Steve Shumate's T-38 / F-5 EDF Build
I have searched up and down the different forums and have yet to find a buid thread for an EDF version of Steve Shumate's T-38 / F-5. I got the kit for the pusher version of the F-5 from 6mmflyrc.com and absolutely loved flying this jet. I posted some pices here http://www.rcgroups.com/forums/attac...hmentid=797229
I have been itching to start an EDF version of the plane, and since I'm still relatively new to "scratch builds" I hope to have some feedback from more experienced builders. Steve was of great help with some suggestions for the power setup of the pusher version (Mega 16/15/3, CC 35A ESC, TP2100 3S 1P, 6X4 APC). My EDF Power setup is as follows: Wemotec Minifan 480 HET Typhoon 2T SPT 60A ESC TP 2100 3S (may run two parallel) My thoughts to start. After doing a lot of reading in different forums, especially the Bandit forum (there are a lot of great minds there), I found the minifan has an FSA of about 4.5" sq'd. That means that I would need just over 2.2" sq per inlet and will also try to achieve between 90 - 100 % exhaust, although I've heard that 80% will yield better speed performance, but for this build I think I'd rather have more thrust. Even thought I wanted this to be somewhat of a pioneering project, I'm not out to reinvent the wheel by any means. I'll use as much tested knowledge as I can, giving full credit where it's due of course. For the EDF build, I thought I'd use as much of Steve's original plans as possible and modify only where required while still trying to keep as much of a scale look as possible. Here's where I may be way off, but after doing some meassuring, I thought that using the same inlets I would be just about 100% FSA. I would however have to increase the width of the fuselage quite a bit in order to fit the fan. I have included some pictures of my progress so far. I would love to hear your comments, suggestions, and or critisism. Fire away ![]() Diego
Fabricating the Duct
I've started what I think is one of the crytical aspects of this build, the duct. I plan to carve a plug out of a block of foam, sand it, glass it, and then break-up and disolve the foam once the glassing cures. I got this idea from nopistons96 - F-18 build thread http://www.rcgroups.com/forums/showthread.php?t=515213
Change of Plans
I have decided to go in a different direction with the ducting. I spent too much time cutting and sanding a plug for the fiberglass duct, but in the end I wasn't really happy with the results. I also realized that making a glassed duct system would take quite a bit longer and add a considerable amount of weight to the plane.
I have decided to go with a much simpler duct system using the existing surface areas, a styrofoam cup for the transition into the fan, and 3mm depron for the inside front ducts. This is a lot easier and much lighter. I got the idea to use a cup from "Power" in his "New Wave Nano" build. I bent the corners of the cup using boiling water and being very gentle. I actually put the cup in for about 30-45 seconds and would then pull it out and bend gently. A better method might be to use water that can be tolerated with thick rubber gloves and work with the cup submerged. Now I will need to mount the motor on the fan. I need to decide whether I'm going to use bullet connectors or wire the motor straight to the ESC.
hey, where is that canopy from???? i need one for my f-20 edf build!!!
heres the link... http://www.rcgroups.com/forums/showt...25#post5758708 by the way, its looking great!!!!! |
Brent,
Thanks for the comments. I actually bought the canopy with a kit for the F-5 Tiger II from www.6mmflyrc.com. It's one of the few pieces that survived the crash . Good luck on your build also. I'll have to check in and see how it goes.
| Thread Tools | |
| T-38/F-5 Plans... | kepople | Electric Plane Talk | 2 | Nov 06, 2008 08:34 PM |
| plans for T-38/F-5 | kepople | Electric Ducted Fan Jet Talk | 2 | Feb 26, 2008 07:49 AM |
| Dyer's T-38/F-5B | Kevin Cox | Electric Ducted Fan Jet Talk | 10 | Jan 12, 2008 08:49 PM |
| Shumate/3DFoamy T-38 Talon VID | JohnVH | Pusher Prop Jet Models | 5 | Aug 18, 2005 12:04 AM |
| Ripmax F-16 EDF build | Richard Cox | Electric Ducted Fan Jet Talk | 20 | Nov 15, 2004 11:05 PM |
