Old Jun 23, 2006, 04:23 AM
dtrip is offline
Find More Posts by dtrip
I'm flying ! (run for cover)
dtrip's Avatar
Greece, South Aegean, Thira
Joined Nov 2004
Is V-tail mix same as elevon mix ?
Hello,
I read in a sticky message that V-tail mix is not the
same as elevons mix (flying wings).
However my 3-ch Hitec Focus TX has a switch for "V-tail or elevon
mixing". (I ve never used it though, I only have an Easy Star).
However Im confused. Will I be able to fly a flying wing with this
TX ? How's about a V-tail ?
Take care
Dimitris - Greece
dtrip is offline Find More Posts by dtrip
Old Jun 23, 2006, 04:59 AM
tigrr is offline
Find More Posts by tigrr
iae
tigrr's Avatar
Sweden
Joined May 2005
V-tail is different from elevon mix per definition.
Elevon mixes aileron and elevator on an aircraft with two control surfaces as with a flying wing.
Elevator up makes both surfaces go up and Elevator down makes both surfaces go down.
Aileron stick left makes left surface go up and right surface go down (and vice versa).
V-tail mix is used on an aircraft with more control surfaces.
It mixes rudder and elevator on the two control surfaces in the tail.
Elevator up makes both surfaces go up, elevator down makes both surfaces go down.
Rudder left makes the left surcae go down(left) and the right surface go up(left).
And vice versa for right rudder.
Aileron stick is not involved in this mix, it controls the ailerons only.
What happens when you have a 3ch Tx is that you have elevator on the stick and rudder OR ailerons. Throttle is place separately.
When the left/right function on the stick can either rudder or aileron the mixing button gets named accordingly.
If you have V-tail on your model you cannot control ailerons.
If you have elevons there will never be any rudder anyway.
Definition differs but the practical use will be the same on a 3ch Tx.
You can fly a wing with that require elevon mixing with that Tx.
tigrr is offline Find More Posts by tigrr
Old Jun 23, 2006, 05:20 AM
dtrip is offline
dtrip's Avatar
Joined Nov 2004
Thanks I got the difference. Left-right is opposite for the
V-tail, compared to the elevons.
After reading manuals more carefully, I find that there are jumpers
inside the TX to inverse channels 1 and 2. So I suppose if rudder/aileron
channel is inversed (btw rudder and aileron is the same thing in a 3-ch TX,
it only has one stick), a V-tail is possible too. This is why they say
"elevon or V-tail mixing".
Although this is not practically possible, to open the TX every time a V-tail
is used.
Thanks a lot
Dimitris
EDIT: Btw there are 3-ch V-tail airplanes, see this :
http://www.sussex-model-centre.co.uk/shopexd.asp?id=261
and this:
http://www.sussex-model-centre.co.uk...xd.asp?id=2360
Old Jun 23, 2006, 06:13 AM
tigrr is offline
iae
tigrr's Avatar
Sweden
Joined May 2005
Yep, one has to reverse the rudder/aileron channel on the Tx too.
Very cheap and simple Tx mod:
Solder cables from the jumpers inside to a switch on the top of the Tx.
Then you will not have to open it every now and then.
Just make sure the switch is not easily altered by mistake, use a small switch like the one on the switch of a Rx battery harness.
Otherwise will will have regular adrenaline rushes, I guarantee that.
Tampering with things is loads of fun...
Old Jun 23, 2006, 01:56 PM
dtrip is offline
dtrip's Avatar
Joined Nov 2004
Hmmm, very interesting!
Old Jun 29, 2006, 10:53 AM
3D-flyer-93 is offline
Find More Posts by 3D-flyer-93
Dang Plane.
3D-flyer-93's Avatar
USA
Joined Feb 2006
On my spectrum Dx6 it has delta mixing (for flying wing) but no elevon mixing. Are they the same?
3D-flyer-93 is offline Find More Posts by 3D-flyer-93
Old Jun 29, 2006, 11:48 AM
sniderea is offline
Find More Posts by sniderea
Cedar Rapids, IA
Joined Mar 2005
delta and elevon is the same.
sniderea is offline Find More Posts by sniderea
Old Jun 29, 2006, 11:58 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
With both elevon and v-tail mixing, get the elevator to move properly first.
Then work on the turning.
If the surfaces move as they should, good.
If they don't, then swap the servo plugs in the receiver.
This has no effect on the elevator function, but will reverse the turning function.
You don't adjust the surface polarities for turning first. These come naturally after the elevator is working.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Jun 29, 2006, 06:04 PM
dtrip is offline
dtrip's Avatar
Joined Nov 2004
Hello Sparky,
Yes you are right!
So there is no need to reverse anything on the Tx.
Thanks !
Old Jun 29, 2006, 06:15 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Originally Posted by dtrip
Hello Sparky,
Yes you are right!
Thanks !
You'll only need to use reverse on the tranny to get the elevator to work properly.
Then it's just swapping the plugs for the aileron/rudder.
Neon V-tail mix + ATV = incompatible? crashbuilder Hitec/Multiplex USA 1 Oct 15, 2003 11:19 AM
Twin ESCs, V-tail mix, coaxial helo IAD Micro Helis 4 Dec 17, 2002 07:53 AM
Twin ESCs, V-tail mix, what will burn? IAD Power Systems 13 Dec 11, 2002 09:16 PM
v-tail mix problems CHARLIE BRITT 7 Electric Sailplanes 11 Sep 15, 2002 06:39 AM
Flash 5 v-tail mix question. omega blood Electric Plane Talk 4 Aug 04, 2002 03:36 PM
