Old Jul 24, 2002, 11:25 PM
Joe Elston is offline
Find More Posts by Joe Elston
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Best Motor For The Wemotec HW 609 Fan
Okay guys, I am looking for the best brushless motor for my HW 609 fan. I would like to be able to run 10-12 cells, zapped RC 2400's and maybe some 3000 NMHI HV's. The fan will be used in a scratchbuilt F86 Sabre. 37 inch wing and about 3.5 pounds all up weight. Any suggestions?
Thanks for any ideas guys.
Joe
Joe Elston is offline Find More Posts by Joe Elston
Old Jul 25, 2002, 03:15 AM
Motormike is offline
Find More Posts by Motormike
Deutschland, Baden-Württemberg, Ebersbach an der Fils
Joined Dec 2001
Some measurements...
FUN 500-21 7 Sanyo. 8,60 Volt 14,50 A 17514 U/min 125 Watt 2100 U/Volt 336 gr. 26,3 m/sec.
FUN 500-21 8 Sanyo. 9,60 Volt 18,10 A 19494 U/min 174 Watt 460 gr. 30,8 m/sec.
FUN 500-21 9 Sanyo. 10,70 Volt 21,50 A 21323 U/min 230 Watt 562 gr. 34,0 m/sec.
FUN 500-21 10 Sanyo. 11,80 Volt 25,60 A 23393 U/min 302 Watt 645 gr. 36,5 m/sec.
FUN 500-21 12 Sanyo. 13,50 Volt 32,20 A 26317 U/min 435 Watt 855 gr. 42,0 m/sec.
FUN 500-21 14 Sanyo. 15,60 Volt 41,20 A 29763 U/min 643 Watt 1111 gr. 47,8 m/sec.
FUN 500-21 16 Sanyo. 16,80 Volt 46,80 A 31697 U/min 786 Watt 1277 gr. 51,3 m/sec.
FUN 500-27 7 Sanyo. 7,90 Volt 26,30 A 20409 U/min 208 Watt 2700 U/Volt 496 gr. 32,0 m/sec.
FUN 500-27 8 Sanyo. 8,80 Volt 32,20 A 22398 U/min 283 Watt 605 gr. 35,3 m/sec.
FUN 500-27 9 Sanyo. 9,80 Volt 37,10 A 24069 U/min 364 Watt 708 gr. 38,2 m/sec.
FUN 500-27 10 Sanyo. 11,10 Volt 45,30 A 27068 U/min 503 Watt 897 gr. 43,0 m/sec.
FUN 500-27 12 Sanyo. 12,10 Volt 54,00 A 29050 U/min 653 Watt 1034 gr. 46,2 m/sec.
FUN 600-11 7 Sanyo. 8,80 Volt 3,30 A 10210 U/min 29 Watt 1100 U/Volt 119 gr. 15,7 m/sec.
FUN 600-11 8 Sanyo. 10,20 Volt 4,10 A 11759 U/min 42 Watt 159 gr. 18,1 m/sec.
FUN 600-11 9 Sanyo. 11,50 Volt 5,10 A 13159 U/min 59 Watt 202 gr. 20,4 m/sec.
FUN 600-11 10 Sanyo. 12,70 Volt 6,00 A 14525 U/min 76 Watt 247 gr. 22,6 m/sec.
FUN 600-11 12 Sanyo. 14,90 Volt 8,20 A 17120 U/min 122 Watt 344 gr. 26,6 m/sec.
FUN 600-11 14 Sanyo. 17,70 Volt 11,00 A 19981 U/min 195 Watt 483 gr. 31,5 m/sec.
FUN 600-11 16 Sanyo. 19,40 Volt 13,20 A 21979 U/min 256 Watt 577 gr. 34,5 m/sec.
FUN 600-11 18 Sanyo. 21,60 Volt 15,80 A 24511 U/min 341 Watt 722 gr. 38,6 m/sec.
FUN 600-11 20 Sanyo. 23,50 Volt 18,10 A 26387 U/min 425 Watt 850 gr. 41,8 m/sec.
