Old Jul 24, 2002, 11:46 AM
drliu is offline
Find More Posts by drliu
Living Room Aviator
drliu's Avatar
Joined Jun 2002
Accurate weights of various DWE micro RC plane components
One of my DWE orders arrived at work, allowing me to weigh everything inside. Here are accurate weights of the components (weighing errors are less than manufacturing variation).
36 sq inches of 1/8" contest grade balsa = 6.271 grams = 1.393 g/cubic inch
32 sq inches of 1/32" contest grade balsa = 1.807 grams (should be 1.4 grams if it is exactly 1/4 the thickness of the above material)
KP00 + gearbox (you can cut away most of the gearbox without obvious ill effect, which might save you 0.7 grams estimated) = 5.038 grams
U80 prop = 0.667 grams
actuator coil with small PCB board, terminated = 0.695 grams
1" GWS wheel (one) = 0.458 grams
12.25" of 0.020" music wire = 0.489 grams (0.040 grams per inch)
1 actuator magnet (both halves) = 0.283 grams
1 battery holder magnet = 0.0739 grams
Clearly the motor and the wheels are the biggest possible sources of trimable weight. Hope these figures are helpful.
-David
drliu is offline Find More Posts by drliu
Old Jul 24, 2002, 12:01 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
David,
You can make a pair of balsa wheels that weighs 0.3g for the both of them.
Check out the weight of Didel gears (Dan's site or the Didel site). KP gears are not very good and rumoured to cause substantial friction loss. You can make a gearbox similar to the one in Bob's picture with the KP/M20-LV motor that will save weight. You can use Dave Lewis' 3.8mm (I think) CF tube as a prop shaft tube with his 1mm id ball bearings (less friction and next to nothing in weight) and then a 1mm CF shaft for the prop shaft and ream your U80 prop out for a tight fit.
Keep it up.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jul 26, 2002, 01:30 PM
drliu is offline
Living Room Aviator
drliu's Avatar
Joined Jun 2002
More
More weights:
0.06" dia. carbon fiber rod: 0.0804 g/in
0.05": 0.0552 g/in
0.04": 0.0285 g/in
0.03": 0.0123 g/in
0.02": 0.00742 g/in
-David
Discussion Estes "Sky Rangers" Micro RC Plane... Don H. Electric Plane Talk 3 Apr 22, 2007 05:54 PM
Discussion mIcro rc plane? FlyJumper Scratchbuilt Indoor and Micro Models 7 Jun 30, 2006 06:13 PM
Found Micro RC Plane Flight Pack johndreid Aircraft - Electric - Airplanes (FS/W) 0 Sep 25, 2005 01:53 AM
WTB: Micro Rc Plane VBSuperMaxx Aircraft - Electric - Airplanes (FS/W) 0 Apr 11, 2005 09:28 PM
Spin Master Air Hogs Intense Micro RC Plane Jax_Myers Scratchbuilt Indoor and Micro Models 9 Dec 28, 2004 09:40 AM
