San Jose, CA
Joined May 2004
stick tighter to the interior of the hub. Very small slivers of silver duct tape (1/8 wide) works best for me so far. I have tried epoxy and many other methods. The tape just works. Generally, you do not need much. The other issue here is that not all motors are perfectly balanced. They should be, but some of the HK motors are pretty far off. I typically run the motors alone and check for balance prior to use. If one is out, you will never get them to sync no matter how perfect the impellers are. That is why I always recommend the final tweak of marking the impellers and the motors. Then rotating the impellers a few degrees on the shaft and retesting. My impellers wind up with two marks. One is blue for the starting point and the other is red for the final "sweet spot". I avoid the twin Harmonic warble at all casts. Things tend to unscrew and fall off when you are vibrating the entire airframe at high frequency. Been there, done that... ![]() A |
United States, NY, Dobbs Ferry
Joined Feb 2008
I used Kilz, sanded, kilz again, sanded, Rust Oleum 2X paint, fine sand it and final coat of Rust Oleum 2X paint, white on fuse, blue tail, grey on the wing and horz stab. The whole plane is composite, 3 layers of layup on the fuse and tail, 4 layers of layup on the wing. To give you a idea of how strong it is, I can pick up the whole plane with just one hand holding on the horz stab (minus the wing) As for the wing, I can pick it up from near the wing tip with both powerplants mounted. Pretty strong I tell you. I didn't like the foam plane but it's a good idea to use it as a core for the composites, worked very well and was easy to work with. I built it this way due to the possible high speed it may run with the powerplants I have it on it... As for the powerplants, it's top secret and can't reveal it now until the madien flight. ![]() Hint: it got bigger intakes. All the flight controls have been lay'ed up with composites and doesn't twist under load. Even the flight control rods have been replaced with Sulivan Gold-n-rods. I was on company business for fam course training on the 777 for 3 weeks and while I was there, I did get a copy of the EPS file of the 'Continental' logo that was used to make the outline paint templates for the paint shop. On my lunch break there, I came by a logo decal cutting shop in a mall and had it done there. They couldn't do the globe on the tail due to the gold and white colors interlaced and it was in sections. Gonna try to use a printed photo of one and cut it out, then use a gold marker to draw it out then top it off with a white pen. |
Holy smokes!!! Whats your AUW gonna be? Even the lightest builds with stock gear dont do so well on grass. |
Joined Feb 2008
![]() Forgot to mention I reinforced the powerplant pylons with CF plates cut to match and bolted on there like a sandwich, also did some layup in the wing mounting area for extra support should it need it...wouldn't want my powerplants break free and fly on it's own!...would cause a major CG shift. Right now I need to do these things before the flight:
I plan on using bigger wheels for grass field operations, about 2.5 to 3" single wheels per strut. How do you support the NLG for grass flying? |
Joined Feb 2008
Crazy! I just found a local hobby shop in a nearby town in Japan close to where I am stationed and they have an SF Airliner kit! That's the one that the e-flite version is modelled after. I like the default Delta scheme on that much better than the E-flite version. It doesnt matter at this point since mine E-flite 777 is now repainted in the new Delta colors thanks to help from NW, but I was surprised to find it.
I finished my horizontal and vertical stab last night. I also had to break down and use the H2O primer on the fuse, cuz I needed it to fill in all the dimples made when installing the gear. Between my fingers and other pointy what nots, my fuse was lookin like a driving range golf ball. |
| Thread Tools | |
| Discussion NEW E-flite Super Airliner | Jim T. Graham | Product Announcements | 31 | Apr 10, 2008 11:13 PM |
| Video E-flite Super airliner, grass field | dogon1013 | Electric Plane Talk | 3 | May 01, 2007 11:58 AM |
| Discussion E-Flite SUPER AIRLINER TRASMITTER SET UP | FedericoA | Foamy EDFs | 0 | Oct 31, 2006 12:59 PM |
| Sold E-flite Super Airliner Cheap | shschon | Aircraft - Electric - Jets (FS/W) | 5 | Sep 28, 2006 04:29 AM |
| Discussion E-Flite Super Airliner DF - Edgewater Video | RktMan | North Coast Electric Flyers | 5 | Jul 06, 2006 08:19 PM |
