Old Jun 25, 2006, 06:10 PM
Pelanconi Flyer is offline
Find More Posts by Pelanconi Flyer
Volksflugen
Pelanconi Flyer's Avatar
Joined Sep 2003
Build Log
Converting a Joystick into a Transmitter
Don't ask me why I'm doing this; I'm not really sure. I am going to change the pots in this Thrustmaster PC Joystick and hook them to the encoder from my Spektum DX6 to create a "buddy box" of sorts. This way I can transmit the output of this Joystick through my Jr 6102DX.
So far I have identified the 4 pots that will control the ailerons, elevator, rudder, and throttle. They are 100k ohm and must be replaced with 10k to match the DX6s electronics. I have located a couple sources for the pots and I will order them tommorrow.
Over the next few weeks, I will rip out the existing board and install the guts from my DX6, and change the momentary trainer button on my 6102DX to a toggle switch so I can use it as a "hands off" Tx base station. While I 'm at it I'll hook some of the trigger/buttons to channels 5 & 6 for shutter/smoke/bombs/rockets/whoknowswhat
I'm thinking that this might be cool to try with a real time fly by video setup that I have used before.
Pelanconi Flyer is offline Find More Posts by Pelanconi Flyer
Old Jun 25, 2006, 07:42 PM
Vindication is offline
Find More Posts by Vindication
Joined Mar 2005
Wow,
That seems really cool. Good Luck!
Vindication is offline Find More Posts by Vindication
Old Jun 26, 2006, 02:48 PM
Volksflugen
Joined Sep 2003
Bad news for me. Looks like I may not be able to get replacement pots in 10K. The problem is that they are 40 degree effective rotation, and although CTS will make them for me in quantities of 1000 or more, they don't have them on the shelf somewhere. They are nice people though and they are checking to see if they have anything close in resistance/rotation.
Old Jun 26, 2006, 04:48 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
Don't know if you are into programming microcontrollers, but this would be a simple program for a PIC or AVR to read the existing pots into A/D inputs on the micro and output a PPM string to the buddy port. Not sure about JR, but on most Futaba and Hitec, you can even get the power off the buddy port, so you could build the micro into the base of the joystick, with just a cable to the buddy connector on the transmitter.
jeffs555 is offline Find More Posts by jeffs555
Old Jun 26, 2006, 07:56 PM
Peteohms is offline
Find More Posts by Peteohms
Peteohms's Avatar
USA, TX, Leander
Joined Jul 2001
Take the sticks out of an old transmitter and fit them into a new housing. Easy money.
Peteohms is offline Find More Posts by Peteohms
Old Jul 20, 2006, 09:20 PM
Eric_N57105 is offline
Find More Posts by Eric_N57105
RC Bum
Eric_N57105's Avatar
Riverside, CA
Joined Apr 2006
Why not just parallel each of the 100K pots with an 11K resistor (a 10K and 1K in series, then paralleled across the end terminals)? That'll give you a 10K pot!
Eric
www.ke6us.com
Eric_N57105 is offline Find More Posts by Eric_N57105
Old Jul 22, 2006, 05:13 AM
ZAGNUT is offline
Find More Posts by ZAGNUT
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
Eric
www.ke6us.com
but linearity will be way off
dave
ZAGNUT is offline Find More Posts by ZAGNUT
Old Jul 22, 2006, 12:23 PM
RC Bum
Riverside, CA
Joined Apr 2006
dave
Very true. I forgot about that. It's already to 9K at 50%. Not too good.
Eric
www.ke6us.com
Old Jul 24, 2006, 01:14 PM
MikeBiv is offline
Find More Posts by MikeBiv
TP 1.21 Gigawatt Needed
MikeBiv's Avatar
Hendersonville, NC
Joined Jul 2005
Great Controller for a HomeBrew UAV system!
MikeBiv is offline Find More Posts by MikeBiv
Old Jul 26, 2006, 09:45 PM
ray foley is offline
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
What you really have to do is make up an analog interface board that takes the output of the pot wipers and conditions the voltage signal to match the voltage span of the pots in your xmtr at min, max positions. A simple op amp circuit with zero and span adjustments for each channel/axis can be made to simulate the operation.
and, oh yes, real men design in analog.
ciao -rjf
ray foley is offline Find More Posts by ray foley
Old Aug 11, 2006, 04:19 AM
mattijs321 is offline
Find More Posts by mattijs321
Joined Nov 2003
dont pots get read in charging a fixed capacitor...timing how long it gets?
You could do a very simple PIC board that just goes high after a period, logarithmicly coupled to the pots you have.
Real men design digital
the opamp circuit might be way easier though
mattijs321 is offline Find More Posts by mattijs321
Old Aug 11, 2006, 04:21 AM
Joined Nov 2003
easiest solution i guess if you have PIC stuff
Old Aug 12, 2006, 05:34 PM
andrew b is offline
Find More Posts by andrew b
dieselburner
andrew b's Avatar
Wyke, Bradford, west yorks
Joined Mar 2005
Why do you need these pots? you could change the timing capacitor on PWM, it would have to be bigger. The PWM is a series of monostables with variable on/off time, a 555 for each channel should suffice, just select the capacitor on each 555 so that you achieve the correct stick span. First thing to investigate would be actually how much does the resistance of the pot change from one end of travel to the other. Have you thought how you would achieve trims?
andrew b is offline Find More Posts by andrew b
Old Aug 12, 2006, 10:29 PM
GailInNM is offline
Find More Posts by GailInNM
Near Albuquerque, NM USA
Joined Apr 2003
Most standard pots have about 300 degree rotation. If you paint about 130 degrees on each end of the resistive element with silver or copper print conductive paint you will have about a 13K pot with 40 degree rotation if you start with a 100K linear taper pot. Probably close enough for your application.
GailInNM is offline Find More Posts by GailInNM
Discussion attach joystick to radio transmitter ┐how? itubal DIY Electronics 5 Oct 03, 2006 05:22 PM
Help Converting twister into collective spityman Micro Helis 4 Dec 22, 2005 01:05 PM
Converting a UPS into a 12v Power Supply? jmartin Batteries and Chargers 5 Sep 02, 2005 10:15 AM
Converting 2S into 3S ??? Flying Beagle Batteries and Chargers 14 Dec 17, 2004 05:55 AM
