Old Jun 21, 2006, 05:51 AM
pontious is offline
Find More Posts by pontious
pontious's Avatar
Bristol, Great Britain (UK)
Joined Jan 2001
Laminate nose then started on Red Steer tailcone.Laminate cockpit & observation bulge.Red Steer was made hollow.Nose still temp. fitted.
pontious is offline Find More Posts by pontious
Old Jun 21, 2006, 06:56 AM
Ron Laden is offline
Find More Posts by Ron Laden
Ron Laden's Avatar
Landkey, Devon, England.
Joined Jul 2003
Hi Terry,
Fantastic use of Depron (and your skill of course) to create a large volume airframe, very impressive indeed, way
I guess from the pictures Terry it is all 6mm material, have you found a method of generating compound curves with it. I think I read somewhere that you can mould it to some extent in hot water, but I,ve never tried it.
Great work Terry
cheers
Ron
Ron Laden is offline Find More Posts by Ron Laden
Old Jun 21, 2006, 07:50 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Hi Ron,
I havn`t had much success with compound curves, I have tried warming with water & Hot air but found this not required for normal single bends. The brown parcel tape stops the outer skin cracking & the inner wall concertinas up.I use thick skin to allow some sanding to obtain a reasonable compound look.
Nose now fixed & some lightweight filler & sanding.Thank God the original Vulcan was white.
Old Jun 21, 2006, 08:21 AM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Hi Terry
I've studied the video several times and didn't see the wings flex once despite what was clearly a strong gusty wind. Not that I really expected you to have produced a floppy model, but does depron make things pretty rigid?
I guess that you can't stand on the wings and have them survive, but here's what I'm leading up to. At present you're using 3s and 40A, say 420W. I'm wondering if, say, a 60" span Javelin, all depron like your Vulcan, but with, say, 9s and 50A (1575W) would be feasible. Or would that amount of poke simply cause flexing and ultimate failure? Could a spot of epoxy with judicially applied carbon cloth and carbon tows stiffen it enough?
Last question (for now ) Where do you get depron in big enough sheets to make a 6ft span Vulcan
Gordon
Gordon is offline Find More Posts by Gordon
Old Jun 21, 2006, 10:37 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Hi Gordon,
Flexing would not be any problem if it was one piece as it is remarkably strong having a 5mm monocoque skin.I had to make the wings detatchable for transportation & was very worried about making the joints strong enough without adding weight.I will cover this shortly.
A Javalin would be great as at the same size & weight the loading would be similar.Only two motors/ fans instead of four would allow for a motor upgrade with four cells if staying with microfans for the scale exhausts or two minifans with megas on four cells.Beefing up/power increase depends on retaining hand launch.
I get my sheets of depron from an insulation supplier at 32"x51" & as no one surface is bigger than that no probs.I think I used six sheets.
You have started me thinking!!!!!!
Started making upper wing skin & ribs /spar trying to retain scale drooped leading edge.Note cardboard plans tube for rolling.Sticky tape extends over the lead ege to grip the tube.
Old Jun 21, 2006, 10:57 AM
Ron Laden's Avatar
Joined Jul 2003
He has started me thinking as well Terry and I do have a reasonable stock of Depron
Ron
Old Jun 21, 2006, 11:30 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Terry, great construction! light and strong, i gotta try that..!
Gordon, check out this pic
http://www.btinternet.com/~javelin/p...d_1024x768.htm
like2fly! is offline Find More Posts by like2fly!
Old Jun 21, 2006, 11:35 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Hi Ron,
Yes a thick wing delta lends itself to this technique,strength & low wing loading.
Add depron edge strips for control surfaces .mark edges for later cutting out.
Dont worry about lead edge fit of skin they will be formed by vertical laminations. Trial fit to fuselage.
Old Jun 21, 2006, 02:11 PM
Gordon is offline
Gordon's Avatar
Joined Aug 2000
Hey Terry, gerroff me Javelin!!
And I hope you're only thinkin' EFA Typhoon Ron!
L2F - That's always been a really lovely pic. Mick Reeves is gradually adding them all to his range of kits www.mickreevesmodels.co.uk. All except the Hurri and Meteor are there already, and the even Hurri is under development, leaving only the Meteor for Mick to get started on.
Terry (again) you've definitely got me thinking ! Looks a great way for me to get out of a deep rut.
Looking forward to the wing assembly and attachment detail.
Cheers
Gordon
Old Jun 21, 2006, 02:15 PM
Gordon is offline
Gordon's Avatar
Joined Aug 2000
BTW, I stumbled on this depron supplier today:
http://www.depronfoam.co.uk/16226.html
They have carbon, plus some interesting accessories like control horns with spigots for glueing into depron.
Old Jun 21, 2006, 05:25 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
No CF rods in the wings?
RCParkflyer is offline Find More Posts by RCParkflyer
Old Jun 21, 2006, 05:34 PM
pontious is offline
pontious's Avatar
Joined Jan 2001
After much agonising, I determined to have a removeable carbon fibre tube in the body just clearing the top of the thrust tubes plugging into aluminium tubes at the highest load point in the wings with a locating peg at the front.
Now how to allign properly. No lower skinning at this point is a must.
With each wing at a time temp in place, I used the sharpened rod already in the fuz to bore a hole through the wing ribs. then remove the wing & place the rod in the newly bored wing rib holes & feed the aluminium tube using the rod as a guide to make its larger hole in the ribs.Glue the Ally tube in adding doublers.
Old Jun 21, 2006, 06:10 PM
pontious is offline
pontious's Avatar
Joined Jan 2001
After boring holes in the ribs for the elevon servo extension leads form & add the lower skins. Add laminations & sand for round lead edges.
At this point I weighed the total airframe -2Lb
Note I kept all the lightening pieces I removed using an apple corer & it came to nearly 1/2 Lb
Old Jun 22, 2006, 04:47 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Beginning to look like a Vulcan now.Pleased that I achieved the drooped lead edge & the wings on true.
Old Jun 22, 2006, 05:03 AM
pontious is offline
pontious's Avatar
Joined Jan 2001
Cut out the elevons & hinge with Micropore tape top & bottom of the V. Make thin ply horns fit wire linkages with Z adjusters.Adjust to get same movement of both elevons as for scale.Lots of up & little down.Fit servos & extension leads (I used G.W.S.18g Parkfly from B.R.C.Models.) I later fitted a strake to protect the servos & horns during belly landings.
Video Four jet Vulcan at Lords Hill pontious Electric Plane Talk 7 Jul 16, 2006 04:55 AM
Video Four Microfan Vulcan Maiden pontious Electric Plane Talk 1 Jun 19, 2006 05:18 PM
