Old Jul 26, 2002, 10:06 PM
KeithLuneau is offline
Find More Posts by KeithLuneau
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
GWS 300C "B", Oil it or not?
Like the subject says, should I oil my GWS gearbox in my Switchback or run it like it is? I have about 10 or 12 flights on it now, without oil. It's starting to make a "vibration" noise at around 1/3 throttle.
KeithLuneau is offline Find More Posts by KeithLuneau
Old Jul 26, 2002, 11:18 PM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Not that this answers whether you "should" or "shouldn't" but I never did, and mine performed flawlessly through 65 flights. When it did die, it was all at once and not gradually over time. Check your prop alignment and balance.
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Jul 26, 2002, 11:52 PM
Jim Winget is offline
Find More Posts by Jim Winget
Mountain View, CA, USA
Joined Nov 2000
A lot depends on the oil you select. You need to be a little careful. Many of the light oils may contain petroleum products that reduce the life of the plastic. There are special purpose oils and greases made for use with plastic gears. I found some in the train department at a local hobby store. Also available are cermanic greases that work well both for plastic and metal.
All that said, I did use a light 3-in-one like oil on a gws gearbox about a year and a half back and I haven't see any ill effects (yet).
It will be interesting to learn what others have found.
Jim
Jim Winget is offline Find More Posts by Jim Winget
Old Jul 27, 2002, 12:44 AM
Joined Jan 2002
Thanks for the replies!
Doug suggested that I check the prop also. Now that I think of it, the noises started when I changed from my APC 9x6 SF to a GWS 9x7, and I was in such a hurry to beat the dark that evening, that I never checked the prop, and today was the first time I flew since then. So I'll try that before the next flight.
On the subject of oils, I used some 3-in-1 on my first DX-A, which contains "petroleum distillates", and never had any problems with the gears, the motor just died of old age.
Thanks again.
Keith
Old Jul 27, 2002, 08:55 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Any wet lubricant will only serve to pick up dirt and dust that will negatively impact performance. I've been using powdered graphite with good success. There are several different dry lubricants that are widely available.
Dave Hederich is offline Find More Posts by Dave Hederich
Discussion 4" Spitfire flies! (believe it or not) rguillot Scratchbuilt Indoor and Micro Models 141 Jan 25, 2007 12:47 PM
To oil or not to oil? olddog Electric Plane Talk 22 Jan 18, 2005 11:43 AM
GWS Dragonfly Main Motor? To Break in or Not? gbagley Micro Helis 6 Oct 30, 2003 08:43 PM
Which is better: GWS 300C 5.33:1 combo or Mpjet 5:1 with s300? Spaulding Parkflyers 10 May 09, 2002 05:35 PM
WTB: EPS-300C-"CS" for GWS Zero cfossa Aircraft - Electric - Airplanes (FS/W) 0 Apr 14, 2002 08:20 AM
