Old Jun 22, 2006, 10:44 AM
metalbuggy is online now
Find More Posts by metalbuggy
"Cracking Toast Grommit!"
metalbuggy's Avatar
Sanford, NC
Joined Feb 2005
Help!
Blohm and Voss 141
I'm looking for a set of plans for this bird.
In the 36"-48" range.
All help is appreciated.
metalbuggy is online now Find More Posts by metalbuggy
Old Jun 22, 2006, 04:40 PM
Frank_K is offline
Find More Posts by Frank_K
Frank_K's Avatar
Antwerp, Belgium
Joined Sep 2004
Nick Ziroli designed one, slightly bigger though.
The plan is still available at www.rcstore.com
good luck with this unusual subject !
Frank
Frank_K is offline Find More Posts by Frank_K
Old Jun 22, 2006, 04:48 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Check out the www.airwar.ru for some documentation.
BTW - Frank what about your "Rhino way"
Harpye is offline Find More Posts by Harpye
Old Jun 22, 2006, 06:11 PM
jhas is offline
Find More Posts by jhas
Brentwood,TN
Joined Mar 2001
Try Al Lidberg's plans.
http://www.aalmps.com/
It is designed for free flight, but is an easy conversion. I had to scale up the plans to get 36 inches. To do this, just go to kinkos, and scale to whatever size you want. My 36 inch conversion flies great and is very unusual.
jhas is offline Find More Posts by jhas
Old Jun 23, 2006, 07:00 AM
Frank_K is offline
Frank_K's Avatar
Antwerp, Belgium
Joined Sep 2004
Hello Hans-Joerg,
I'm sorry to say rhino is on the back burner...
I am starting up a new division at work and this results in zero hobby time
whenever I finish drawing my DO-335 I'll mail it to you
grtz,
Frank
Old Jun 23, 2006, 08:47 AM
metalbuggy's Avatar
Sanford, NC
Joined Feb 2005
I appreciate the help everyone.
I may do a build thread on this if no one else has.
Old Jun 24, 2006, 08:20 PM
DaniSaez is offline
Find More Posts by DaniSaez
CeNeCe PRO rules!
DaniSaez's Avatar
Barcelona
Joined Jan 2005
Hi Metalbuggy,
I'm also starting to build a bv-141, it is all foam designed from a 3 view pic, and it's all CNC cut.
Here's the 3 view pic, and a dry fit of the wing, fuse and pod.
Wing has 5 pieces, with a total span of 120cm, pod was done in only 3 cuts (lateral, top and front), and the fuse is done in two interconecting halves.
I look forward to see how you do with yo BV-141 ;-)
best regards
Dani
DaniSaez is offline Find More Posts by DaniSaez
Article 04/05 JDC: Blohm & Voss P-188-04 stacker Electric Plane Talk 0 Dec 28, 2004 01:00 AM
Blohm and Voss 208/04 Joe41 Scale Kit/Scratch Built 8 Mar 08, 2004 06:38 AM
Help! Blohm+Voss 212 dead Heiner Skroblin Electric Ducted Fan Jet Talk 8 Mar 02, 2004 07:51 AM
Asymmetrical like Blohm Voss Van Scale Kit/Scratch Built 5 Jan 03, 2002 10:39 AM
Blom&Voss 141 building artical wanted? KOMET 44 Scale Kit/Scratch Built 2 Nov 13, 2001 10:23 PM
