Old Jun 13, 2006, 11:04 AM
ChuckB is offline
Find More Posts by ChuckB
ChuckB
ChuckB's Avatar
United States, CA, Santee
Joined May 2004
TB18 at low throttle
I have a TB18 esc hooked up with my Esskay 400xt and a 3s1p 2100mah battery pack, and a Berg Rx. When I first turn on everything the throttle (at low setting) is ok. Then every once in a while the motor will start to turn on at low throttle. I must then turn my trim from a zero setting to about -25% setting before the motor will turn off. I have 3 TB18 and have never had a problem like this before. Once my setting stops the motor I can fly and have full control of the plane. The Xmtr I'm using is the Hitec Optic 6. I have 4 other models setup in the Optic 6 and do not experience this problem with any of them. Any suggestions as to what could be the problem?
ChuckB
ChuckB is offline Find More Posts by ChuckB
Old Jun 13, 2006, 01:54 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
There is a feature in all CC ESC software that allows the endpoints to be reset until you lock them both down by going to full throttle for a short time. A glitch or other issue can reset the lower endpoint even lower if you haven't locked both ends down.....
Do you see this even after you've flown some or otherwise set the endpoints?
BEC is offline Find More Posts by BEC
Old Jun 13, 2006, 04:41 PM
ChuckB is offline
ChuckB
ChuckB's Avatar
Joined May 2004
Thanks for the quick answer. No it only happens and not all the time when I first turn on with the throttle in the off position. Once in the air and back down or up again it seems to work ok. One thing is that I cannot set my throttle trim to zero again. I must keep it in the -20 or more position. Come back to fly again with the throttle trim at zero and it seems ok and then all of a sudden with it just sitting there the throttle will go on just a little.
ChuckB
Brushless motor kicks back at low throttle settings??? New Park Pilot Power Systems 8 Mar 24, 2015 07:14 AM
Discussion Power loss and "hiccups" at low throttle marckossa Power Systems 6 Mar 24, 2007 03:40 PM
Question ESC Response at low throttle. RGinCanada Dock Talk 14 Jan 07, 2005 01:36 PM
CD-ROM Motor runs rough at low throttle spudboy 3D Flying 8 Nov 30, 2004 03:56 PM
Help with nose high E3D at low throttle Ninjak2k Sport Planes 15 Aug 05, 2003 11:31 PM
