Old Jul 25, 2002, 12:54 PM
Ray Manhart is offline
Find More Posts by Ray Manhart
Monroe, La.
Joined Jul 2002
Match Motor, Battery, & Propeller
Most of the electric plane motors on the market (such as Wattage) are not labelled as to the rated: voltage, amperage, wattage, or RPM with a specified propeller. Also, would an motor shaft adapter be required.
Therefore, I am very confused on how to match a motor with the correct battery & propeller.
Ray Manhart is offline Find More Posts by Ray Manhart
Old Jul 25, 2002, 01:04 PM
Bonafidepirate is online now
Find More Posts by Bonafidepirate
define("BEASTMODE", "1");
Bonafidepirate's Avatar
United States, LA, Moreauville
Joined Jan 2002
Ray, I've always come on here and asked what a good starting point would be, then went from there. After a few setups, you'll start to learn what motors use what props, and batteries, and ESCs, you know, all that good stuff.
What plane are you looking for a power setup for? Wingspan, airfoil, weight, type of model (trainer, sport, aerobatic...)?
By the way, I see we have another member from Louisiana. Starting to close in on me. LOL
Bonafidepirate is online now Find More Posts by Bonafidepirate
Old Jul 25, 2002, 03:06 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
Try this free calculator
http://custompaintjob.com/ezcalc/dma.asp
poobs is offline Find More Posts by poobs
FS Fan motor battery & charger Derrek Curtis Aircraft - Electric - Airplanes (FS/W) 7 Feb 12, 2004 08:12 AM
Battery & motor amp draw questions soundman Batteries and Chargers 6 Oct 06, 2003 02:45 PM
Flying Styro F-4U Corsair w/motor, ESC,& Li battery bruff Aircraft - Electric - Airplanes (FS/W) 1 Aug 05, 2003 09:08 PM
battery & motor voltages ? 13brv3 Foamies (Kits) 4 Mar 09, 2002 04:25 PM
Motor/battery combos for S&B Models - input wanted YVR Foamies (Kits) 0 Oct 06, 2001 02:50 PM
