Old Jun 21, 2006, 11:24 PM
Admiral_Red is offline
Find More Posts by Admiral_Red
Vice President at MultiGP
Admiral_Red's Avatar
San Antonio, Texas
Joined Oct 2001
15 Y/O .60 sized Curare to electric. Power suggestions please!
A friend asked me about converting a Curare Pattern plane he used as a teenager to e-power. I have been researching V28 batteries, and might just suggest them as a power source. I have a 77opto controller I can donate to the cause, so 10S is a posibility. That also sits in line with an Astro 109 for charging use as they are low cost and can hit a 3C charge current which the V28's are happy with. I am looking for power system suggestions based on 10S2P V28 power. Maybe I am going down the wrong path in thinking V28's?
The airframe weighs 3lbs 14oz with retracts and no servos, and 10S2P Emoli's should weigh about 3.2lbs. The goal is better than 1:1 thrust to weight for the whole flight, pitch speeds of about 60-70mph, and a flight time of 8-10 minutes. I would like to keep the weight to 8.5lbs max.
I am open for suggestions, please fire away! Available funds for the project are 450-550 including motor and at least one battery as I have a UBEC and ESC for it.
Thanks!
Edit: I realize that this might should be in the electric conversion forum instead. Please move it if appropriate.
Admiral_Red is offline Find More Posts by Admiral_Red
Old Jun 22, 2006, 04:16 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Have a look at the AXI 4130 range...
Old Jun 22, 2006, 09:29 AM
Matthew Cotten is offline
Find More Posts by Matthew Cotten
Joined Oct 2003
could it be that 3000ma is all you would need/want for this set up as 10cell in line make a bunch of power......10s2p is a lot of weight in e-molies.
Matthew Cotten is offline Find More Posts by Matthew Cotten
Old Jun 22, 2006, 11:58 AM
San Antonio, Texas
Joined Oct 2001
I have actually backed up from 10S to 7S2P. I think from looking at the specs, a Feigao 540XL 9T with the 5.2:1 and a 16x10 will get the job done nicely.
Edit:
Cells = 7
Gear Ratio = 5.20
Diam (in) = 16.0
Pitch (in) = 10.0
Weight (oz) = 77.3
Batt Amps = 54.7
Motor Amps = 54.7
Motor Volts = 18.9
Input (W) = 1037.2
InPLd (W/lb) = 214.7
Loss (W) = 134.0
MGbOut (W) = 903.3
OutPLd (W/lb) = 187.0
MotGb Ef(%) = 87.1
Shaft Ef(%) = 63.7
Motor RPM = 33725
Prop RPM = 6486
Thrust (oz) = 160.9
PSpd (mph) = 61.4
RofC (fpm) = 3529
Time (m:s) = 6:35
Old Jun 22, 2006, 03:39 PM
twest is online now
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
I was going to suggest an astro 40 brushless geared, but it looks like the feigao motor has nearly identical specs, and probably costs a bit less.
twest is online now Find More Posts by twest
New Product 60 sized twist-electric ready txfly 3D Flying 2 Jun 25, 2006 10:56 AM
Link 40-60 sized Glow to Electric Setups ndflicks Product Announcements 0 Mar 11, 2006 07:16 AM
Oldtime Power Suggestions Please steve f Power Systems 16 Nov 27, 2002 04:05 PM
Filip V Electric Power Suggestions Please - Steve McBride Electric Sailplanes 10 Dec 03, 2001 01:38 PM
Want more power for Simple 400. Suggestions please. smsgill High Performance 12 Oct 08, 2001 03:24 PM
