Old Jul 17, 2011, 03:24 AM
bloodline is offline
Find More Posts by bloodline
Avro Vulcan Enthusiast
United Kingdom, London
Joined Jun 2011
These are the holes cut into the bulkhead. Once glued into the model, I will sand the flat sides smooth to form 63mm dia. holes (The fan is a 55mm fan), The fans will be directly mounted behind here, with smoothed filler to make an intake air duct.
bloodline is offline Find More Posts by bloodline
Old Jul 22, 2011, 12:55 PM
Joined Jun 2011
A quick update so you can see the new intake, it hasn't been finished yet, but the final form will be far more "areodynamic"
Old Jul 22, 2011, 01:06 PM
Robert May is offline
Find More Posts by Robert May
Joined Apr 2002
It can be difficult to tell from photos but the thickness of material seems a little towards the over engineered end of the scale. I have spent a few years very close to micro ducted fan models and whilst the parts are beautifully cut I am concerned that this one is going to be well over weight. Terry's original was made of Depron and thin air, 5mm close grain balsa might be a bit heavy. I am not having a pop but would hate for you to build something that flies like a space shuttle.
Robert May is offline Find More Posts by Robert May
Old Jul 23, 2011, 03:46 AM
Joined Jun 2011
Hey Robert,
I really appreciate you taking time to check on my progress! This is my first EDF so all comments are very welcome. I am very aware that this is going to be a heavy model as I'm looking for scale flying at best, but more than that, this is an experiment, everything I learn I will take to my next one
A scale test of the unglued parts suggests that I'm still on target for 5kg total model weight... Though I have little doubt that you are right and I will have an EDF brick
Old Jul 23, 2011, 11:33 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Originally Posted by bloodline View Post
Good morning gentlemen!
After much debate, my idea is to use four 55mm 4300RPM/V fans each pulling 18A (which should work out to about 200Watts per motor) and each motor delivering 470g of thrust.
Many thanks
I'm thinking that those EDF Perf numbers are a bit optimistic.
AEO persists in lying about their product performances.
DO your own EDF testing to verify thrust/amp numbers.
It may prevent surprises.
Bare is offline Find More Posts by Bare
Old Jul 23, 2011, 01:12 PM
Joined Apr 2002
5kg is a bit too much for 4 X 55mm fans especially when you consider that the last 25g always weighs 250g. You should be aiming for under 4.5kg so you should start cutting out lightening holes before you go much further.
Here is our last 4x55 mm fan model, that is 4.2kg.
http://www.rcgroups.com/forums/showt...hlight=sperrin
Old Aug 01, 2011, 06:12 AM
Joined Jun 2011
Yeah, I got a bit wobbly about using 20Amp motors... And opted for 4 30Amp ones to give me a bit of headroom! Glad I did, as I'm getting ~500g of thrust on a 2200mAh 20C battery I should say that my test flights will be on 4 12C 1000mAh batteries (as I have some lying around), not much thrust but should be enough to trimm and balance it, and give me some reliability.
I hope to use 2 3000mAh 20C batteries for proper flying, with one battery powering the outboard motors and the other powering the inboard motors, for obvious reasons
-edit- forgot to note, all my batteries are 3S
Old Aug 01, 2011, 06:17 AM
Joined Jun 2011
That sperin is beautiful! I hope I get close to that level of finish
Each wing is coming in at under 0.5Kg and the fuselage is 2kg ( -edit- didn't account for jig pole, the fuselage was actually much lighter)... Without covering... We shall see how I get on
Last edited by bloodline; May 19, 2012 at 05:02 AM. Reason: made an error in my weights :)
Old Aug 19, 2011, 04:06 PM
Joined Jun 2011
A quick update, here is the main airframe uncovered and without completed wing tips, tail fin and control surfaces... but with the fans installed. This structure weighs in at just over 1Kg, which I'm quite happy with.
Old Aug 19, 2011, 06:04 PM
LuvEvolution7 is online now
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
she's looking good and fairly light considering building materials.
LuvEvolution7 is online now Find More Posts by LuvEvolution7
Old Aug 20, 2011, 04:36 AM
Joined Jun 2011
Yes, I'm quite pleased with the weight of this completed section... But I will be covering the fuselage in 1.5mm balsa planking... Which will add a lot of weight to the model... I'm gonna keep an eye the weight and plank the areas where I want extra strength first... Then consider my options if I get concerned about weight. Just a note, that this will have about 500g of batteries (just forward of the motors) which will also be used as ballast... The model is slightly tail heavy at the moment.
-Edit- also I have used carbon fibre in place of the original aluminium parts... After my first flight tests, I hope to replace some of the rear support structures with more carbon fibre
Last edited by bloodline; Aug 20, 2011 at 04:55 AM. Reason: Must stop smoking crack... I'm using 1.5mm balsa planking, not 3mm as originally stated :)
Old May 19, 2012, 05:00 AM
Joined Jun 2011
A short update...
Work on the model was slow over the winter, I had some employment "issues" :roll eyes: but the last month has been quite productive... so here is the state so far!
Right now we are coming in just over 2kg... the sheeting on the topside of the wing will probably push that up by 500g at least...
Old May 20, 2012, 03:01 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Good to see this thread up and running again, looking very nice.
Phil
jumpy is offline Find More Posts by jumpy
Old May 20, 2012, 07:25 AM
vengeance111 is offline
Find More Posts by vengeance111
vengeance111's Avatar
United Kingdom, England, Tedburn St Mary
Joined Apr 2012
Subscribed,looks amazing
vengeance111 is offline Find More Posts by vengeance111
Old May 20, 2012, 02:55 PM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
http://www.bbc.co.uk/news/uk-18135404
A little inspiration for you.
Video Four jet Vulcan at Lords Hill pontious Electric Plane Talk 7 Jul 16, 2006 04:55 AM
Video Four Microfan Vulcan Maiden pontious Electric Plane Talk 1 Jun 19, 2006 05:18 PM
