Old Jun 17, 2012, 08:55 PM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Aftermrket or stock would be fine. do callie graphics have the specs for this model of woulf i have to supply them with something?
lipoflyer is offline Find More Posts by lipoflyer
Old Jun 17, 2012, 09:35 PM
limodune is offline
Find More Posts by limodune
limodune's Avatar
Australia, QLD, Toowoomba
Joined Oct 2011
Hi Lipoflyer
Did you purchase this bird in Aus ? if so where, I am still looking to purchase one
limodune is offline Find More Posts by limodune
Old Jun 18, 2012, 07:45 AM
dirdredd is offline
Find More Posts by dirdredd
Dir_D_Redd
dirdredd's Avatar
United States, GA, Clayton
Joined Jan 2010
I hope that this will help you in your search.SF-RC.com
dirdredd is offline Find More Posts by dirdredd
Old Jun 18, 2012, 10:05 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
I am sure they do since i had her make the delta decals for me...
Jetnfast is offline Find More Posts by Jetnfast
Old Jun 21, 2012, 10:17 PM
limodune is offline
limodune's Avatar
Joined Oct 2011
Callie has just excepted to do a custom job for my airliner where she will supply as well as the standard scheme clear decals and a cover panel for the port holes the required size and correct spacing, (which I have opened up on the fus for cabin light's) she is very good to deal with and under stands your need's.
Old Jun 23, 2012, 09:10 AM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
awesome, good to hear. I might be calling her up again too since i need some decals for my JHH F-86.
Old Jul 03, 2012, 10:43 AM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
What are the airframe parts needed to build one of these super airliners? Im really wanting an airliner, and was going to get the hobbyking A380, but i don't trust hobbyking airplanes after reading about some things.
******EDIT: I just checked all the parts to build the airframe up from scratch, its $174 just like the airliner costed! NICE!!!*********
electricrc68 is offline Find More Posts by electricrc68
Old Jul 03, 2012, 08:09 PM
Joined May 2011
Originally Posted by Glacier Girl View Post
68, to run my motors, you need 4S minimum. To run on 3S you'll need a higher kv motor.
The 2855, is also available in a 2300 and 2800 kv ratings, I'd say the 2800's would work for 3S for you.
You wire up the motors just like you Y harness ailerons. The receiver leads are Y harnessed to the receiver, and the power leads run to the pack(s)
If running 2 separate packs, I parallel the connections together, so that both motors are pulling from both packs instead of separate ones.
jamnbec, stock nacelles. Just bored out to fit the fans.
Trick, a 3M 77 spray adhesive can, with a piece of sandpaper wrapped around it, makes a nearly perfect 70mm form for sanding the nacelles.
I have a question. I've decided to run 4s 5000mah in mine. I understand the Y harnessing to the receiver, but what about ESC's? Do you use two ESC's and run a harness there too, or do you use 1 ESC? Im a little confused there. Also, how many amps is your ESC?
Old Jul 03, 2012, 10:59 PM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
You still have to run two ESCs, one for each motor. You can then do a y-harness to the reciever. Basically you want the throttle channel to output to both ESCs (via the Y-harness). If you are running the stock motors, a 20-30 amp ESC will be fine. If you run upgraded motors, then check on the motor specs to see what is reccomended.
Are you planning on running 4s 5000mah pack? If so that might be too much for the stock motors, just keep that in mind. They are designed to run on a 3s pack.
Old Jul 04, 2012, 12:02 AM
Joined May 2011
Well no im going to be running the change sun 10 blade and the motors that glacier linked on page 86. I think i know how the y harness works...I just wire them both up to the same receiver. The thing im confused about is the battery. Im using a single 4s battery, so would I make a harness there too so that power goes to both ESC's from the battery?
Old Jul 04, 2012, 02:56 AM
limodune is offline
limodune's Avatar
Joined Oct 2011
Yes you will need a Y harness going from your one battery to the two speed controller's
Old Jul 04, 2012, 09:33 AM
Joined May 2011
Okay cool thanks. Is there somewhere i can read about how to make this Y harness or somewhere to purchase it? Sorry for all the questions.
Old Jul 04, 2012, 10:41 AM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
To be 100% clear, you need a "PARALLEL Y-harness" from the 4s battery to the 2 ESC's. I am sure many hobby retailers or even on Ebay will sell a parallel harness that is already fitted to your type of connectors. You could also make one your self. Just make sure you dont screw up the polarity.
Old Jul 04, 2012, 11:31 AM
Joined May 2011
Okay thank you.
Old Jul 04, 2012, 11:51 AM
jdlilfan is offline
Find More Posts by jdlilfan
jdlilfan's Avatar
United States, IN, Indianapolis
Joined Mar 2010
You can make one pretty cheap by soldering. Otherwise you can buy them from several hobby shops online as well as ebay.
http://www.ebay.com/itm/Deans-Ultra-...item5ae46858bc
You will need to make a male/male adaptor for the battery though.
jdlilfan is offline Find More Posts by jdlilfan
Discussion NEW E-flite Super Airliner Jim T. Graham Product Announcements 31 Apr 11, 2008 12:13 AM
Video E-flite Super airliner, grass field dogon1013 Electric Plane Talk 3 May 01, 2007 12:58 PM
Discussion E-Flite SUPER AIRLINER TRASMITTER SET UP FedericoA Foamy EDFs 0 Oct 31, 2006 01:59 PM
Sold E-flite Super Airliner Cheap shschon Aircraft - Electric - Jets (FS/W) 5 Sep 28, 2006 05:29 AM
Discussion E-Flite Super Airliner DF - Edgewater Video RktMan North Coast Electric Flyers 5 Jul 06, 2006 09:19 PM
