Old Sep 28, 2006, 05:41 PM
mecevans is offline
Find More Posts by mecevans
mecevans's Avatar
United States, CA, Monterey
Joined Feb 2006
i used a 2 mm rod
mecevans is offline Find More Posts by mecevans
Old Sep 28, 2006, 08:20 PM
ghee-grose is offline
Find More Posts by ghee-grose
Honey, I got more planes!
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
Originally Posted by Boeingdvr
Ghee-grose, I couldn't tell if you put a cf rod in the wing? I did on mine and at least that is one part that has not broke
I just looked at the pics I posted and saw I used the stock wood spar. With lots of gorilla glue.
http://www.rcgroups.com/forums/attac...hmentid=877297
ghee-grose is offline Find More Posts by ghee-grose
Old Sep 28, 2006, 08:28 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
pics
just found out that some how my rudder linkage is all glued up or something im gonna try debonder, but heres some pics. the part i hate is the tail it always looks crocked or not fiting good
Old Sep 29, 2006, 12:09 AM
ColinB is offline
Find More Posts by ColinB
Canada, BC, Victoria
Joined Mar 2004
Hi Guys,
I bought a used E-starter, but just can't decide what motor to put in it. It did have a Himax 2015-4100 in a GWS gearbox (that the owner kept) and was flown with 3 cell lipo. I'll be using 8 cell nimh to start off with, and can't decide between the himax and the Bp-12.
The price of the BP-12 sounds great, but I read that you need the voltage from a 3 cell lipo pack to make it really shine. I'll be using 8 cell nimh, so am not sure.
I like the idea of the better quality Himax, but have heard horrible things about their gearbox. I asked the manufacturer about prop savers, and was told not to use one with their offset gearbox - the prop could break the motor shaft. Wow. Made me want to rush out and buy one.
So, I'm at square one. It flys ok with the 300 motor, but I have to pull the esc and receiver out of my Beaver to do it. Since I have to buy a 2nd esc anyway, it may as well be brushless, right?
Suggestions?
Colin
ColinB is offline Find More Posts by ColinB
Old Sep 29, 2006, 08:45 AM
Ranfred Radius is offline
Find More Posts by Ranfred Radius
Ranfred Radius's Avatar
Central Point, OR.
Joined May 2002
A PJS 550 3D outrunner(from Hobby Lobby) 10x4.7 APC prop and TP 1320 3s lipos will give you this performance on your E-Starter!!...
http://video.google.com/videoplay?do...12588367543542
Randy
Ranfred Radius is offline Find More Posts by Ranfred Radius
Old Sep 29, 2006, 08:56 AM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
Colin, the motor and battery you choose will depend on what kind of performance you plan on getting out of your E-Starter. I find that 3 cells on my BP-12 make too much power than what I like for this type of plane. Keep in mind that mine weighs 12oz without a battery. That's pretty light so a 2 cell gives it great performance. I would say about a 1:1 power to weight ratio with my 800mah PolyQuest pack. I'll say this... I can hover it for 5-10 seconds before it wish-washes.
Now if you want your E-Starter to be unlimited vertical (or yours weighs in around 20oz) then you might do better with a 3 cell pack.
Old Sep 29, 2006, 10:49 AM
ColinB is offline
Joined Mar 2004
Thanks guys,
I guess my post was more of a rant - just having a hard time making a final decision.
Too much power? Nah! I'm getting good at throttle management. I don't want to go vertical - just a strong climb to get me out of sticky situations. And I need an esc for the plane anyway, so why not brushless?
I am not going to use lipo batteries; I guess my 8 cell pack is in between the voltage of a 2 and 3 cell lipo, so I'm splitting the difference. I haven't weighed this plane, but I think it is on the heavy side. I guess I should before I decide on things! I'll have to stop by the post office...
Randy, I've come across that video before - I liked it then, and like it now. Wow.
Thanks for your help guys. I'll weigh the plane and decide.
Colin
Old Sep 29, 2006, 04:08 PM
Central Point, OR.
Joined May 2002
Not sure what you are getting at here... Mine weighs at least 20oz., has unlimited vertical and it will land at a snail's pace!
