All the boats mentioned above are good.
For as close to RTR as possible I would go with Small World Models. Here is a review I did on the SWM Trenchant. http://www.subpirates.com/viewtopic.php?t=171 Cheers BC |
Joined Nov 2004
Hi
Dave Merriman's (D&E Miniatures) 1/96th scale Skipjack with the WTC3 is almost ready to run to the same sort of level as the Blueback and SWM boats. If his catalogue prices are still current the Skipjack hull with linkages set up is about $400 and the WTC3 with Propel ballast system and motor is $360. You have to do the same things to the hull you have to do the SWM kits I believe. Here's a quote from Dave's catalogue: http://www.vabiz.com/d&e/downloads/2...-webformat.pdf Pre-assembled and in primer gray, only two nights work is needed to get it into the water. Control surfaces, fixed ballast weight, buoyant foam, propeller, running gear, instructions, Deep Sea Designs plans, a complete set of masts and antennas, and dry-transfer markings make this the most complete and easily assembled scale R/C submarine kit on the market today. The WTC3 needs: - 4-channel R/C system with two standard servos, - Traxxas speed controller - APC-3/4 angle keeper - SubSafe failsafe - 7 Volt 1500 mAH Ni-Cad battery - battery charger - can of Propel and Propel charging fitting. I have driven a Skipjack BTW and that little sucker is fast in the water and turns like a fighter because of the roll associated with the sail (true to scale) which is both fun and can drive you to the bottom of the pond if you're not careful. Here's a movie of a Skipjack in action at the 05 Subregatta: Click here to watch Skipjack-movie Dave Manley's boats (SWM) look great as well and Skipjack and the SWM kits are about as close to RTR as you will get in this hobby. I personally am building the Subtech Albacore and there is a lot of work to do on the hull and the WTC. If I was doing this again, just to get something in the water straight off, I would have gone for the Skipjack or the Blueback to start off with. Cheers Byron |
USA, OH, cambridge
Joined Sep 2001
II have a Engle Patrick Henry TAES kit for sale. $750 I also have a 1/96 Scale Shipyard Acula kit with a Small World 3.5" wtc w/motor. $400
email me at fgroza@msn.com Frank |
| Thread Tools | |
| Found Looking for a High wing aileron trainer 4 channel Plane kit.............. | mtdoramike | Aircraft - Electric - Airplanes (FS/W) | 11 | Jun 17, 2007 04:43 PM |
| Looking for a 60 Size tucano kit or arf | mitc99kd | Sport Planes | 3 | Oct 27, 2005 12:26 PM |
| Looking for Consolidated B-24 Kit or Plans | planefun | Electric Plane Talk | 8 | Nov 21, 2003 05:39 PM |
| Looking for High Quality Coroplast Zagi Winglets? | 177ichael | Aircraft - Electric - Airplanes (FS/W) | 15 | Jul 31, 2001 11:48 PM |
| Looking for High Quality Coroplast Zagi Winglets? | 177ichael | Foamies (Kits) | 13 | Jul 31, 2001 08:31 PM |