FUN 600-15 7 Sanyo. 8,90 Volt 5,80 A 12756 U/min 52 Watt 1500 U/Volt 193 gr. 19,9 m/sec.
FUN 600-15 8 Sanyo. 9,90 Volt 6,90 A 14156 U/min 68 Watt 239 gr. 22,2 m/sec.
FUN 600-15 9 Sanyo. 11,30 Volt 8,30 A 15937 U/min 94 Watt 300 gr. 24,9 m/sec.
FUN 600-15 10 Sanyo. 12,50 Volt 10,20 A 17951 U/min 128 Watt 378 gr. 27,9 m/sec.
FUN 600-15 12 Sanyo. 14,40 Volt 13,30 A 20203 U/min 192 Watt 501 gr. 32,1 m/sec.
FUN 600-15 14 Sanyo. 17,10 Volt 18,30 A 23698 U/min 313 Watt 702 gr. 38,0 m/sec.
FUN 600-15 16 Sanyo. 18,50 Volt 21,20 A 25512 U/min 392 Watt 816 gr. 41,0 m/sec.
FUN 600-15 18 Sanyo. 20,50 Volt 25,60 A 28330 U/min 525 Watt 1002 gr. 45,4 m/sec.
FUN 600-15 20 Sanyo. 22,10 Volt 29,20 A 30167 U/min 645 Watt 1140 gr. 48,5 m/sec.
FUN 600-18 7 Sanyo. 8,50 Volt 10,60 A 15505 U/min 90 Watt 2100 U/Volt 286 gr. 24,3 m/sec.
FUN 600-18 8 Sanyo. 9,60 Volt 13,40 A 17484 U/min 129 Watt 380 gr. 28,0 m/sec.
FUN 600-18 9 Sanyo. 10,80 Volt 16,20 A 19437 U/min 175 Watt 453 gr. 30,5 m/sec.
FUN 600-18 10 Sanyo. 12,10 Volt 20,20 A 21623 U/min 244 Watt 572 gr. 34,3 m/sec.
FUN 600-18 12 Sanyo. 13,40 Volt 25,10 A 23925 U/min 336 Watt 715 gr. 38,4 m/sec.
FUN 600-18 14 Sanyo. 16,20 Volt 33,60 A 27779 U/min 544 Watt 976 gr. 44,8 m/sec.
FUN 600-18 16 Sanyo. 16,70 Volt 37,10 A 29719 U/min 620 Watt 1090 gr. 47,4 m/sec.
FUN 600-18 18 Sanyo. 19,70 Volt 49,10 A 32970 U/min 967 Watt 1386 gr. 53,4 m/sec.
Motormike is offline Find More Posts by Motormike
Old Jul 25, 2002, 10:53 AM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
Joe, I ran the 1406/2Y in my 609 in a Ky T-33 and the first few flights were awesome on 9 cells until it threw a magnet. When it came back from the repair the 1406 was never the same, didn't have the same power. I think the rotor design was the same, it didn't look any different so I don't think the kV changed. Even if it had, I tried the motor on 11 cells and kept getting thermal cutoff, and then went to 10 cells and still was getting thermal cutoff. I think the L260 controller was too conservative with temperature, it's rated for 60 amps but I was only pulling around 50 or so.
So would I recommend an Aveox motor? Hmmm, I guess maybe the new ones are ok, but you'd want to get a 60-70 amp controller.
Mike's data seems to show that the 500-27 on 10 cells might be the best choice, maybe 12 cells if you can stand the heavier wing loading. I have a Fun 400-28 and I love it, especially the fact that the controller never cuts the motor, it just gradually spools down until the plane wont stay in the air. No pulsing like with the Aveox.