Old Sep 29, 2006, 09:54 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
fixed my pushrod i just ripped the bad one out and there was three inches of glue in there
Old Sep 30, 2006, 09:26 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
maidened today in more wind than usual but it still flew way better than my first one. i made sure that the battery couldent come out with tape,tissue and,rubberbands. i got a pretty long flight out of it mabe 15 or more min with battery to spare , i ended up hitting a batters cage on landing and only the window part broke
Old Sep 30, 2006, 10:59 PM
pamtri is offline
Find More Posts by pamtri
USA, PA, Philadelphia
Joined Jun 2005
Colin,
Not sure I understand the issue with the HiMax gear box and prop savers. I've been using the Himax 2015-4100 with a 1060 prop and prop-saver on a Slow Stick (Pulls 6 amps, goes vertical on 10C 3-Cell lipo)
The prop saver works great. If you crash hard enough you'll break a gear, put they're inexpensive and real easy to replace (ask me how I know...).
I've sheared off the first ten inches of fuselage, but the original HiMax Motor shaft still spins true (It was easy enough to pull out and put back in to check)
Ghee-Grose, what's the deal with Gorilla Glue? Should I get rid of my 5-min epoxy?
pamtri is offline Find More Posts by pamtri
Old Oct 01, 2006, 12:03 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Gorilla Glue is a great glue for foamies, it seems to penetrate the foam better than epoxy does..
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Oct 01, 2006, 12:46 AM
ColinB is offline
Joined Mar 2004
Hi Pamtri,
About the Himax gearbox and prop savers: I was surprised as you were. Heres the response I got from Himax:
Please do not use a prop saver with the offset gearbox, if a prop tilts for any reason and hits the motor shaft it will snap motor shaft right off.
gearbox spec sheet : http://www.maxxprod.com/pdf/HG20xx-xx66.pdf
Travis
- ColinB <...@hotmail.com> wrote:
- Good morning,
- Could you tell me which prop saver would fit on the ACC3966
- gearbox? The specs are not clear to me - does the gearbox
- have a 2mm smooth shaft where the prop adapter or prop
- saver would be mounted?
- Thank you for your time,
- ColinB
Which prop saver did you use? The type where the screws contact the drive shaft to hold it on? Or is your drive shaft threaded, and you can just bolt on a servo arm? (which is what I've done on my Beaver. Works great.)
Anyway, I'm looking for someone with a scale to weigh the E-Starter, to help decide which motor to go with.
Can anyone try their 2015-4100 or BP-12 motor with an 8 cell nimh, 700mah(ish) and compare power to their usual lipo? I know batteries are all different, but it may be interesting. I won't go lipo just yet (until I get a safer place to store and charge them.)
Thanks, and happy flying this weekend!
Colin
Old Oct 01, 2006, 03:59 AM
DarkHorse is offline
Find More Posts by DarkHorse
0 Carbon fp? don't breed!
DarkHorse's Avatar
www.dhrc.rchomepage.com Gloucester/Cheltenham Gloucester, Great Britain (UK)
mecevans, the damage doesn't look too bad.
I had to search a couple of your pics...
there is an E-starter is in all of them .
DarkHorse is offline Find More Posts by DarkHorse
Old Oct 01, 2006, 07:34 AM
dellavex is offline
Find More Posts by dellavex
Evansville Indiana
Joined Aug 2006
Just bought my first estarter, and it's my first time assmeblying one also......so far so good. I do have a question on the attachment of the airlons, rudder etc. The guy at the LHS said he found it best to tape them on and not use a hinge. So whats the deal is it a prefence? I'm sure everyone has one....Would like to hear some of them so I can finish today.
dellavex is offline Find More Posts by dellavex
Old Oct 01, 2006, 07:58 AM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
The hinges are easiest to do with tape, preferrably 3M Blenderm tape. Dubro also sells this stuff in their package for $4.50 but you can pick it up at most pharmacy stores for $2 or less. It's designed for medical uses where tape really needs to stick to skin (or whatever) real good. It is kinda rubbery, clear, and super sticky. I have used it in about 8 planes that I've built and had zero troubles with it. You will save a ton of time instead of doing any kind of hinges!
Good luck on your build
Gary
Old Oct 01, 2006, 08:00 AM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
As Tram said... this stuff works great on foam. It's great for any application where there are some gaps and spaces (especially with repairs) that need to be filled. The glue foams up and fills those gaps and cracks making them super strong.
Get some, try it, you will be convinced.
