| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
battery charger as 12v power supply
Is there anything wrong with using a automotive-type battery charger as a 12v power supply for my nicad charger? It seems like I heard not to do this. What are the dangers?
#2 |
Single-task at best...
sandman,
I did this for quite a while, with no problems except that the car-battery charger would cut out at 3amps draw, so everything had to be charged at below this rate. I believe there are technical reasons why this practice is frowned on by some, but I'm no expert. What I do now is charge my field battery from the domestic AC supply, at the same time as charging flight packs from the field battery, daisy-chain fashion. tim |
#3 |
its possible to do this but you need to modify it some. if you can solder and have access to electronic parts its no problem. you will need one of the larger chargers, 20 amps at least. if you dont allready have one then and you have a voltmeter dont buy one untill you contact me if you want to take this further. as usuall the cheap ones are the ones you have to modify the most.
#4 |
The problem with those chargers is that they do not provide pure DC. They have no smoothing or regulation and just provide a crude pulsed DC current. Fine for connecting to a lead-acid battery which does it's own smoothing but no so good for connecting to the complex electronics which is a modern NiCd/NiMH charger. Some will work. Some will die.
The best way to use one is to connect it to a 12V charging battery then connect the 12V battery to the NiCd charger. Steve |
#5 |
Been using a SEARS 10/2 AMP charger
for 12 years now , no problem ! Works fine on my ASTRO , LEISURE , & HITEC CHARGERS & BATT. PACKS! WILD BILL |
#6 |
Agreed with the 12V lead battery as "stabilizing capacitor".
Steve, what capacity would you suggest? Do you think a 7Ah sealed cheap battery is enough? TIA |
#7 | |
As a big capacitor is already enough a 7Ah baterie will do as well. Eike http://www.schunternet.de/~eike/ |
| Thread Tools | |
| New Triton charger plus 12v power supply | stealthy | Aircraft - Electric - Airplanes (FS/W) | 4 | Mar 07, 2005 12:55 AM |
| Car battery charger as 12V power source | Squeezer | Batteries and Chargers | 3 | Jul 24, 2004 06:57 AM |
| Hobbico Quick Field Charger and Costco 12v Power Supply/Compressor Make a Nice Combo | Vomit | Micro Helis | 0 | Apr 14, 2004 08:20 PM |
| Using Automotive battery charger as a power supply? | DRR | EFLIGHT Mailing List | 3 | Nov 13, 2003 07:02 PM |
| Carb Batery Charger As 12v DC Power Supply???? Will This Setup Work | putt_13 | Electric Plane Talk | 2 | Aug 13, 2002 01:13 PM |
