Old Nov 19, 2007, 02:18 PM
RP6705 is offline
Find More Posts by RP6705
Joined Aug 2007
Ok when the motor is running the servos at the rear have a mind of there own?
Ihave disconnected the motor and run the speed controlto full speed and the servos operate correctly, so it is the motor itself which is causing the interference?
RP6705 is offline Find More Posts by RP6705
Old Nov 19, 2007, 02:52 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Sounds like it.
Have you got three capacitors fitted to the motor. One across the terminals and one from each terminal to the can of the motor?
Also make sure your power leads are well separated from the radio/signal wires.
Other things to try are small toroid rings for each motor lead.
It could well be that the interference is caused via the ESC's BEC. If the glitching and interference persists, then try removing the red wire from the ESC's receiver plug, and either use an external BEC or plug in a 4 cell battery pack for the receiver and servos. If this cracks it, then you may need to consider a different ESC.
Andy
Sub culture is offline Find More Posts by Sub culture
Old Nov 19, 2007, 03:17 PM
RP6705 is offline
Joined Aug 2007
I think the problem lies with the main pcb at the front of the sub, there seems to be more problems, there is power coming into the board but nothing coming out now, i think this one will be taken back or i will ask if the main board can be replaced.
Old Nov 19, 2007, 03:31 PM
RP6705 is offline
Joined Aug 2007
No the problem was not the main board, i found a switch that was trapped and it switched it off!
Back to the drawing board!
Old Nov 19, 2007, 03:41 PM
Ocean's One is offline
Find More Posts by Ocean's One
Joined Oct 2007
Russ, another little suggestion.
If you are afraid of the motor position close to the servos, you may remove the motor, apply longer wires, place the motor somewhere else (far from the servos) and run again.
If the problem still exists, the position of the motor has no influence: the cause is another one.
Ocean's
_______
By the way, are the two motors of the same model and voltage? They should be.
If so, what about replacing the propulsion motor with the pump one (*), just for a test, and see what happens? If there's something wrong with the propulsion motor, the problem should disappear.
Otherwise, you'll have to check the other electricals, as Andy suggested.
(*) disconnect the hose to the bag, of course!
Ocean's One is offline Find More Posts by Ocean's One
Old Nov 20, 2007, 04:11 PM
Azekpoan is offline
Find More Posts by Azekpoan
Sweden
Joined Nov 2007
RP6705,
...or anyone else who might know: I'm following this thread with interest, since my dad and myself are considering buying one of those little (?) beauties for Christmas.
However, it seems that dealers in Germany (where we plan to purchase it) sell only an ready-to-run version, which would spoil half the fun. You however seem to have gotten a kit with assembly plan and all...?
Was that a special order? Or how else can one get a DIY-Neptune like you did?
Thanks in advance for the help!
Azekpoan is offline Find More Posts by Azekpoan
Old Nov 20, 2007, 04:54 PM
RP6705 is offline
Joined Aug 2007
In the UK the Neptune is only available in kit form, the rtr version i tnink is not available until 2008, a few model shops now have these in but they seem to be scarce and hard to come by at the minute, i should imagine they will be better availability towards christmas.
Old Nov 20, 2007, 06:39 PM
Azekpoan is offline
Sweden
Joined Nov 2007
Great, thanks! I now found a shop in the UK (wonderlandmodels) where I can order the kit.
Sorry to bother you again, but...
- What radio set did you buy for it? Any tips on what I should think of when looking for my own?
- Did you also buy the Polyphemus camera and cable? Any tips on where to get that one?
Old Nov 21, 2007, 03:27 AM
NEPTUNE 1 is offline
Find More Posts by NEPTUNE 1
Joined Oct 2007
Hi there,
Radio set should be 40 mhz 4 channel mimimum, be sure not to go for the 2.4 ghz wireless as the signal will not transmit through water, as for the camera i am installing my own, i think the one that ThunderTiger produce doesnt have any infa-red lighting so i think it will only be any use in a clear swimming pool and the monitor is very small, i have gone for a 8 inch lcd monitor which can be powered off battery and a 2.4 ghz wireless camera powered off the Neptunes battery, again with the transmision problem the cameras transmitter aerial has to be lengthened so that it sits on the top of the water with some kind of buoy(ping pong ball maybe).
