
you should be able to do this quite easily with just carbon and fiberglass reinforcement,look in the flying wing section,theyre getting 100 mph on 2 cells
MustangAce17 is offline Find More Posts by MustangAce17
Old Jun 27, 2006, 08:56 PM
Pshaw is offline
Joined Aug 2005
On a MICROJET?!?!
Old Jun 27, 2006, 09:00 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
Just look in the Stryker threads, everybody in there claims their plane goes 100 MPH
Jim
BrunswickOH is offline Find More Posts by BrunswickOH
Old Jun 27, 2006, 09:58 PM
Pshaw is offline
Joined Aug 2005
Are you saying that if a stryker will do it... then this should?
Old Jun 27, 2006, 10:06 PM
Brunswick, Ohio
Joined Aug 2003
It takes a lot to get up over 100MPH unless you have a really low drag airframe like a hotliner. A small plane like the MicroJet moving at 80MPH is not that hard to achieve and 80 MPH on a little MicroJet is real hard to keep up with.
Jim
Old Jun 27, 2006, 10:21 PM
Pshaw is offline
Joined Aug 2005
Is there any video of a MJ doing 80+ mph???
Old Jun 27, 2006, 10:44 PM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Springfield
Joined Jul 2004
i have not radared mine but with the set up that i have i'm doing close if not just over 100mph.
i switched from running the Astro20 with the mega 3T i'll let you know what i find is the diff. between both of em'.
i would definately reinforce the wings with a solid CF bar,i take turns almost full throttle and it holds very well.
snolord1 is offline Find More Posts by snolord1
Old Jun 27, 2006, 11:29 PM
Jurgen Heilig is offline
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
There have been some tests done, with identical power setups, the Micro-Jet was a few mph faster than the new FunJET. The FunJET with Mpx BL480-4D, 3 Lipos and APC 5x5" was measured at 170km/h - that's 105.7 mph.
Jürgen
Jurgen Heilig is offline Find More Posts by Jurgen Heilig
Old Jun 28, 2006, 12:31 AM
Pshaw is offline
Joined Aug 2005
I've been doing some research on the 450TH and this thing looks like it would SMOKE the mega 3t. What kind of speeds would I be looking at with this?
Also can you ONLY get these from the justgofly.com website?
Old Jun 28, 2006, 01:54 AM
punkindrublik is online now
Find More Posts by punkindrublik
multirotormania.com
punkindrublik's Avatar
United States, CA, North Highlands
Joined Sep 2004
You've got to be kidding. Where did you get that info???
The mega 3 turn can handle 600 watts if ya do it right. The 450DH tops out at 300watts and they recommend you don't even do that
My MicroJet with a Mega 3 turn on 3s with a 4.75x4.75 APC would get reeaaally close to 100mph. With 4s 20c lipos, it was gunned at 120
35 amps on a 14.8 v lipo was drawing a tad over 400 watts.
punkindrublik is online now Find More Posts by punkindrublik
Site Sponsor
Latest blog entry: NEW MRM 130mm FRAMES!
Old Jun 28, 2006, 02:02 AM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
wow,now that's what i'm talking about
Old Jun 28, 2006, 02:06 AM
EDF Addicted
Joined Sep 2005
i went the other way with my microjet when it was flying,APC 7x5,Rimfire,bl-8 esc,and TP 730 and Tanic 1050 and 1500 3 cells,was fun and pretty quick 60 ish but flew foreverrr lol it was fun
Discussion Why use a EDF over a prop? is there any FAQ's on this? rosco Electric Ducted Fan Jet Talk 36 May 29, 2006 08:56 PM
Can I get information on this gray foam jet pusher? himeros Pusher Prop Jet Models 3 Nov 03, 2005 04:23 PM
Question Control the engine speed on electric plane, possible? Tal Aviel Electric Plane Talk 10 Aug 12, 2005 04:03 PM
Gotta get a handle on this HB tail! AirMicro Micro Helis 6 Aug 13, 2003 08:24 PM
Can't get 2100rpm head speed on CP hornet :( sizam Micro Helis 0 Jul 28, 2003 08:31 PM
