Old May 03, 2001, 09:06 AM
Al P is offline
Find More Posts by Al P
small electrics r BIG FUN
Iowa
Joined Aug 2000
How hazardous are soldering fumes ?
Well, I finally got the nerve to solder my first flight pack last night. Wasn't that tough once you believe you can do it.
I've been using Deans Racing Solder from New Creations for all my soldering, I suppose it has flux in it from all the smoke when it melts. Also has some silver solder in it.
Is the smoke just the flux, and how dangerous is soldering in the house ? I mean the fumes . There is lead in solder also.
Al
Al P is offline Find More Posts by Al P
Old May 03, 2001, 09:52 AM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
I would not bother with fancy solder. IMHO There is not much to it but the percent of tin vs lead etc. The more tin the higher the higher the melting point.
You probably have rosin cored solder. I think rosin is basically tree sap.
The mnanufacturer or suplier might have the Materail Safety Data Sheet for the product.
If you find out something negative please let me know. I practically inhale this stuff when I solder.
poobs is offline Find More Posts by poobs
Old May 03, 2001, 10:01 AM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Al,
I've been sucking those fumes for decades. The good stuff too, not that water soluble crap.
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old May 03, 2001, 10:11 AM
BillH is offline
Find More Posts by BillH
Function Over Form
BillH's Avatar
Connecticut
Joined Feb 2000
Yeh, I've been breathing that crap too, I do think that it could be hazardous, afterall arent you breathing in Lead particles?
BillH is offline Find More Posts by BillH
Old May 03, 2001, 10:39 AM
Rotten Robbie is offline
Find More Posts by Rotten Robbie
Rotten Robbie's Avatar
Kent, Wa.
Joined Feb 2001
The hazard with soldering is that tere is LEAD (and TIN) in the fumes. Neither are good for you.
But you should nof have to inhale them. Keep your work area well ventilated and if possible have a draft the carries the fumes away from you.
But if you are only assembling an occaisonal battery pack, you are not in danger.
You are more likely to burn yourself with the soldering iron than getting LEAD POISENING.
Robbie
Rotten Robbie is offline Find More Posts by Rotten Robbie
Old May 03, 2001, 10:48 AM
Quartz is offline
Find More Posts by Quartz
Ottawa, On, Canada
Joined May 2001
If you head down to radio shack you can get "lead free" solder.
Quartz is offline Find More Posts by Quartz
Old May 03, 2001, 11:06 AM
Slope Nut is offline
Find More Posts by Slope Nut
Super Senior Member
Albuquerque, NM
Joined Feb 2000
Lead free solder is for the WEAK!
Generally you should keep a window open or a fan blowing to either evacuate the fumes or dilute the fumes into the air without breathing them in directly off the iron. I try to keep it out of my face, but its like standing near a campfire....no matter where you stand the smoke seems to follow you.
Greg
Slope Nut is offline Find More Posts by Slope Nut
Old May 03, 2001, 11:42 AM
Spiff is offline
Find More Posts by Spiff
Ste-Therese, Qc, Canada
Joined Mar 2001
The big problem with lead and other heavy metals such as mercury is that your body cannot get rid of it so all intakes are cumulative.
I once worked for an electronics manufacturer and all soldering stations had proper ventilation. Of course, there is a difference between soldering for a living and for hobby. Gentle ventilation for hobby works is good enough. Too much wind will cool the part you're trying to solder
Spiff is offline Find More Posts by Spiff
Old May 03, 2001, 02:16 PM
fill is offline
Find More Posts by fill
Houston Texas
Joined Mar 2001
Hey, I did it for a living for a little while, what doesn't kill you only makes you a better person, the smoke is not from the lead but from the flux
fill is offline Find More Posts by fill
Old May 03, 2001, 02:52 PM
MrBungle is offline
Find More Posts by MrBungle
rebmeM roineS
MrBungle's Avatar
Rockingham, Perth - Western Australia
Joined Apr 2001
Hi all,
I am currently studying Electronic Engineering, which includes doing a class 3, surface mount soldering accreditation module.
Now im no expert at all ( yet ) but I believe the dangers of fume inhilation are quite high.
Some of the training video's I had to sit through were quite graphic, showing the effects of long term expusure to these fumes. Ofcourse, the video's were for industrial soldering where the concentration and length of exposure is high, BUT some (not all) flux/rosins do have some known carcinogens....cancer makers, that ANYONE soldering (with those fluxes) will be exposed to.
