Old Jul 01, 2011, 05:10 AM
bloodline is offline
Find More Posts by bloodline
Avro Vulcan Enthusiast
United Kingdom, London
Joined Jun 2011
Many thanks for your advice Robert!
I have been reading this thread for help to convert the old pusher model! Though I had originally planned to use a large gauge (0.5mm) Aluminium foil for the jet pipe, I now think I will use paper as Terry has done
This is set to be a fun and difficult project, my only real concern is the wing attachment... I think I will be investing heavily in carbon fibre rods
-Edit- I notice Terry has tapered the jet pipes by about half an inch from the fan to the exhaust... Do I need to taper the pipe, does that assist in providing thrust?
bloodline is offline Find More Posts by bloodline
Last edited by bloodline; Jul 01, 2011 at 05:12 AM. Reason: Added question about ducting!
Old Jul 01, 2011, 06:19 AM
Robert May is offline
Find More Posts by Robert May
Joined Apr 2002
The intakes need to be about 110% of the fan area (blade area less hub area) for an ROG model (100% for bungee) the eflux should reduce down to 85%.
With 4 to make, make a plug, then make Brown paper/PVA laminated tubes.
Look at Ron Laden's Eurofighter thread for details of that.
Robert May is offline Find More Posts by Robert May
Old Jul 01, 2011, 06:41 AM
Joined Jun 2011
With 55mm fans, that's a fan area (including hub) of 2376mm2, with two fans that's 4752mm2... And my intakes have an area of 6580mm2... So I should be good for the intakes... If i need 85% of the area for the exhaust... Then if my calculations are correct I would need the end diameter to be 50mm... Not much of a reduction... I assume I really do need to take into account the hub.
I don't have fan to hand to measure the hub size... I will rework my calculations again when I have.
Brilliant stuff, thanks again.
Another question, sorry I have so many... Is there any advantage to have smooth (I.e. Polished) bore jet pipes, or would any advantage be negligible?
Old Jul 01, 2011, 07:05 AM
Joined Apr 2002
I use rolled 0.3mm epoxy glass sheet for my ducts which is polished as a result of production.
As our models are comparatively flying through treacle anything you can do will help but that said, a finished bad model flies a heap better than a polished unfinished one.
Old Jul 09, 2011, 04:20 AM
Joined Jun 2011
My build has started
I will be constructing the fuselage central section conventionally, then once glued I will remove the bulkhead that foul my fan ducts and reenforce the sections with carbon-fibre.
My only concern now is the wing attachment. My current idea is to use 3 carbon-fibre rods that extend across the fuselage, two up front (top of the wing and bottom of the wing) which will also be the engine mounts and one at the rear of the wing.
Other than the wing attachment, I don't plan any modification to the wing design.
Old Jul 09, 2011, 10:35 AM
Joined Jun 2011
A couple of photos, the first is a test fit of the Port Wing Ribs... I love the undercamber at the edge of the wing!
The second photo is a rough sketch of the cuts I will be making to the bulkheads to accommodate the EDF ducts. The ducts get gradually lower down the panels and sit in the Jet pipe mouldings under the wing.
Old Jul 10, 2011, 02:49 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Really looking forward to this build, good luck. Went to see XH558 at Yeovilton yesterday.
Phil
jumpy is offline Find More Posts by jumpy
Old Jul 10, 2011, 08:47 AM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
shut up Phil. LOL
don't you have a plane to build?
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Old Jul 10, 2011, 12:45 PM
Joined Jun 2011
I saw XH558 earlier this year at Abingdon... See attached, and will see her again on the 16th at Fairford...
I also "accidentally" saw her at Margate, while visiting my girlfriend's grand parents... no idea how that happened
[youtube]YxFojmjxf_w[/youtube]
airshow.MP4 (0 min 28 sec)
Old Jul 10, 2011, 01:09 PM
Joined Jun 2011
Attached is a photo of my modification to bulkhead F6A to allow a real air intake. I will sand the Square hole into a nice smooth curve and build a nice smooth air duct with some lightweight filler.
Old Jul 11, 2011, 02:47 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Originally Posted by LuvEvolution7 View Post
shut up Phil. LOL
Yeah yeah i know, nearly there.
Gotta love that Vulcan 'howl' from those Olympus's, wonder how you could recreate that with edf's?
Phil
Old Jul 11, 2011, 03:05 AM
Joined Jan 2009
ummmmmmmmmm, I'm guessing some type of heavy liquid injection. although, I doubt the electronics would last very long. then again, the smoke trail would look really cool.
Old Jul 11, 2011, 11:00 AM
Joined Jun 2011
Perhaps a free spinning fan (with carefully placed distuptive stators - much like the old air raid siren) sitting in front of the EDF could simulate the spool up whine...? It would eat up a fair bit of the EDF's efficiency though :-/
Old Jul 12, 2011, 03:03 PM
Radar-Guy is offline
Find More Posts by Radar-Guy
EDF Vulcan To The Sky
Radar-Guy's Avatar
Near Koblenz, Germany
Joined Jul 2002
Nice work bloodline! I almost finished my 65 inch wingspan Twin EDF Vulcan (90 mm) build from the Cyril Carr plans. Here are are a couple of pics posted including the wing attachment at my model. The weight is 5,25 kg and the wing attachment works great. Of course I will not try snap rolls with this construction, but scale-like flying is no problem at all.
http://www.modelflying.co.uk/albums/...ms.asp?c=73594
Frank
Radar-Guy is offline Find More Posts by Radar-Guy
Old Jul 12, 2011, 04:22 PM
Joined Jun 2011
Frank
Beautiful model! I hope mine will look even half as good... Though I doubt it... my next one will be better
Also, scale flying is the plan... I don't want an engine with wings! :-D
Here is a photo of my fan duct template (held by my girlfriend to make the photo more interesting), I am cutting this out of the bulkhead to and mounting the fan behind... I can provide measurements/specs and templates if anyone else needs them.
Video Four jet Vulcan at Lords Hill pontious Electric Plane Talk 7 Jul 16, 2006 04:55 AM
Video Four Microfan Vulcan Maiden pontious Electric Plane Talk 1 Jun 19, 2006 05:18 PM
