Old Jun 19, 2006, 04:37 PM
flossandfly is offline
Find More Posts by flossandfly
fly more...build less
Calgary AB
Joined Mar 2005
stiffen up deb tail
I have basically a debonair fuselage with the wings from my crashed tiger 2. The stab and fin shake a lot in the air. The stab is a little bit warped, would that cause me to not be able to do a good loop? I will just try to put on a new stab.
Also
Someone told me to try an L bracket on the fin to stiffen it up. Has anyone tried this?
flossandfly is offline Find More Posts by flossandfly
Old Jun 23, 2006, 12:32 PM
Calgary AB
Joined Mar 2005
I read that the deb tail wobbles for lots of people and doesn't cause any troubles. I flew in a very windy day and had troubles but that probably had nothing to do with the wobbly tail.
Flying on very windy days is the cool thing about SPADs.
Old Jul 13, 2006, 09:19 AM
spitfire123 is offline
Find More Posts by spitfire123
jimi hendrix
Joined Apr 2006
Also
RE INFORVE IT WITH STUTS
DONT LEAVE IT!!!!
spitfire123 is offline Find More Posts by spitfire123
Old Jul 17, 2006, 04:15 PM
Calgary AB
Joined Mar 2005
Good Idea. I will add some struts between the stab and fin. That should help.
Old Jul 17, 2006, 05:15 PM
acam37 is offline
Find More Posts by acam37
Cessna 172H driver
acam37's Avatar
lufkin,tx USA
Joined Nov 2003
Stuff bamboo skewers down the flutes. You can get them at the grocery store.
acam37 is offline Find More Posts by acam37
Old Jul 28, 2006, 11:39 AM
Calgary AB
Joined Mar 2005
I put a peice of string through one of the stabilizer flutes and attached them to the top of the fin. That helps a lot, the tail doesn't shake around like it used to.
I bought some bamboo skewers but they are much smaller than the 4mm coro flutes. Are there larger skewers or should I just jam more of the smaller ones inside to stiffen up the stabilizer?
How to set up a V-tail? miserlou Hand Launch 15 Feb 20, 2009 08:43 PM
Setting up a v-tail talonxracer Electric Sailplanes 5 Mar 05, 2004 01:16 PM
How to stiffen up veneer foam wings... Vic Peh Electric Sailplanes 3 Sep 22, 2003 08:04 PM
Whoops! Setting up a V-tail mixer in R Evo 9 lysander Radios 5 May 19, 2003 09:29 AM
Help me stiffen Lil hornet tail :( poobs Foamies (Kits) 5 Jul 19, 2002 05:22 AM