Old Oct 01, 2006, 08:03 AM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
I used clear packing tape, after wiping down all surfaces with denatured alcohol to remove the foam release agent, for for the hinges on my first E-Starter which was built "stock". It worked well and I had no complaints with how the empenage and ailerons functioned, nor did I experience any failures.
That being said, my new E-Starter and Beaver will have brushless power and I think I am going to go the "floppy-disc" hinge route because of the increased speed and turbulence that will be going over these surfaces. Others who have gone brushless may have used the tape, and even others who built stock may have gone the "floppy-disc" or other hinge-type route. I guess it all depends on individual assessments, prefernces, and building style. I can honestly say, however, that the tape did serve me well on my stock ES.
Good luck in whatever you coose!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Oct 01, 2006, 08:07 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
I, too, have heard very good things about the "3M Blenderm tape". The adhesive is supposedly much more tenacious than the clear packing tape. Hmmmm... now you've got me thinking (uh, oh...) since tape IS much easier!
Aeronca
Old Oct 01, 2006, 08:14 AM
pamtri is offline
Joined Jun 2005
Colin,
I'm using the Hyperion Prop Saver 30 (I think that means for a 3.0MM shaft). The shaft is smooth and the screws hold it on. They use a black 0-ring for a nice snug fit.
When I look at my plane, I can see what they're talking about. There are *two* shafts. The one that's easy to deal with is the prop shaft. If you bend that, its easy to remove and fix or replace. The other is the *motor* shaft. If you slice that off, I guess your motor is trashed...
That said, I'll keep using the prop saver. Its saved me a ton of propellers (even on good landings where the plane just noses over in the grass).
Old Oct 01, 2006, 08:24 AM
pamtri is offline
Joined Jun 2005
How do you do the hinge with tape? Do you run the tape the entire length of the hinge (like on a Slow Stick)? Or would you just do an inch of tape at the ends and in the middle.
Did you use tape for the ailerons also?
Old Oct 01, 2006, 08:38 AM
dellavex is offline
Evansville Indiana
Joined Aug 2006
Gary, how close is Athens to Huntsville?
jay
Old Oct 01, 2006, 08:50 AM
aeronca is offline
aeronca's Avatar
Joined Oct 2003
I run the entire length of the hinge line to minimize flutter...
Aeronca
Old Oct 01, 2006, 12:13 PM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
I put a couple inches on each end of the surface, then most of the way in the middle too. But not one continuous strip... I save my tape.
All control surfaces on all my planes for the last several I've built have all been done this way without fail.
Old Oct 01, 2006, 12:14 PM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
jay
Athens is 20 minutes West of Huntsville. Straight out Hwy 72 (University Drive). I work in Huntsville.
Are you from around here???
Old Oct 01, 2006, 12:24 PM
dellavex is offline
Evansville Indiana
Joined Aug 2006
No but I'll be down the in acouple of weeks to attend some training at Adtran..... Maybe we could hook up?
Old Oct 01, 2006, 02:20 PM
mecevans is offline
mecevans's Avatar
Joined Feb 2006
fixed the side and made a litttle mod, i used balsa to reinfroce the side. i moved the battery back more than usual and i found it flew better there i got about a 30 plus minute flight. i got kind of close to some turkey vultures and they tried to chase me but i shook them , besides that no problems.
Old Oct 01, 2006, 05:05 PM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
My bro (dee-grose) works at Adtran!!!!
Old Oct 01, 2006, 06:11 PM
dellavex is offline
Evansville Indiana
Joined Aug 2006
Sweet, I got abunch of rc questions.....would you be up for that?
Old Oct 01, 2006, 08:06 PM
ghee-grose's Avatar
USA, AL, Athens
Joined Jun 2003
We'll just have to arrange a lunch meeting!
I'll PM you with my contact info.
My E-Starter build fizzak Parkflyers 1 Oct 09, 2003 02:10 PM
E-Starter Build Question #2 Ralph_D Parkflyers 27 Oct 09, 2003 08:07 AM
E-Starter Build Question Ralph_D Parkflyers 7 Oct 04, 2003 07:52 PM
Oops! E-Starter Build Mistake Awakened Foamies (Kits) 3 Aug 29, 2003 11:45 PM
E-Starter Build and Flight Report (Long) DavidJ Parkflyers 11 Mar 17, 2003 08:51 PM
