Old Jul 26, 2002, 06:58 PM
NetForce2K is offline
Find More Posts by NetForce2K
Montreal, Canada
Joined Apr 2002
What do you use as a weighted bar for your wing core cutter ?
I'm almost done with the setup of my hands-free wire cutter.
Thanks to y2bnormal and his clear article on the web, that is what I've come up with:
(credit/picture to/from y2bnormal website)
One question I have though is, what should I use as the weighted bar to get the perfect cutting speed ? I've seen numerous size steel bar at the hardware shop but wasn't sure exactly which one to pick.
Could someone let me know what you're using ? Maybe size, lenght, thickness would help as it will be difficult to weight at the HW shop.
Thanks guys !
NetForce2K is offline Find More Posts by NetForce2K
Old Jul 26, 2002, 07:27 PM
Acer is online now
Find More Posts by Acer
Acer's Avatar
Loveland, Colorado
Joined Mar 2000
Looks good. I have a FeatherCut system to cut my Mini SpeedWing cores. It uses a 1 pound lead weight with an eyelet screwed into the top. It is held on the bar with one of those metal paper clip deals (spring clip). you hang it on the swing arm at different distances from the pivot point to adjust your cutting speed. I have mine set at 65% on the swing arm.
You can get 1 pound led weights with the eyelet already installed in sports department stores in the fishing section.
Hope this helps.
-- Acer
Acer is online now Find More Posts by Acer
Question What do you use your 10A brushless speed controller for? glydr Power Systems 10 Mar 03, 2006 05:29 PM
for all you in the north what do you use to keep your hands warm? kushal_22 Electric Plane Talk 42 Dec 11, 2002 10:26 AM
Looking for a small battery connector. What do you use ? RonJ Parkflyers 18 Jul 12, 2002 10:04 PM
What do you use for an end insulator on a foam cutter? AW Power Systems 8 Jun 20, 2001 10:49 PM
