Old Jun 19, 2006, 07:22 AM
Sleedo is offline
Find More Posts by Sleedo
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
Any advice for a heli newbie with a smartech areohawk?
Just picked a smartech areohawk and have never flown a real heli before. I am looking for words of wisdom on things to look out for, common mistakes to avoid, simple mods for durability etc. Not really looking for advice on which model I should have bought as my budget for this is next to nill, too many irons in the fire at this point. Thanks in advance for your help and guidance.
EB
Sleedo is offline Find More Posts by Sleedo
Old Jun 19, 2006, 01:54 PM
SMaric is offline
Find More Posts by SMaric
Poole, Dorset, UK
Joined Mar 2004
Have you read the EHBG at
http://www.rcgroups.com/forums/showthread.php?t=439631
Practice on a Heli simulator - if you can get one
Lots of people recommend
RADD'S SCHOOL OF ROTARY FLIGHT
http://www.vankets.com/eco/flying-index.html
check the motor pinion >> main gear mesh
make sure that there is no vertical movement of the main gear - it can move up/down & lose contact with pinion
The fix for this is to fit a shaft collar
(or a piece of tubing beneath the swashplate)
Make sure that the main shaft is straight - gently rotate the main gear (by hand) check to see if the top of the rotor head has any wobble
Make sure that the main blades are balanced
Make sure that the flybar paddles are evenly spaced
Adjust battery so that (front-back) Heli centre of gravity is OK
Some people have had to balance the tail blade
make sure that all the rotor head components swivel/rock smoothly with no binding - parts #25 & #29 should rock easily
SMaric is offline Find More Posts by SMaric
Old Jun 19, 2006, 02:21 PM
Sleedo is offline
Sleedo's Avatar
USA, CT, Fairfield
Joined Jul 2004
SMaric, thanks, that is exactly the kind of info I was looking for and plenty to start with I suppose. I have flown a contra rotating little eBay heli, forget the name but it wasn't the BladeRunner, it was a knock off. handled that fine but found it too fragile and all it wanted to do was hover. I'm looking forward to exploring more advanced flying with FP before I make the investment into a CP model.
Old Jun 19, 2006, 02:32 PM
4RCHELICOPTERSPA is offline
Find More Posts by 4RCHELICOPTERSPA
Joined Sep 2005
You can check the tips in this website
4RCHELICOPTERSPA is offline Find More Posts by 4RCHELICOPTERSPA
Question battery advice for elec newbie gouch Batteries and Chargers 3 Jul 06, 2003 02:09 PM
any advice for straightening prop shafts? mikekosatka Power Systems 2 Dec 07, 2002 06:47 PM
Heli newbie with Eco8 questions All__talk Electric Heli Talk 3 Apr 25, 2002 05:13 PM
Advice for electric newbie? Russell2 Sport Planes 8 Dec 31, 2001 05:45 PM
