Old Jun 24, 2006, 06:47 PM
MikeBiv is offline
Find More Posts by MikeBiv
TP 1.21 Gigawatt Needed
MikeBiv's Avatar
Hendersonville, NC
Joined Jul 2005
Mini-HowTo
How to Make a Shock Flyer Firewall Mount
If you have to mount a different motor bolt config or Make your own on a 3d plane that has a similar mount to a Shock Flyer this has worked great for me.
The First Pic shows my best attempt at using a coping saw and the one on the right is the final product of the bit. I don't know the name of it, I bought it a garage sale while back with a bunch of other tools.
Second Photo is the bit itself. It is 2 1/8" Anybody know what it's called?
I used my drill press and I am uncertain if you could use a handheld drill cause it won't fit into any of the chucks on mine.
Also, be sure if you download the drill pattern off the internet it prints out correctly. Mine was off even though it was a PDF.
MikeBiv is offline Find More Posts by MikeBiv
Old Jun 24, 2006, 07:04 PM
mike glass is offline
Find More Posts by mike glass
Bethpage Grumman, New York, United States
Joined Nov 2002
Hole Saw
mike glass is offline Find More Posts by mike glass
Old Jun 25, 2006, 12:14 AM
MikeBiv is offline
MikeBiv's Avatar
Hendersonville, NC
Joined Jul 2005
Thanks!
How have you guys been making your firewall motor mounts?
Old Jun 25, 2006, 04:39 AM
Downwind 1 is offline
Find More Posts by Downwind 1
Downwind 1's Avatar
massachusetts
Joined Aug 2003
GRATE idea ; I use 1/16 ply and a jigsaw for this. Also I added 4 little notches, were it meets the foam.
Downwind 1 is offline Find More Posts by Downwind 1
Old Jun 25, 2006, 08:45 PM
micagreenmachine is offline
Find More Posts by micagreenmachine
Yup, I just figured out to use a hole saw to make a mount the other day. Works awesome. I don't have a drill press so I use a hand drill. Works fine.
The trick is to saw/drill the hole half way thru the plywood, then flip it over and saw/drill from the other side. Comes out really clean that way...
10 more minutes of work notching it out (carefuly) with a small (balsa?) saw and it's all done in 12 minutes total! Only literally only takes a couple minutes to hole saw it out.
-todd
micagreenmachine is offline Find More Posts by micagreenmachine
how to make a Rear Servo/Gyro Mount for Shogun ATARI-2600 Mini Helis 7 Oct 06, 2005 10:00 AM
Rave shock flyer motor mount lozano415 3D Flying 14 Jan 30, 2005 09:31 PM
Help! How to build a Shock Flyer lozano415 3D Flying 6 Oct 15, 2004 11:18 AM
Question Shock Flyer motor mount thrust angle??? CactusJackSlade 3D Flying 5 May 13, 2004 04:54 AM
A fix for the stock Shock Flyer motor mount weak point Thomas B 3D Flying 0 Feb 29, 2004 02:07 PM