From what I have learned from my lecturer,
(and I could be wrong) flux's are an acid or will form an acid, to remove the oxide coating on the solder, and surfaces to be soldered, so the solder alloys can flow nicely over the nice new clean metals. Flux fumes, on contact with any liquid in our throat or lungs, can form acids which can cause TEMPORARY Asthma even if you do not normaly suffer Asthma (I have experienced an extreme case of this myself - VERY hard to breathe)
As for the lead in the fumes, this will not happen(im told) if the tip temperature of your iron is less than 900F, or 485C where lead vaporises. You are more at risk of lead intake after you have handled the solder and then eaten a sandwich etc...you _DO_ wash your hands after handling solder dont you??
In the lab room that I am soldering in, there are flexible extractor tubes that can be positioned over our work to suck the fumes, out of our faces.
The best bet is to solder in a well ventilated room, or even better, outdoors, and not have your head over the work.
If you start to notice that breathing is getting harder, or your throat feels a bit tingly (nice technical term there) its time to call it quits for the day, start again tomorrow.
Keep soldering, just leave a few windows open,
MrB
[This message has been edited by MrBungle (edited 05-03-2001).]
MrBungle is offline Find More Posts by MrBungle
Old May 03, 2001, 03:02 PM
steve glass is offline
Find More Posts by steve glass
england
Joined Jan 2001
I work in electronic manufacturing. All soldering activities have the fumes extracted.
All employees have yearly checks for lead levels and lung-function.
Breathing the fumes can sensitise your body so that further exposure will give asthma symptoms each time.
Always solder in a well ventilated area and wash your hands after
Steve
steve glass is offline Find More Posts by steve glass
Old May 03, 2001, 03:07 PM
brianchristie is offline
Find More Posts by brianchristie
Should it be doing that?
Riverside, CA
Joined Mar 2001
Yeah, just keep a fan near by or blow as you solder. Been doin it for many years (the surface-mount stuff too).
I've always used some small fan to keep the air moving across my work to move the fumes outta the way.
It hasn't affected me one %jhg!: qwer*(&)
Ah, what was my name again? Oh yes Brian Christie ;-)
brianchristie is offline Find More Posts by brianchristie
Old May 03, 2001, 03:30 PM
MrBungle is offline
rebmeM roineS
MrBungle's Avatar
Joined Apr 2001
Thanks Brian,
you just jogged my memory, I have seen a homemade extractor that I have been meaning to build for some time.
It was just a 120mm 12v computer fan attached to some of that flexible 5" ceiling ducting available at hardware stores, with the exhaust end hung out a nearby window. The fan blew into the duct and was placed close to the work.
MrB
Old May 03, 2001, 03:47 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
If you are vaporizing and inhaling the lead from the solder, your tip is a bit too hot
Make sure you have a small fan blowing across the work to keep the smoke from your schnoz and things should be well. Definately don't solder for 8 hours straight every day breating the smoke....
Have a good one guys!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old May 03, 2001, 07:18 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Considering the vast number of us old guys still around that used all those bad things..
solder, acetone, diesel, glue... These things won't kill you. If they could, they're be a lot more flying time at the local field during the week when us old guys go..
Not to say that some precautions aren't good, but fear.. Naah.. that's just a reaction to some gummint idjit with an agenda pushing his favorite whipping thing because he and only he knows what's best for everyone else!
Like those idiot labels all over ladders.
Golly, ladders are the modern equivalent of the gene-pool cleansing Saber Tooth Tiger! Go pet the nice kitty, and fail to contribute to the gene pool. Stand on the top of a ladder, and fail.... That's nature's way!
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
How dangerous are aluminum solder fumes? BING! Electric Plane Talk 22 Nov 11, 2003 03:02 PM
How dumb are you? Bleriot Parkflyers 17 Nov 15, 2001 09:10 PM
How good are the R-C 2400, N-2400SCR batteries Joel K. Scholz Power Systems 14 Jul 03, 2001 10:27 AM
How good are Sanyo 1600 Twicecells ? Al P Electric Plane Talk 7 May 26, 2001 12:00 AM
Hitec radio systems...how good are they? luv2fly Electric Sailplanes 6 Apr 24, 2001 01:49 PM
