Go Back   RC Groups > Aircraft - Electric - Airplanes > Parkflyers
Old Jul 24, 2002, 11:17 AM   #1
Joe_in_AZ's Avatar
thrust to weight ratio
Help
In the progress of learning this hobby I am very curious in the thrust to weight ratio. I am not sure what a good ratio is. How do I know if my plane is under or over powered. (no such thing as too much power) here is an example of what I have tested I have a mini max with the stock motor and on my home made thrust meter it puts out 4.2oz of thrust. Buy the plane weighs 14oz.
Also is there an easy calculation for wing loading?? Is there a software program that will do all the math for me??
So many question so little time.
Joe
Joe_in_AZ is offline Find More Posts by Joe_in_AZ   Reply With Quote
Old Jul 24, 2002, 12:05 PM   #2
(aka Cliff Lawson)
Wright Flyer's Avatar
Re: thrust to weight ratio
Joe,
There are two programs that will do all the maths you need - Motocalc or Electricalc and there's even a dynamic web site where you can do a rudimentary form of calculation but Pcalc doesn't give you as much "depth" as the commercial programs.
By the way, these programs are designed for working out the best power system for a model. To work out wing loading it's actually a much easier calculation. You just measure the wing (so maybe 3ft wide by 8" in chord) and work out that this is 2sq ft (8"=0.66ft and 0.66 * 3 = 2). Then weight the plane. If it's 14oz then your wing loading is 7oz/sq ft
Light backyard flyers like the LiteStick and Tiger Moth will have a wing loading of about 3-5oz/sq ft. Reasonably fast park flyers (like a Switchback say) would maybe be about 7-10oz/sq ft and "heavy" scale planes of about 3-4ft wing span might be anywhere between about 10 and 20 oz/sq ft.
On the whole, the lower the wing loading the slower you are going to be able to fly it.
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer   Reply With Quote
Old Jul 24, 2002, 12:17 PM   #3
Static thrust to weight is an imperfect way to judge plane performance but pretty useful on slow flying models. With that said I try for 1:2 - 2.5 on the planes I build, but you can fly on less.
For the more common motors, do an internet search for P-Calc. Its free software that lets you enter all the variable of a plane to see the predicted performance
You don't really need software to calculate wing loading. Ounce per square feet is simply the weight divided by your wing area in square inches divided by 144. WL=ounce/(WA/144).
Hope that helps. I started about 4 years ago and remember feeling very lost and overwhelmed in the beginning. The Litestick wasn't even around when I started. You pretty much built planes yourself.
strouse is offline Find More Posts by strouse   Reply With Quote
PJS300 thrust to weight ratio? Jim Miller Power Systems 13 Jul 26, 2003 05:04 PM
Holy Thrust to Weight ratio Batman! SS ROCKET! eBird Parkflyers 24 Jan 21, 2003 01:08 AM
Thrust:weight ratio > 1 on a living room flyer! drliu Indoor and Micro Models 5 Aug 17, 2002 11:57 PM
Thrust to Weight Ratio??? sapok Beginner Training Area (Aircraft-Electric) 1 Feb 23, 2002 05:21 AM
Thrust to weight ratio Frank B Electric Plane Talk 6 Oct 19, 2001 08:08 AM
Congratulations SimpleM!
