Old Jun 26, 2006, 12:12 PM
wsnowfall is offline
Find More Posts by wsnowfall
Cleveland Ohio
Cleveland Ohio
Joined Jan 2006
delta wing setup
i have a combat wing xe2. i assume a zagi type plane is a plank. there is no nose or tail.
I use a multiplex evo. in their tutorial they talk about elev pitch sensitvity. They recommend full aileron tranvel and 30% elevator travel. The guys at combat wings recommend 5% up elevator to start with.
Does these recommendations sound right? is a zagi type sensitive to elevator? I can also expo on the elev or go to dual rates.
too much info overload in Cleveland
wsnowfall is offline Find More Posts by wsnowfall
Old Jun 26, 2006, 12:20 PM
Riley is offline
Find More Posts by Riley
Joined Jun 2006
I have a Zagi XS and Zagi 60 both with huge brushless and 35 Amp ESC and I use 100% throw on Elev and Aile =1/2" up and down. For pucker factor above 3 I Dual Rate to 60%. Make sure both sides go up and down the same and left and right the same distance. Have seen problems on other folks setup/radio and you will really notice it if you try to do a perfect loop.
Riley is offline Find More Posts by Riley
rotccapt is offline
Find More Posts by rotccapt
that tree ate my plane
rotccapt's Avatar
oklahoma city oklahoma
Joined Apr 2004
that sounds about right. just make sure that you get the cg right
rotccapt is offline Find More Posts by rotccapt
Help! JR XP652 setup for delta wing ?? nakman8 Radios 1 Apr 05, 2006 01:52 PM
Help! JR XP652 setup for delta wing ?? nakman8 Flying Wings 2 Apr 04, 2006 12:06 AM
JR 6102 setup for Stryker(Delta Wing) Mayday!Mayday! Radios 1 Dec 16, 2005 04:46 PM
Delta Wing setup? TooTall Parkflyers 2 Sep 08, 2003 09:07 AM
Will this setup work for Delta Wing? webnetxpress Foamies (Kits) 3 Apr 03, 2003 03:05 AM
