Old Jul 25, 2002, 08:15 AM
NetForce2K is offline
Find More Posts by NetForce2K
Montreal, Canada
Joined Apr 2002
Question about glassing with WBPU... please help.
I put some glass cloth with WBPU on my project yesterday.
From what I've read and seen here, I thought the result would have been much more shiny/stronger than what I have...
I thought it would become as hard as plastic, or glass ! The foam is not realy harder than it was before the glass cloth was applied. What could explain that ? Not enough WBPU ?
I'm covering pink foam, using .75oz cloth with BEHR Water Based Polyurethan (High gloss).
Please if anyone can give me some advice, it would be very appreciated.
Fred
NetForce2K is offline Find More Posts by NetForce2K
Old Jul 25, 2002, 08:30 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
I think part of the problem is that the foam may absorb some of the WBPU, so you're not getting a silky smooth hard finish, but that's fine. You just want the glass to bond to the foam. I usually put on 2 or 3 coats of WBPU, to try to fill the weave as much as possible, w/o too many pin holes. It's not going to be puncture proof, or heavy ding proof, but it's does stiffen up the foam significantly and enough for flying. I seem to be getting a much harder and tougher finish on balsa than foam. It also takes some time for the WBPU to dry completely and harden.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jul 25, 2002, 08:34 AM
Montreal, Canada
Joined Apr 2002
I see... It's gonna be 24h since the first coat this afternoon, I will try and put a second one... As you said, I think it might have been absorbed by the foam.
Hey I see that you're in Hull... I'm traveling to Hull and Ottawa once a week for work, can you recommend a few good Hobby Shops in that area where they hold Electric stuff ?
Thanks for your help by the way !
Fred
Old Jul 25, 2002, 10:20 AM
tom_yellowblue is offline
Find More Posts by tom_yellowblue
Sunnyvale, CA
Joined May 2001
Pierre, have you ever weighed the plane before and after you've applied the WBPU? I'm wondering how much weight it adds. Does the foam absorb more than the balsa?
tom_yellowblue is offline Find More Posts by tom_yellowblue
Problems with edges...please help urbankreations Composites Fabrication 4 Dec 18, 2004 11:48 AM
G2 USB with FMS.. please help tripxrcer Simulators 2 Dec 19, 2003 07:37 PM
Question about A-10 with polies? thor4944 Parkflyers 4 Aug 08, 2003 12:12 AM
Soembody with motocalc please help... Hopperfly22 Parkflyers 3 Jul 03, 2002 10:55 PM
Covering EPP with tape . . . PLEASE HELP! CheeseWing Foamies (Kits) 20 Sep 08, 2001 11:38 PM
