Old Jun 18, 2006, 11:15 PM
Mel Duval is offline
Find More Posts by Mel Duval
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
Help!
How to make the button on a 9303 a momentary switch
I have been trying to figure out how to mix the trainer button on my 9303 into the rudder channel and have the button a momentary switch where you push it and it is on, let go and it is off. I can get it to be a push on/push off, but that won't work for what I want. Any ideas?
THANKS!
Mel D.
Mel Duval is offline Find More Posts by Mel Duval
Old Jun 18, 2006, 11:40 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You should be able to assign the trainer switch to AUX4
For ACRO mode get into the setup menu ( power on + ENT)
-Choose DeviceSEL
-Scroll over to AUX4, press the scroll wheel, scroll to BUTN and select it with the scroll wheel.
- exit the setup and check AUX4 with the servo monitor.
It should move when you press the trainer switch.
- Now use a PMIX to mix AUX4 into the rudder.
In sailplane mode the method is similar, but some of the names and options in the DeviceSEL menu are different.
Hope that helps,
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Question How to program the momentary switch on EVO9 Nicoflyer Radios 3 Mar 13, 2007 05:00 AM
Question How to program momentary switch on EVO9 Nicoflyer Hitec/Multiplex USA 2 Mar 10, 2007 10:33 PM
Need Help On How To Make 3d Air Plane! lttakas Foamies (Kits) 31 Nov 02, 2003 11:44 PM
GWS pinon gear on upgrade motor. How to make "ridges" on drive shaft Spiteful Power Systems 5 Oct 07, 2003 02:45 AM