Russ
NEPTUNE 1 is offline Find More Posts by NEPTUNE 1
Old Nov 21, 2007, 07:17 AM
Man from Atlantis
London
Joined Nov 2003
If you can spare the extra cash, a 6-channel TX is worth the investment. Most people usually want to add a function or two above the 4 channels usually used, and the cost of a 6-channel set isn't significantly greater.
For a receiver I would strongly recommend one of the newer generation microprocessor PPM receivers.
Jeti MPD, Schulze range and Hyperion receivers all feature these advances. The microcontroller filters out spurious information and stops servo jitter, improves weak signals etc.
They offer the benefits of PCM with out the disadvantages. They cost a tad more than standard receivers, but it's a small price to pay for the benefits they offer.
Andy
Old Nov 21, 2007, 07:29 AM
Azekpoan is offline
Sweden
Joined Nov 2007
Ross and Andy,
Thanks a lot! I’ll see what I can find on the net…
How’s the work with your sub progressing, Ross?
…and another thing, concerning the camera. Here’s an interesting site giving some food for thought on the issue: http://www.modelluboot.de/Video/Video_Artikel.html
Assuming that you don’t speak German, and considering your plan to put the aerial on a ping-pong ball, here’s one key idea I picked up from it:
What he suggests is to have a larger buoy. As it seems, if you use an aerial all the way up from the sub to the buoy, the signal would become too weak to be effective. He therefore suggests to take one with at least 1 litre (could even be a duck decoy), in which you can put both the sender for the camera and the energy supply for the sender.
Another thing he describes is the difficulty to steer the sub with a camera. Even 2mph seem very fast from the viewpoint of a tiny camera, one doesn’t have any references to steer by, and it’s difficult to guess whether one is going up or down or which way the sub his heading. One tip he has concerning the latter is to build in a little compass that you can see from the camera (he doesn’t specify exactly how, though). As for a depth meter he has no idea (yet) how to solve that one.
Concerning b/w cameras: don't you think it would be possible to add projectors to the Neptune, either inside the sub or outside? It’d be fun to see the bottom in all its colourful (ehm…) glory, after all… Plus that it might attract some fish.
Do you have any tips on where to buy cameras and monitors, by the way?
And one last question: I vaguely recall having read that it’s not possible to have an RC sub in saltwater, as the salt absorbs the radio waves. Is that true? If yes, does any of you have an idea on the modifications that would need to be made in order to place the sender in the buoy rather than the boat?
Cheers,
Frederik
Old Nov 21, 2007, 08:37 AM
Joined Oct 2007
Hi there, the Neptune is now fully built and ready for water trials, i have tested the WTC in the bath and will try it next in the swimming pool before i take the plunge into the lake. As with the camera install i am trialing a few methods using homemade water containers first with various methods of lighting.
Old Nov 21, 2007, 09:13 AM
Joined Oct 2007
Russ,
please accept my compliments: four days from delivery to finished model is a very good performance indeed!
Now keep us informed about your swimming pool test, tks.
Regarding buoys, I agree that the most functional solution is a buoy having inside the sender and its battery, even if it becomes larger. I've built such a buoy and I will post some pics. Eventually, I'll check how it performs during my next test with the Neptune.
________
Frederik,
I'm happy you wish to be a Neptuner!
Regarding salt water, the problem exists but there's also some solution. You may look at the thread "Titanic wreck" in the submarine section.
Hi
Ocean's One
Old Nov 21, 2007, 11:19 AM
Joined Oct 2007
Oceans, i think i misunderstand, the camera i am using as the transmitter built into it so does not require a seperate sender?
Old Nov 21, 2007, 11:40 AM
Joined Oct 2007
Ok, sorry, I didn't get it.
I supposed your camera needed an external sender, and therefore I suggested to place the latter inside the buoy.
If there is a built-in transmitter, you have just to let its antenna reach the surface.
(By the way, have you already decided how the antenna will pass through the Neptune's hull? You'll need a long antenna as well...)
Ocean's
THUNDER TIGER 42 GP on Ebay - only $15.50!! ENDS TUE 9-14 night bentgear Aircraft - Fuel - Airplanes (FS/W) 0 Sep 14, 2004 12:18 AM
THUNDER TIGER 42 GP on Ebay - only $5!! bentgear Aircraft - Fuel - Airplanes (FS/W) 0 Sep 10, 2004 06:16 PM
Good Deal on Thunder Tiger Ducati RTR!! grymg Motorcycles 8 Jun 24, 2004 05:52 AM