I hope your Sabre flies great. I seem to recall you were working on a glass version? Cool. Hope your fiberglassing experience is better than my first foray. I made my Wattage Sabre into a plug, the second half that I molded came out worse than the first, painted the plug with silver paint and it and the epoxy liked each other too much and stuck like glue.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Jul 25, 2002, 02:29 PM
foss1997 is offline
Find More Posts by foss1997
toledo, oh, usa
Joined Nov 1999
Im using a mega 22-20-2 on 10 cp 2400's works pretty well but i think the cp 2400s are too heavy for my project....
Scott
foss1997 is offline Find More Posts by foss1997
Old Jul 25, 2002, 02:53 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Motors
Thanks guys for all the responses to my question.
Thanks Mike for the numbers.
Ed, the plane was not layed up by me. I am just building it from a short kit. I have a Dragon 55 esc for my 1406/2Y, evreybody that I know that has used an Aveox esc on their 1406/2Y has had thermal shutdown with more than 9 cells. I wonder if the Dragon would be any better?
Thanks Again
Joe
Old Jul 25, 2002, 03:31 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: Motors
Originally posted by Joe Elston
[...] my 1406/2Y, evreybody that I know that has used an Aveox esc on their 1406/2Y has had thermal shutdown with more than 9 cells. [...] Joe
I use a Jeti 70 on the 1406/2y on 12 CP 1700 cells & never had any problems. A friend (Doug) has a Ky fan & B40-11S, with same power he runs rings around my config.
Herb is offline Find More Posts by Herb
Old Jul 25, 2002, 03:51 PM
Jim Phelps is offline
Find More Posts by Jim Phelps
Jim Phelps's Avatar
Elizabethtown/Ft. Knox, Kentucky, United States
Joined Jan 2001
Joe, I have a Hacker B50-12S/609 fan on 10 cells in a Mig 17 and it works great.
I also have a brushed Ultra 920-4 with the same setup that works great too, although I wouldn't go out and buy one!
Jim Phelps
Jim Phelps is offline Find More Posts by Jim Phelps
Old Jul 25, 2002, 05:23 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Posted by Herb
Herb, can you tell me how many amps you are drawing on 12 cells? And do you know the watts out?
Thanks Joe
Old Jul 26, 2002, 12:55 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
About 53 A x 12 V = 640 Watts with my setup. The Minifan can deliver the same amount of power with comparable efficiency & a lot less weight to carry around.
Old Jul 26, 2002, 08:01 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
Joe:
as Herb alluded to, why not go with a lighter set up. i had a 700w 609 set up in my Mig originally, but a 600w m/f set up has the same speed at 12oz less weight..............gregg
gregg f is offline Find More Posts by gregg f
Old Jul 26, 2002, 07:11 PM
Acme Powered!
Joe Elston's Avatar
Orange,CA
Joined Jul 2000
Sabre Fan
I think that this plane is larger than your Mig, Gregg. And the ducting is desighned for the 609. If I could run 700 watts I would be happy!
Joe
Old Jul 27, 2002, 12:59 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Re: Sabre Fan
I think that this plane is larger than your Mig, Gregg. ...Joe
Wingspan of K&A MiG-15 is 38 inches, one inch more than your F-86.
Old Jul 29, 2002, 07:19 PM
Oski is offline
Find More Posts by Oski
Lake City, Fl
Joined Mar 2002
URL site
Joe, did you get the PM with the URL site I sent last week? Was it the correct one? If not, will go on F14 thread and find it.
Oski is offline Find More Posts by Oski
Best motor for wemotec minfan? dusmmdb34 Power Systems 0 May 23, 2005 01:50 AM
What motor for Tanic 6S and 609 fan? sblack Electric Ducted Fan Jet Talk 5 May 27, 2004 12:01 PM
HELP!! Best Motor for Wemotec Minifans?? hulbear Power Systems 6 Feb 06, 2003 09:54 PM
Which Motor For My HW 609 and FJ-3 Fury Joe Elston Electric Ducted Fan Jet Talk 17 Nov 30, 2002 11:40 AM
Best Motor for Wemotec Micro-fan Gordon Electric Ducted Fan Jet Talk 16 Jun 10, 2001 10:23 PM
