Old Jun 21, 2006, 07:43 PM
Tophinater is offline
Find More Posts by Tophinater
Tophinater's Avatar
GI, Michigan
Joined Jun 2004
Help!
H-bridge PWM frequancy????
I stumbled upon some chips very similar to the Motorola MPM3002 chip. Iv got the chips working fine except they get extremely hot only after a few seconds of running. Im using PWM signals to drive the chip and Iv tested them with only 20% duty cycles, as in 50ms low pauses 10ms high. If I raise or lower the frequancy so the thing will cool off? Im running a standard 300 size motor with no load and 12volts. The chip is rated to 8amps continuous and 100v at 62watts of power. There is no reason why the chip should be getting hot with such little power.
Tophinater is offline Find More Posts by Tophinater
Old Jun 21, 2006, 08:13 PM
jeffs555 is offline
Find More Posts by jeffs555
"Simplify, then add lightness"
Raleigh,NC
Joined Nov 2000
You won't be able to drive a 300 sized motor with that chip without an extremely large heat sink and even then it would be questionable. The MPM3002 has an on resistance of 0.4 ohms. That is 20 to 100 times higher than the mosfets used in most ESC's. At 8 amps, that would be 25 watts disipated by the chip. Without a heat sink, the MPM3002 has a Tja of 35 deg C per watt. If you tried to run 8 amps through it with no heat sink, the junction would try to get to 875 deg C, but would burn up long before that.
PS I just looked at the spec sheet again, and its even worse. The .4 ohms was only the P-channel. The N-channel is .15 ohms so the total for the bridge would be .55 ohms.
jeffs555 is offline Find More Posts by jeffs555
Old Jun 21, 2006, 08:24 PM
Tophinater's Avatar
GI, Michigan
Joined Jun 2004
The motors I plan on driving are 280 size and draw .750amps when they are locked. Thats only 9 watts of power to be drawing. Ill give the heatsink a try and see what happens.
Old Jun 21, 2006, 09:14 PM
jeffs555 is offline
Raleigh,NC
Joined Nov 2000
Actually, at .75 amps and .55 ohms that would only be 0.31 watts dissipated in the IC, and should be fine without a heat sink. However, that sounds like extremely low current for a 280 sized motor.
Old Jun 21, 2006, 09:54 PM
Comatose is offline
Find More Posts by Comatose
Dimension Engineering
Akron, Ohio
Joined Jan 2002
What sort of circuit are you using to drive the high side Pfets? You can't just connect them to the microcontroller or they'll alternate between "on" and "sorta on" which will get the chip toasty really quick. You need to use some sort of level shifter to get the control signals to 12v and 0v.
Comatose is offline Find More Posts by Comatose
Old Jun 21, 2006, 10:34 PM
Tophinater's Avatar
GI, Michigan
Joined Jun 2004
Im driving the chip directly from the MC. What sort "switching" set up should I use?
Old Jun 21, 2006, 11:11 PM
Comatose is offline
Akron, Ohio
Joined Jan 2002
An NPN transistor with a 1k ohm resistor between the collector and +12v, and a 1k ohm resistor between base and the microcontroller would work. The gate of the pfet goes to the collector of the NPN.
Old Jun 22, 2006, 07:42 AM
Tophinater's Avatar
GI, Michigan
Joined Jun 2004
Thanks for the help Ill give a shot, I just gotta see if I can find the NPN transistors now at work.
EDIT: Where does the emitter side go to??? I take it what you ment was the emitter goes to the Pfet. If you ment somthing different then Ill figure it out pretty soon!
Question H-Bridge circuit to dual polarity convertion help Angry_Monk Scratchbuilt Indoor and Micro Models 6 Aug 09, 2005 11:15 PM
Fried motor-FET (or h-bridge) on JMP Rx, what to do? nanoflite Scratchbuilt Indoor and Micro Models 21 Dec 03, 2004 11:48 AM
bipolar-H bridge amp? jonathan8388 Scratchbuilt Indoor and Micro Models 5 Nov 21, 2004 01:03 PM
H-Bridge problems Propjob81 DIY Electronics 3 Aug 11, 2004 09:07 PM
Bitcharger h-bridge mod Phreakish Scratchbuilt Indoor and Micro Models 15 Mar 02, 2004 03:17 PM
