Old Aug 06, 2006, 08:28 PM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Oop's almost forgot the most inportant part.
you put the Lime in the Coconut, you mix em both togeather
ewo
ewo is offline Find More Posts by ewo
JAM is offline
JAM
Find More Posts by JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
You lost me with 2 wings x times -3 part.............does that include adding the weight and amount of drag produced by the traditional landing gear of a tail dragger or the extra weight of the overdoing of hot melt glue filling in the mistakes???? And I just saw your last post..............can't stop laughing......it hurts....
JAM
JAM is offline Find More Posts by JAM
Old Aug 06, 2006, 08:33 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
JAM
well if you want to get technical,
2wings is slang for full span ,and the x factor is the length-3 times the height
see?
simple hugh?
ewo
Old Aug 06, 2006, 08:46 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Is the X-factor the same as the pucker factor.........?
JAM
Old Aug 06, 2006, 08:48 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
JAM
well lets just say the pucker factor i cant help you with
Maby i need to call Jen on you behalf on that pucker factor thing
x-3 div.2=
ewo
Old Aug 06, 2006, 09:09 PM
JAM is offline
JAM
JAM
MaxAmps CMO
JAM's Avatar
Nine Mile Falls, WA
Joined Jun 2004
Oh boy! I'm not sure you want her answer on this subject........She might kick my a$$ and mail you the pieces.
JAM
Old Aug 06, 2006, 10:44 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
when ya got it, Ya got it!
ewo
Old Aug 08, 2006, 07:25 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
EWO , cool animation .... Question about the 300... very low speed High AoA plane tends to wallow (wing rocking/tip stalling all at once ) , my Mini 3D epp did the same thing .... Is it normal , or can I tame this some way ... You be the designer....wassUP with that ???
Could you please restate your power system and exact setUP ... The boys want to build it like you did it ... I would like to do the same , cause mine came out too light and small ...??? I dunno' how that happened?????
gpw is offline Find More Posts by gpw
Old Aug 09, 2006, 06:20 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Animation isnt mine, i borrowed it from a Japanese website a week or so ago.
Just thought it was cool and seamed to fit me as i was a break dancer back in the late 80,s early 90,s.................
Still do pop and lock when i get out of bed in the early hours
Anyways
I havent had any such problems with mine at all . Cept. i needed some stuff fo another desigh so i robbed things from my 300
The red white and blue one in the pictures earlier was 32 " I did add a little to the rudder and it flew verry good No kind of wallowing , maby the extra rudder area helped
It had a 17 turn komodo and 3 HS55 servos, and cheap gws reciever
also i used a 700 and a 910 cell battery .
Hope this helps some
I would be glad to resize the drawings to whatever size would work best for your crew
ewo
Old Aug 09, 2006, 07:49 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
hUMMMMM wallowing YEH. Do a fly by and see if the ailerons are where they are suppose to be during flight. I had a plane one time that did that and both of them would tuck or cup up a tick from the air flow. So the flexing would rock the wings. Once I fixed it the issue went away.
Thatovalguy is offline Find More Posts by Thatovalguy
Old Aug 10, 2006, 06:33 AM
gpw is offline
gpw
gpw
gpw's Avatar
Joined Jul 2002
Guys , Don't get me wrong , I love the plane , and it is only this rare circumstance that makes me wonder ... I checked out the wings / ailerons , everything , all FINE !!! It just may be the pilot (might I say that ?) and his desire to fly in a hovering /slow motion / blimp-like manner that finds this lone odd flying trait ... low speed flying very high AOA (harriers, elevators) ,beyond a certain point , the plane seems to just lose it and fall off to one side or the other ... usually toward the torque side (left ) but not always (?)and seems like wing rocking at the same time .... maybe something as simple as more power , or the fact that my CG is about 45% now ...
hmmmmm?
EWO , thanks for the setUP info ... mine's about 28.5" and equipped similarly to yours...I really like the rudder response!!!!!! ... did you add extra (excuse the pun )area to the plans rudder ...????
TOG , how didja' fix it ??? Been thinking more and more about the extra FFF layer back to 40% of wing .... worked great on the Shark , and really stiffened the wing ...???
Old Aug 11, 2006, 07:43 PM
Foam rules
HdG Md.
Joined Jan 2003
gpw it was the control rods and horns. In slow High alfa forward flight you look at the ailerons and they were flexing. I changed the horns and the rods, made everything stiffer and it worked. Had the same issue with a plane Art got from a guy. It wollowed really bad in high alfa forward flight. Same thing, made it stiffer and alls good.
Old Aug 11, 2006, 07:46 PM
Foam rules
HdG Md.
Joined Jan 2003
ewo ya know what would be really cool with that animation? If the head was an 8 ball. It would be all you. Jam, you up for making it? I know your good at that sort of thing.
Well the bathroom is done so its time to get back to flying and building.
Old Aug 11, 2006, 07:49 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Hummmm.
Well i had a really good reply to the last post,My thought here"___________________________" but on second thought
i think i will just say that that makes sence.
ewo
Old Aug 11, 2006, 07:53 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Yea i thought about that, i think Jam can make it mine pretty easy
Whatcha think jason?
Well im shure glad the bathroom break is done
NOW Get To Work On Foamies.................
ewo
ModelTech Extra-300 ARF Electrified! Troy Sport Planes 39 Mar 11, 2004 10:07 AM
Watt-Age's new Extra 300 for Speed 400 chris hinz Sport Planes 54 Aug 07, 2001 05:46 PM
Extra 300 for geared 550 m.irschick Foamies (Kits) 0 Jun 03, 2001 06:48 AM
Canopy for my Extra 300 tumad Scale Kit/Scratch Built 0 May 07, 2001 04:08 AM
Cap-232 vs. Giles G-200 vs. Extra 300 MMGM Electric Plane Talk 5 Apr 25, 2001 12:20 AM
