Old Jul 25, 2002, 02:20 PM
jimdrever is offline
Find More Posts by jimdrever
calgary, alberta
Joined Jun 2002
Hobby Lobby Super Cub 400
Hi
I have some questions about the Super Cub. If anybody could help out....
1) I would like to modify the wing with ailerons...is that possible?
2) Is a speed 400 6v enough power and could I use a speed 500?
3) Will the cub ROG?
Thanks in advance
Jim
jimdrever is offline Find More Posts by jimdrever
Old Jul 25, 2002, 02:40 PM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
HL Cub Power
I use a 6v S400 in a 2.3:1 Mini-Olympus gearbox, 9X5 Graupner Slim Prop, and nine 500AR nicad cells in my 28 oz 54" w/s Comet Aeronca Chief. I can rise off and land on short grass easily, climb rapidly to 500 feet and cruise for 6-10 minutes depending on lift etc. It will thermal very well. Covering is Litespan with Dope trim. I can loop after a shallow dive. Be sure to strengthen wing center section (and beyond) and make the struts functional if you are going to try loops. It should be fairly easy to incorporate ailerons using tourque rods and a single servo. If you build in moderate dihedral you would not need ailerons on your Cub. Dihedral is necessary to turn nicely with rudder and elevator.
BTW, I have the tail wheel mounted to the rudder so I can taxi very realistically.
Use the search engine to find threads on HL Cub wing strengthening.
E-Challenged is online now Find More Posts by E-Challenged
Old Jul 25, 2002, 04:20 PM
Dick Curtis is offline
Find More Posts by Dick Curtis
Dick Curtis's Avatar
Santa Barbara, California, United States
Joined Mar 2002
Jim,
If your referring to the Hobby lobby HLAR07 , $29 kit, here are data on one I built three years ago and still are flying.
Motor: 6 volt Graupner 400
Gearbox: Graupner GR170323, 2:33:1
Prop: Graupner GPS08040, Slimprop 8/4
Battery, seven, Sanyo KR600 AE cells
Weight- 24 ounces
Covering- Litespan
Quick takeoffs, six minutes flying time at 3/4 throttle, will loop and stall turn. I wouldn't bother with ailerons on this small airplane. It is all stick construction and somewhat fragile. Very pretty in the air. Not hard to build if you have experience with built up structure.
Dick Curtis is offline Find More Posts by Dick Curtis
Old Jul 25, 2002, 04:49 PM
JCastle is offline
Find More Posts by JCastle
The Bent Pin
JCastle's Avatar
McMinnville, OR, USA
Joined Mar 2000
I built one a while back set up the same as Dick's. Nice little plane that looked very scale in the air. ROG was no problem and ailerons not necessary. If I were to do it again I would reinforce the bottom longeron where the landing gear attaches and try to devise a way to change the battery faster. Repeatedly taking off and putting on the wing inevitably leads to broken struts.
John
JCastle is offline Find More Posts by JCastle
Old Jul 25, 2002, 05:45 PM
calgary, alberta
Joined Jun 2002
Thanks for the feed back guys. Nice looking planes.
I will confess now that I have attempted building 2 cubs, both ended in failure...due entirely to inexperience in building and flying. But I'm going to give it another try. I have a few models under my belt now and I like the look of the cub.
BTW, any comments on direct drive 400 with a 6x3 prop?
Jim
Old Jul 26, 2002, 01:33 PM
Joined Mar 2002
John's Cub sure looks nice with the balloon whells and paint job.
Regards battery changing, I left the right window open and insert the battery through it. Leave abour 6 inches of wire to pull through the window opening, plug in the battery and insert, I put velcro on the battery and floor to hold in place. works fine if you don't have fat fingers.
I wouldn't go with a direct drive with a six inch diameter prop since the plane is draggy and needs the thrust of a larger diameter prop. Remember that thrust goes up as the prop diameter fourth power so 6^4=1296 and 8^4 =4096: so 3 times the thrust (greater rpm would reduce to a factor of two).
Good Luck and send us a photo when finished.
Old Jul 26, 2002, 01:53 PM
genovia is offline
Find More Posts by genovia
The One....
genovia's Avatar
San Jose, Ca.
Joined Jan 2002
WOW!! I love how the Super Cub's have turn'd out in the hands of expert builders. Makes me want to change my covering to something even better GOOD LOOK"N J-3's guys
genovia is offline Find More Posts by genovia
Hobby Lobby Super Cub Speed 400 Maine Bear Parkflyers 43 Feb 13, 2004 08:59 AM
hobby lobby super cub bosley Parkflyers 16 Sep 17, 2002 04:34 PM
Hobby Lobby Super Cub- FS PunkerTFC Aircraft - Electric - Airplanes (FS/W) 2 Feb 14, 2002 12:21 PM
Hobby Lobby Super Cub, throws, thrust angles, ect. PunkerTFC Electric Plane Talk 0 Nov 22, 2001 07:37 PM
Hobby Lobby Super Cub - struts esox Electric Plane Talk 8 Jul 30, 2001 08:41 AM
