Old Jun 27, 2006, 02:42 PM
INewton is offline
Find More Posts by INewton
Massachusetts
Joined Jan 2006
dago red-60 E-conversion
This is my first war bird conversion. The ARF kit just arrived by UPS this afternoon. The box is sure big.
The stang has a wing span of 65.2" and a weight of a bit over 8 lbs. It comes with retracts and requires servos for rudder, elevator, flaps, aileron, and retracts - five altogether.
Normally this plane would be flown with a 12x6 prop and .60 2cycle or .91 4-cycle.
I just got some 11x6x4-blade props APC glow (scale size) for my outrunner. The advantage of the 4-blade is that the prop won't mow the lawn on takeoffs. The outrunner would otherwise require a 14x10 prop, which would never fit with retracts and would not looks as cool.
I ordered a BM4230 which is just a bigger sized BM3520 to swing the 4-blade wihout gearing things down. This is not a 3D plane so I'll hold the power to 6S2P or 22V and 60A using 12 emoli cells and a TP65A controller. Eight pounds and 1200W is 150W/lb, which should get the job done. Of the 8 pounds, 3.2 lbs will be batteries and motor. I'm using a 3A switching BEC made from a cell phone charger.
I'm going with S3004 BB servos unless I find I need a higher torque S3010 for perhaps the ailerons since there is only one servo to drive both.
On to step 1 of the assembly instructions...
INewton is offline Find More Posts by INewton
Old Jun 27, 2006, 04:55 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
Is this the plane you are converting?
http://www.rcgroups.com/forums/showthread.php?t=420880
gwh is offline Find More Posts by gwh
Old Jun 28, 2006, 04:34 AM
INewton is offline
Massachusetts
Joined Jan 2006
Yes, that's the plane. It looks much better up close.
Old Jun 28, 2006, 12:52 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Uh the flaps take one servo and the ailerons take 2.
I hope I can use a 16" propellor on this one like my H9 Miss America.
A 4 blade scale prop would be about 20" dia as I recall.
feathermerchant is offline Find More Posts by feathermerchant
Old Jun 28, 2006, 02:36 PM
INewton is offline
Massachusetts
Joined Jan 2006
You are right about the two aileron servos. And the scale prop should be about 4x15" for a 65 inch wing span. Let me check on a 4 blade 15x6 or 15x5 prop (and also check the tip speed on the props for the pitch speed I need)
Old Jun 28, 2006, 03:23 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Best I can tell, the P-51 prop is 10.7ft dia. and wingspan is 37ft.
Then for a 65" model, the prop would be 18.8" dia.
Check my math.
If our model accurately depicts a clipped wing racer ( I cannot remember is Dago or VooDoo is clipped wing) then the prop diameter would be larger.
The Merlin/Packard engines are geared about 2.5 to one so the prop is really huge.
Old Jun 28, 2006, 05:29 PM
INewton is offline
Massachusetts
Joined Jan 2006
Check my math.
I think you're right again. I may just 'live' with a 15.5x12 4-blade APC since I don't want gears. It's close enought.
It's also not going to spin all that fast. I still think I'll be okay with a 4130 motor. I may need to come down to 5S and 60A for around 5,000 peak rpm.
Old Jun 28, 2006, 05:40 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Just got done reading a lengthy history of teh Mustang and teh prop size is about 11ft.
You should just try a 15X10 on 6S. It has been used by many on the similar H9 P-51. ine flis great with it and nothing gets too hot.
I have a Hyperion 4035 that can do 1600-1800W for mine
Old Jun 28, 2006, 06:49 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
It's red
Is this it? If it is, it's red with a 4 blade.
http://media.putfile.com/Its-Red-with-a-4-blade
SCALEFAN is offline Find More Posts by SCALEFAN
Old Jun 28, 2006, 07:20 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Yup this is not actually Dago Red even though that's what the instructions say.
I think it is VooDoo which is purple amoung other things.
Old Jun 29, 2006, 07:32 AM
INewton is offline
Massachusetts
Joined Jan 2006
feather,
You found a 15x10 4-blade... That's better than the 15.5x12 APC 4-blade since I can run at higher RPMs and go back to 6S. Who makes it? Tx
INewt
Old Jun 29, 2006, 07:34 AM
INewton is offline
Massachusetts
Joined Jan 2006
Scale models are getting more and more realistic! There must be a 4-cycle .82 in that baby...
Old Jun 29, 2006, 08:04 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
No No I meant you should try an APC-E 2 blade 15X10. It will probably fly the plane better than any 4 blade you can find. Generally fewer blades are more effecient. The reason that the full scale has a 4 blade is that a 2 blade would be too long.
INewton - as smooth as that was running you can tell it was not about to race. On race day they sound much different.
Old Jun 30, 2006, 05:31 PM
Stregaracer007 is offline
Find More Posts by Stregaracer007
SF Bay Area
Joined Jan 2003
That's Strega. Looks like early '90s paint scheme because no white swooshes towards the tail.
All of them (Voodoo, Dago and Strega) have clipped wings.
They have removed the racing canopy from the current Voodoo. See recent photo attached. How recent? Two weeks ago at Reno.
Stregaracer007 is offline Find More Posts by Stregaracer007
Old Jun 30, 2006, 05:35 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
For scale note the prop is about as tall as the fin.
Looks good too.
Wot- 4 Twister 60 e-conversion leccyflyer Sport Planes 51 Jun 14, 2010 10:25 AM
Article Sig Somethin Extra KIT from KAVAN E-Conversion Review- Torcman vs CC Phoenix 60 Boyko Sasha Glow to Electric Conversions 12 Jan 05, 2008 08:04 AM
New Conversion: Dago Red P-51 DrBill Sport Planes 74 Dec 02, 2006 07:18 PM
Raptor 60 E Conversion MODMAXX4748 Electric Heli Talk 26 Oct 30, 2004 08:52 PM
Covering advice for .60 size E-conversion Rick W Scale Kit/Scratch Built 3 Feb 26, 2002 05:49 PM
